setting valves on 12 valve
Old Mar 15, 2010 | 09:06 PM
bws_86's Avatar
Default setting valves on 12 valve
What should i set my valves at. I need to change valve cover gaskets and i thaught i would check my vavles.
Old Mar 15, 2010 | 09:12 PM
B Series Valve Adjustment
Old Mar 15, 2010 | 09:19 PM
Lil Red Express's Avatar
10 thousanths intake
20 thousanths exhuast
Old Mar 16, 2010 | 09:47 AM
joey's Avatar
Will it hurt anything for the valves to be a little bit tight because when i put in the head bolts it pulled the head down like 2 thousands more than it was.
Old Mar 16, 2010 | 11:59 AM
oglejust's Avatar
headbolts have nothing to do with valve adjustment..
Old Mar 16, 2010 | 12:24 PM
nate379's Avatar
I'm not sure why you think that, but you are 100% wrong.
Old Mar 16, 2010 | 01:55 PM
NadirPoint's Avatar
I'd check them again, but 8/18 is OK as long as they are running out, which they usually do.
Old Mar 16, 2010 | 02:48 PM
You should be ok but I would go ahead and set them right.
Old Mar 16, 2010 | 04:04 PM
94 12valve's Avatar
if the head went down .002, all you would have to do is re adjust your valve lash and you should be fine.
RA113024
Mar 13, 2016 07:42 PM
Oklahoma24v
Jun 1, 2015 07:24 PM
Jake12valve
May 10, 2015 11:57 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
