Transfer Case
Old Apr 19, 2010 | 07:30 PM
ztk7220's Avatar
Default Transfer Case
I have a NP241 DLD (light duty) transfer case on my truck but it is junk. So i was wondering if a NP241 DHD (heavy duty) will work on my truck. any one done it will it work.
Old Apr 19, 2010 | 09:20 PM
HAYMAFIA's Avatar
it has been done but i dont know what it takes. all my dodges have been 2 wheel drive
Old Apr 22, 2010 | 11:37 PM
D-Roc's Avatar
I just bought the truck in my sig (1998). How can I tell what I have?
Old Apr 23, 2010 | 12:02 AM
tltruckparts's Avatar
there should be a metal tag about 2" round that is silver with red writing on it (i think its red at least). and it will have engraved the model number. it should be on the back end of the transfer case
Old Apr 23, 2010 | 12:09 AM
bobcat67's Avatar
i know alot of guys with the 2nd gen pickups upgrade to 271D like found in the 3rd gen trucks, but i've broken 2 of mine now so i'm not sold on the whole heavy duty bad@$$ transfer case i supposedly have
Old Apr 23, 2010 | 06:01 AM
94 12valve's Avatar
I just did this a few months ago. i got a 241dhd out of an auto so I had to change the input and the 241dhd slip yoke is bigger than the 241dld so that will need to be changed. Other than that it was a bolt up swap.
Old Apr 23, 2010 | 10:27 AM
kazairl's Avatar
What do you keep breaking on it? Just curious.
Old Apr 23, 2010 | 11:03 AM
94 12valve's Avatar
The 241dld output on the left and the 241 dhd on the right
The chain on the 241hd is also thicker than the 241ld
Old Apr 23, 2010 | 11:17 AM
kazairl's Avatar
241 dhds also have a PTO cover and gear where as the DLD does not.
Old Apr 23, 2010 | 11:21 AM
94 12valve's Avatar
that is true there are also 2 kinds of 241dhd's the one with the solid tailhousing has the same output shaft as the 271 and the one with a spilt housing has a slightly smaller shaft than the 271. The solid tailhousing does not have a mount for a speedo but the split shaft does.
