where"s my leak???
Old Mar 10, 2010 | 06:09 PM
BAD ASS RAM's Avatar
Default where"s my leak???
i have an oil leak almost in the middle front of the engine,it is a little on the passenger side though.it seems to dump when i shut the truck off.i am going to degrease it and look but i was just wonderin if somebody could point me in the right direction first,thanks
Old Mar 10, 2010 | 06:24 PM
TXHC's Avatar
Possibly front timing cover gasket, front crank seal, oil filter/bracket, turbocharger drain hose?
Old Mar 11, 2010 | 08:30 AM
Hammer's Avatar
Might even be Killer Dowl Pin Problems also.
Old Mar 11, 2010 | 09:34 AM
joey's Avatar
I bet if you take out your fan and look the crack will be right there under the fan. Or what happened to mine was some of the bolts vibrated loose a little bit and that made it leak. Is the belt sqweeking or is there oil all over the front of the motor.
Old Mar 12, 2010 | 09:58 AM
there is oil on the front of the motor,but no sqweek.if i had dowel pin issues,would it not be making some kind of noise?
Old Mar 12, 2010 | 12:54 PM
12valvetater's Avatar
No it wouldn't make any noise. Also it could be the bolts fell out or the case.
Old Mar 12, 2010 | 01:18 PM
joey's Avatar
You will have to get some of the oil off and get a big light and look really good if its the killer dowel pin you will see the crack. Mine cracked and the bolts vibrated loose.
Old Mar 15, 2010 | 09:54 AM
where would the crack be?
Old Mar 15, 2010 | 03:27 PM
Under the fan bracket in that area.
Old Mar 15, 2010 | 04:03 PM
dshane62's Avatar
what about the sqeak noise? mine just started but it s not leaking bad.
