wastegate adjustment
Old Apr 23, 2010 | 09:32 AM
cummins95's Avatar
Default wastegate adjustment
im always toyin under the hood of my truck and the other night i slipped and snapped off my boost elbow and i had to put the stock fitting back in. 17 psi isn't very efficient for keepin this pig cool, so right now i have the line plugged, but im also not a big fan of 50 psi, high drive pressures and a pegged egt gauge... the old boost elbow helped, but it wasn't adjustable n i couldn't get over like 25 psi
i'd like to adjust the wastegate itself to open at 35, but im not sure which way to go. do i wanna make the rod longer or shorter? i'd like to fix this the right way n not with a "presidential solution"
Old Apr 23, 2010 | 10:05 AM
85_305's Avatar
Being Evaluated
Dude just order a 16$/shipped adjustable boost elbow off of ebay and call it a day.
Old Apr 23, 2010 | 10:18 AM
12valvetater's Avatar
I have an adjustable elbow laying around somewhere. If I can find it it's yours.
Old Apr 23, 2010 | 01:32 PM
Threesixty's Avatar
I got an adjustable from ebay, for about 20 bucks including shipping. But as it turned out I didn't do enough research for a '94. Seems I can't use it without taping the turbo hosing...
Arrived in about 4 days....
http://cgi.ebay.com/ebaymotors/Adjus...Q5fAccessories
Old Apr 23, 2010 | 01:54 PM
12vcummins96's Avatar
Adjustable Boost Elbow ---Dodge Cummins Turbo hx35 hx40 : eBay Motors (item 300394038373 end time May-06-10 11:23:13 PDT)
there is a metal line at the back of your afc that is where your elbow goes
Old Apr 23, 2010 | 02:40 PM
The elbow goes in the compressor housing that line is what controls the wasetgate. The line to the afc you want at full boost (no elbow).
I couldn't use the elbow on mine since it senses pressure for the gate and the afc at the same port on the afc.
Texasboy
5.9L Rotary Performance
Sep 19, 2016 12:06 PM
2gCummins
Jul 22, 2015 11:34 PM
wpg6.5
Feb 19, 2015 07:27 PM
marks86
Oct 23, 2014 03:25 PM
