no fuel!!!!
Old Mar 19, 2010 | 06:12 PM
captain_stabbin's Avatar
Default no fuel!!!!
i just got my truck back together... again!!!!!!! when i go to drive it.... it will not spool up turbo and i believe its a fuel issue. i have 4gsk 60lb springs 191'dv's 75 horse injectors, pulse manifold airdog2 165 64/71/14 turbo.. i just changed out the over flow valve an still nuthing feels like the fuel is just by passing the ofv, is this normal the trucks starts an runs fine, but is not gettin enough fuel to spool turbo wtf
Old Mar 19, 2010 | 06:30 PM
FastCR's Avatar
is the gov working correctly? Got a fuel pressure gauge? AFC air line in good shape?
Old Mar 19, 2010 | 06:35 PM
i do no have a fuel pressure gauge, i just ordered one, the afc airline goes from the head to the afc housing correct?
everything seems to be workin correctly i just dont get it
Old Mar 19, 2010 | 06:39 PM
FastCR's Avatar
yeah. it goes from the intake manifold-plate-thing to the back of the afc. if there's no pressure there, the afc lever won't move forward and it won't fuel much. I'd double check that little line, make sure its not leaking or kinked. What plate are you running?
Old Mar 19, 2010 | 08:16 PM
cummins95's Avatar
check your fuel filter. might be blocked up
Old Mar 20, 2010 | 04:08 PM
nuthin wrong with line, or fuel filters just put brand new airdog2 on
Last edited by captain_stabbin; Mar 20, 2010 at 04:08 PM. Reason: Automerged Doublepost
Old Mar 20, 2010 | 08:57 PM
joey's Avatar
Did you check and make sure all the turbo boots are on
Old Mar 21, 2010 | 09:22 AM
oglejust's Avatar
fuel shutoff not pulling up all the way?
Old Mar 21, 2010 | 10:11 AM
wes-cummins's Avatar
any boost leaks?
pull the afc off put shop air to it to make sure foot moves
Cavnar
Sep 9, 2015 07:18 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
Gm3500
May 7, 2015 11:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
