Turbo oil return block elbow
Old Apr 19, 2010 | 01:16 PM
woolyhorn's Avatar
Default Turbo oil return block elbow
How is that oil line fitting in the block connected? (located below the oil filter, pointing upward, the oil return from the turbo connects to it) Is it threaded or pressed. I have a oil leak there and It was either the clamp being loose or this fitting. I need to check it out, but I don't know how to take it off.
Old Apr 19, 2010 | 01:19 PM
94 12valve's Avatar
I can't remember but I think it was threaded ... I should know this I had my oil pan off last year
Old Apr 19, 2010 | 01:26 PM
12vcummins96's Avatar
its threaded
Old Apr 19, 2010 | 01:59 PM
woolyhorn's Avatar
Is there an O ring at the top of the threads? Do these leak very often?
Old Apr 21, 2010 | 10:23 AM
cummins_guy's Avatar
there is no gasket, it is probably loose, we have these in stock.
Old May 27, 2012 | 01:41 PM
jcarrick's Avatar
Sorry to revive an old thread, but i am having troubles with this. How do you get it out? Can you rotate it so it points towards the back of the block?
avatardvr
18
Aug 8, 2019 12:38 AM
honda89
Oct 17, 2015 01:08 PM
rodbuilder
Jun 26, 2015 12:48 AM
CumminsCoalRoller24/7
Apr 21, 2015 09:03 PM
MrCat4974
Mar 25, 2015 08:13 PM
