Problems with....just about everything
Old Apr 2, 2010 | 02:57 PM
justinb12's Avatar
Default Problems with....just about everything
So i got my dodge out the shop and now i have a transfer case rear seal leak. Is that on me or should shop shop fix it? Also, my truck will take awhile to start. I turn the key and its a honest two seconds of waut tu tutu tu, cranks and baahhhhhh. Could it be from the timing bump? Any help would help
Old Apr 2, 2010 | 04:50 PM
TwinStackPete379's Avatar
my timing is set at 16 and on my truck it does take a little longer to start. i believe its from timing. of air in fuel system. did ya check that out?
Old Apr 2, 2010 | 04:59 PM
justinb12's Avatar
i just went through the whole intake track (wipin oil off of everything as i go) and cleaned my air filter. It started the same. maybe bad fuel cuz yesterday it didn't seem like it was as rev happy as it normally is. The water in fuel light comes on often and i drain it twice weekly. Guess its the timing
Old Apr 2, 2010 | 05:03 PM
kayden101's Avatar
are you giving the gas pedal a little loving when trying to start..??
12v arent like the newer trucks.... give it a little gas when starting it after its been sitting for a while... thats what i do to mine... 2 pushes on the gas pedal when i start it up and its on.
what did you have the shop do to it? did they have to do anything to the transfercase?? if so.. then as long as it didnt leak before they need to fix it..(sometimes they mark on the paper work that it was leaking prior to service)
if they did not touch the transfercase then they are not going to do anything about it. and it could of just start leaking as soon as you got it back. sometimes that happens.
your fuel filter been replace?
Old Apr 2, 2010 | 05:09 PM
justinb12's Avatar
i'll try the gas blip for starting.
They install a new clutch, 4gsk, set the timing to 16* and gave me a tune-up on my pump. But i watched the guy put the drive shaft in and he splined it and let it hang there while he gather the bolts for the next step. it just comes out of a weep hole in a rubber wiper seal. Not sure why but right after that is the rear seal...right?
negaitive on the filter.
Old Apr 2, 2010 | 06:22 PM
lodal cummins's Avatar
that is totally normal as far as starting goes with the timing bump.
Old Apr 2, 2010 | 06:25 PM
justinb12's Avatar
hit the throttle once before i turned it over and fired right up. Scared the crap outa my ol lady, she was standing by the back getting the dogs to move when it came roaring to life. she got smoked on too. got in the truck and didn't say a word. whata gal
Old Apr 2, 2010 | 07:11 PM
HAYMAFIA's Avatar
i have had 3 12 valves and every one i hold the fuel pedal right when i crank it then let off. they fire right up
Old Apr 3, 2010 | 01:14 AM
zach_west's Avatar
yup first time of the day ya gotta give it a lil tap haha
Old Apr 4, 2010 | 07:40 AM
94 12valve's Avatar
here is how mine started with 22* of timing
YouTube- Dave Swank
as for the rear seal, since they had the tcase off the truck it should be on them to fix it.
Zachbishop
Feb 10, 2015 10:23 AM
Ol Goat
Jan 22, 2015 02:16 AM
ChgoSquad5
Ford Powerstroke 2011-Up 6.7L
Jan 6, 2015 11:37 PM
Tucker126
Jan 2, 2015 08:09 AM
yams
Audio Equipment/Electrical
Nov 29, 2014 09:25 PM
