Pedal wont go past half way.
Old May 2, 2010 | 12:36 PM
2.S.F.L's Avatar
Default Pedal wont go past half way.
My throttle pedal wont go past half way. Is it the injetion pump or what, when go to pinn it it the pedal will only go half throttle then stop unless i really push on the pedal it will go past that one spot and run fine. Can someone tell me whats wrong with it?
truck is a 1997 cummins.
Old May 2, 2010 | 12:43 PM
tltruckparts's Avatar
try revving it through the throttle on the pump, if that runs fine, i would say check for kinks/damages in your linkage
Old May 2, 2010 | 04:29 PM
Dallas Flywheels's Avatar
Sounds like lincage or cable problem.
Old May 2, 2010 | 11:28 PM
Cody Cummins's Avatar
Sounds like a linkage problem, if you recently replaced your TPS sensor check and make sure you put it on the right way, also dodge has a recall on the throttle linkage cable, i dunno if you ever had that done, if not look into it!
Old May 3, 2010 | 01:07 AM
12vcummins96's Avatar
sounds like a linkage problem
weatherby
Aug 31, 2015 08:04 PM
rusmis91
Chevy/GMC Duramax 04.5-05 LLY
Aug 6, 2015 04:44 AM
Moly Squid
Mar 28, 2015 04:26 PM
krinderhagen
Dec 31, 2014 07:12 PM
1stgenswap
Nov 3, 2014 09:45 PM
