.020 marine headgasket.... thin washers?
Old Apr 9, 2010 | 01:50 PM
jeepdr79's Avatar
Question .020 marine headgasket.... thin washers?
if i installed a new .020 oversized head gasket how much of a difference will thin injector washers make?
Old Apr 10, 2010 | 07:45 AM
Hammer's Avatar
How much did you have taken off the head when you did the headgasket?.
What timing do you run and what is the spray angle on your set of injectors?.
All of this is needed to answer your question.
Old Apr 12, 2010 | 04:27 PM
jeepdr79's Avatar
i removed 4 thousanths im using ddp stage 2 injectors
hope that helps
Old Aug 2, 2010 | 09:03 AM
jeepdr79's Avatar
bump!
anyone?
also where do u but ur hg from? i want a cummins one.... not chinese!
