Blue Smoke & Rough Idle at start up
Old May 17, 2010 | 07:57 AM
jumpnjed's Avatar
Question Blue Smoke & Rough Idle at start up
Ok guys I just noticed this problem this winter. When I first crank it up it has a lite haze of blue smoke mixed with black smoke and the idle is rough. After the truck warms up and i drive it it doesnt do it at all. The truck only has 169,000 on it and is not heavily modified. I have an 100 plate all the way forward and afc slid forward as well. It also is straight piped with a 6" stack. It runs fine with no loss of power I am just concerned with the blue smoke on startup. Could this be a sticking injector or something? My valve cover gaskets are all leaking as well.. Should I be worried? I have a 93 12v with almost the same miles and it doesnt do it at all.
Old May 17, 2010 | 06:34 PM
95cumminsguy's Avatar
Is it blue or white? sometimes its hard to tell
Old May 18, 2010 | 07:10 AM
jumpnjed's Avatar
Its hard to tell.. My valve covers are leaking but it doesnt seem to be using any oil. Im not sure exactly whats going on with it. I was thinking maybe I could have a bad injector or somethin. But if it was the injector it wouldnt be light blue smoke.. Any help would be greatly appreciated.. Thanks
Old May 18, 2010 | 04:42 PM
daveO's Avatar
Could be a leaky valve seal that drips into the cylinder when the truck is off. That could give you a little bit of blue smoke during startup. If it's not using oil, and it clears up after a bit, I wouldn't be too worried about it.
Old May 18, 2010 | 07:03 PM
X2 i wouldnt be to troubled by it untill you notice it starts to use oils but then again that might not even be the case it could be white smoke thats just cold unburnt fuel untill the truck warms up which is nothing to worry about either
Old May 19, 2010 | 07:09 AM
jumpnjed's Avatar
Ok ill keep a eye out on it to see how it does. thanks guys
Old May 21, 2010 | 10:51 PM
diesel_addict's Avatar
if its cold enough for fuel to gell that sounds like a solution
bdbfam
Aug 31, 2015 09:06 PM
Jmrobinson
11
Aug 21, 2015 09:54 PM
gagemotors
Jun 9, 2015 04:24 AM
ctjkelley
Jun 3, 2015 06:01 AM
lil red
Oct 10, 2014 09:03 AM
