Tires
Old Mar 16, 2010 | 05:23 AM
nate379's Avatar
Default Tires
I need to put 2 tires on the front of my 2wd 95 3500 and trying to figure how big I can go.
I'm putting a levelling kit on the truck (1.5"), so hoping I can fit a 285/75/16 without rubbing.
Yay?? Nay??
Old Mar 16, 2010 | 09:55 AM
joey's Avatar
Um ah mabe i would go like 31's insted of 33's.
Old Mar 16, 2010 | 10:26 AM
MUDDY's Avatar
width is the prob between the duals with no spacer. 235/85 is the max on the pre 2000 wheels and 255s are max on the 2000 and ltr. and depending on the brand those sizes are pushing it.
of crse you mentioned the front specifically but ya want all six to match, dontcha. 285s would fit the wheels on the frnt but are max width for the width of rim. 235s on mine with the runnin boards and mudflaps clearance is tight in a turn. the extra height and width of 285s may be too close in a turn even w/o the flaps etc even w/ a 1.5 lift. i wouldnt go bigger than a 265 on front unless ya had a couple of nakid 285s ya cld mount just to try without purchasing any. and then it would look funny having mismatched tires............
if that 95 2wd was mine i'd just do all 235s.
Old Mar 16, 2010 | 11:25 AM
nate379's Avatar
The stock tires are almost 31s, I know I can fit larger than that!
I might get a set of 3rd gen wheels. Guy has a set of tires/wheels for a good price.
Trying to go big as I can to loose some rpm. Right now 70mph is pretty much all it's got (2500rpm), plus the tiny skinny tires in front remind me more of something that should be on a Camaro drag car, not a pickup!
Old Mar 18, 2010 | 02:19 PM
nate379's Avatar
Think what I may do is put 2 new 235/85/16s on the front. The rears are pretty new, but when they wear out, will be able to swap those to a bit larger tire as well.
The fellow that had the 3rd gen wheels, well they are 17" and only 2 tires are decent.
Kooper
Dec 4, 2015 12:03 AM
Jsully
Aug 31, 2015 07:55 PM
j_stroker
Mar 5, 2015 07:35 AM
ChgoSquad5
Ford Powerstroke 2011-Up 6.7L
Jan 6, 2015 11:37 PM
Nov 20, 2014 11:20 AM
