My brakes are starting to scare me. Any help?
Old Apr 12, 2010 | 11:23 AM
justinb12's Avatar
Default My brakes are starting to scare me. Any help?
The problem is that i can pump them up and hold steady pressure and they will eventually fall all the way to the floor. No leaks, fresh pads and decent fluid. So what is happening? I understand how it works just not this.
Old Apr 12, 2010 | 11:30 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
are you back in wv working yet
Old Apr 12, 2010 | 11:31 AM
justinb12's Avatar
Soon i hope. you know about this brake problem?
Old Apr 12, 2010 | 11:41 AM
diesel pap's Avatar
brians shop would know.
Old Apr 12, 2010 | 03:06 PM
monster12valve's Avatar
wheel cylinder
pull the rear tires off and pull the drums.... bet u have a leaker
Last edited by monster12valve; Apr 12, 2010 at 03:06 PM. Reason: Automerged Doublepost
Old Apr 12, 2010 | 04:00 PM
85_305's Avatar
Being Evaluated
ya either a wheel cylinder or maybe there is an issue with your hydroboost? Are the vac lines all good?
Old Apr 12, 2010 | 05:05 PM
440ctd's Avatar
could be problem with the internals of the master or rear brake cylinders
Old Apr 12, 2010 | 05:16 PM
DixonPeer's Avatar
What the hell is a "hydroboost"? Hydro would mean water, so I don't get it.
Anyway, sounds like a leak somewhere. Did you bleed the brakes lines (get any air out of lines)?
Well, here's an article that explains "hydroboost": Installing A Hydroboost Brake System on a Chevy
Old Apr 12, 2010 | 05:17 PM
justinb12's Avatar
me and my brother checked lines, mastercylinder, front leaks and rear. Found nothing. must be something internal.
Old Apr 12, 2010 | 05:24 PM
85_305's Avatar
Being Evaluated
You sure you checked the master cylinder and not just the brake fillup? I'm pretty sure '96 had hydroboost
