Fuel pressure readings video.???
Old Apr 13, 2010 | 08:40 PM
hereismylife's Avatar
Question Fuel pressure readings video.???
Here are some vids where my fuel pressure is....
http://s689.photobucket.com/albums/vv254/j_k_auto/FUEL%20PRESSURE%204%2013%2010/
I shimmed the ovf and it is still low.
I drove around and it seems to low from what I have read.
I am still thinking on getting a adj reg because this ofv just sucks. I tried to adjust it and it went up from eight to where it is at now at idle.
If I get a adj reg can I run it from 30psi and up or does it have to be at 22 psi?
Old Apr 13, 2010 | 08:52 PM
Red_Rattler's Avatar
High Tech Redneck
Ppumps can handle 40psi all day
Old Apr 14, 2010 | 12:04 AM
Do you have a needle valve or pressure snubber on there? That guage is not happy.
Old Apr 14, 2010 | 04:35 AM
Do you know why they have the ofv set at 22 psi if it can handle 40 psi like you are saying?
Just trying to figure this out.
I have a needle valve in there.
Not sure where to get the pressure snubber. I am searching this now...
Last edited by hereismylife; Apr 14, 2010 at 04:35 AM. Reason: Automerged Doublepost
Old Apr 14, 2010 | 08:26 AM
dan33klein's Avatar
you can get them from summit part #ATM3279
there made by autometer.
im also curious how to get 35 psi at the pump instead of 22? can you get a new ofv
Old Apr 14, 2010 | 08:56 AM
12vcummins96's Avatar
it should not be under 25 psi under load
Old Apr 14, 2010 | 02:29 PM
Question
Even with mt 75 injectors?
if so what should be my bottom number at wot?
Old Apr 14, 2010 | 07:02 PM
ATTN video update....
Here are the vids...hopefully you like them....
http://s689.photobucket.com/albums/vv254/j_k_auto/FUEL%20PRESSURE%204%2014%2010/
I did adjust my pressure to 30 at idle. I did not see any difference in hp or the lp
Old Apr 14, 2010 | 08:16 PM
dan33klein's Avatar
how did you end up adjusting the pressure
Old Apr 14, 2010 | 09:39 PM
I have a special tool to close a hose off. It has a slider on it that keeps pressure on the hose to close it off. I just adjusted the clamp till I had 30 psi at idle. I drove it around to see if there is any change...I saw alittle about 5-10 mph but that is it.
