what tranny fuild
Old Mar 11, 2010 | 08:41 PM
94cummin12v's Avatar
Default what tranny fuild
what trans fulid should i run on a new reduilt 47rh
Old Mar 11, 2010 | 08:43 PM
wes-cummins's Avatar
atf + 4 unless the person that rebuilt it says diff
Old Mar 11, 2010 | 08:46 PM
Old Mar 11, 2010 | 08:53 PM
Shea@L&N Performance's Avatar
FormerVendor
ATF +4
Old Mar 11, 2010 | 09:30 PM
ArizonaRedneck's Avatar
who rebuilt it and did they make any suggestions or say anything about warranty issues and i read a little bit of this you might read it and throw the amsoil question out there and see how people like it http://diesel-trucks.com/dodge_cummins_transmission.htm
Old Mar 11, 2010 | 09:32 PM
tltruckparts's Avatar
did they still use the atf+4 on these? i know thats what they used in the 46rh's but i dont know for sure what to tell ya. im kinda curious too
Old Mar 12, 2010 | 05:05 AM
440ctd's Avatar
atf +4
Old Mar 12, 2010 | 07:03 AM
it will say rite on the dip stick
Old Mar 14, 2010 | 04:37 PM
bowtech's Avatar
the dip stick says the mopar fluid or dexon II where is the atf+4 comein from? would the atf+4 mix with the dex fluid? bc i put the dex fluid in the tranni last and i just put my tc in and put the atf4 in the tc and i would need to fill up the pan at least half. so could i use the dex or the atf4 or i have to use all the same fluid? might be dumb question but i heard could mix as long as ones not a synthetic
Old Mar 15, 2010 | 03:43 AM
nate379's Avatar
Dextron 3. It's better than ATF +3/+4 since it has less friction modifiers (= less slip)
