figure this one out!!!!!!!!!!!!
Old Mar 28, 2010 | 11:33 PM
captain_stabbin's Avatar
Default figure this one out!!!!!!!!!!!!
i have a 94 12valve 5spd i recently blew a headgasket on it, soooo i figured since i had it apart i would mod it.
i did the kdp fix
quickspool manifold 191dv's 75horse ddp injectors head studs airdog 165 4gsk 60lb springs htt64/71/14 turbo vulcan boots an clamps since i put all this stuff on the truck it will not give it enough fuel to spool turbo, i am only getting a small amount of black smoke i have the timing set at 16* i have checked for boost leaks i have tryed taking out the fuel plate i have pretty much tryed every thing,, what would cause this to happen i am stumped!!!
Old Mar 29, 2010 | 01:06 AM
ArizonaRedneck's Avatar
only thing i can think of right off the bat is your fuel pressure good
Old Mar 29, 2010 | 01:39 AM
yes, i have tryed 2 other and they say the same thing!!
Old Mar 29, 2010 | 05:58 AM
94 12valve's Avatar
shutdown soleinoid pulling all the way up?
Old Mar 29, 2010 | 03:59 PM
yepp
Old Mar 29, 2010 | 04:43 PM
cummins95's Avatar
fuel filter?
Old Mar 29, 2010 | 04:47 PM
biged681985's Avatar
when u put the 4k kit in, u did tighten them up right didnt u?
Old Mar 29, 2010 | 05:08 PM
Red_Rattler's Avatar
High Tech Redneck
Afc functioning correctly? Does it have a good boost reference?
Old Mar 29, 2010 | 07:21 PM
fuel filters brand new!!! the afc is workin as it should! the gov springs was a easy install also!!
Old Mar 29, 2010 | 07:35 PM
Benjamin's Avatar
Bombardier
did you check the wastegate and make sure it is closed when there is no boost pressure?
see below response
