12v High Idle
Old Apr 25, 2010 | 09:10 PM
dodgecummines12valv's Avatar
Default 12v High Idle
hey guys was up i wanted to now haw to rig a high idel switch in my 1994 dodge cummins 12 valve 2500 5 speed
Old Apr 25, 2010 | 09:26 PM
cummins95's Avatar
i dont think you can hook up a swith for it on these mechanical motors. i have heard of guys running a cable into the cab to set the idle. You might be able to rig up a stepper motor somehow but i tend to stay away from electricity.
Old Apr 25, 2010 | 10:28 PM
12vcummins96's Avatar
i was going to say the same thing a stepper motor some way
Old Apr 26, 2010 | 07:17 AM
wes-cummins's Avatar
it can be done electrically, or just wedge a stick between the seat and the pedal thats what ive done all winter, fully adjustable
Old Apr 26, 2010 | 09:40 AM
85_305's Avatar
Being Evaluated
A lot of people use a choke-cable. Mount it on the dash next to the steering wheel and attach it to the throttle bracket somehow. Just pull the choke cable to the desired hi-idle speed and there ya go.
Old Apr 26, 2010 | 08:01 PM
12Vdodge's Avatar
I used the stick method all winter and it worked great...plus it was free. Just curious, but what RPM's do you guys raise the idle to?
Old Apr 26, 2010 | 08:04 PM
85_305's Avatar
Being Evaluated
1200 or so
Old Apr 26, 2010 | 09:16 PM
96blackcloud's Avatar
i do the stick method too works great all winter and with the power seat you can set the idle to whatever you want, i raise mine to a grand to warm up a bit during the winter. the stick doubles great to self prime the truck to from the driver side fender if needed
Old Apr 27, 2010 | 02:41 AM
BrettWINspeed's Avatar
Someday I'd like to take the time to figure out how to make the cruise control work as a high idle. I'm no electrical engineer, but there has to be some way to send power to the accuator.
Old Apr 27, 2010 | 07:43 AM
85_305's Avatar
Being Evaluated
Pretty sure the actuator is vacuum operated; when it recieves vacuum, it holds it in place (or something to that affect..)
