Fuel Problem
Old Apr 2, 2010 | 06:52 PM
Redsmokincummins's Avatar
Default Fuel Problem
my father inlaw has a 95 extedned cab auto. it runs fine when its cold. after it warms up it likes to stumble and rev up. it has had all of the filters changed, a new lift pump, and the throttle cable replaced at the dodge dealer in north battleford. The thottle cable still doesnt seem to be working properly, its still loose on the pedal. People are telling him that the main pump isnt working properly. Any ideas ??
Old Apr 2, 2010 | 11:50 PM
dan33klein's Avatar
does it seem like the throttle is"hanging up"?
Old Apr 3, 2010 | 01:11 AM
zach_west's Avatar
mine did that i replaced the spring on the throttle and it stopped that. also when i put my new injection pump on it was doing that. replaced my governor springs and it ran alot better.
Old Apr 3, 2010 | 12:26 PM
Default fuel problem
no the throttle isnt hanging up now. it runs fine then seems to just run out of fuel. Wondering if he has the same problem as i do , being the suction tube in the tank is cracked and wont suck fuel properly..?? The throttle sticks al most wide open at times. not really sure how to tackle this.
Old Apr 3, 2010 | 12:56 PM
94 12valve's Avatar
when it hits about 2200+ rpm is when this happens?
if so your feeling your stock gov springs defuel.
As for the throttle sticking how many return springs do you have?
Old Apr 3, 2010 | 11:12 PM
its still the factory throttle so the same as new?? will know more in the am
Old Apr 10, 2010 | 01:22 AM
anyway this truck is an 97 auto , sorry. can he replace the governor springs with factory pieces or does he have to get a 3k kit?? The throttle seems to be working properly.
Old Apr 10, 2010 | 06:14 AM
kayden101's Avatar
if it is doing it at the 2200 rpm mark as stated above and you want more fueling rpms... buy the 3gsk.. only bout 100 dollars and there are plenty of right ups with pics on how to install them
http://www.thoroughbreddiesel.com/pe...vernor-kit.pdf
Old Apr 10, 2010 | 07:17 PM
Neibe's Avatar
It sounds like you have a broken or missing throttle spring.
Old Apr 11, 2010 | 05:28 PM
that could be... will have to check with the father in law
