Where do these go??
Old Mar 16, 2010 | 07:25 PM
Rexy's Avatar
Default Where do these go??
This came in the Timing cover gasket kit from O'Reillys' wondering where these other 2 pieces go.
Thanks
Old Mar 16, 2010 | 07:37 PM
wes-cummins's Avatar
one should be a crand seal, one might be the oil fill seal
Old Mar 16, 2010 | 08:20 PM
12valvetater's Avatar
Crank and oil fill
Old Mar 16, 2010 | 08:29 PM
Rexy's Avatar
I have already put the new crank seal in. In the pic, does the top left rubber seal go in the oil fill? The top right is all metal.
Old Mar 16, 2010 | 09:26 PM
Overmodified's Avatar
Mine dosn't have the black circle just the tin peice the seal and that plastic sleeve that is in the seal. I think the tin part goes on the outside closest to the balencer?????
Old Mar 16, 2010 | 09:45 PM
hdsidehack's Avatar
the tin thing is the installation tool for the seal
Old Mar 16, 2010 | 11:30 PM
Rexy's Avatar
I was hoping the metal piece was for installation, cause thats what I used it for!! Still not sure on the black rubber piece.
Do you leave the seal flush with the front of the cover, or put it in as far as the installation piece will let you? about 1/4 inch?
