starting issue
Old May 9, 2010 | 10:58 AM
cumminsCrazy's Avatar
Default starting issue
okay so when i first fire the truck up in the morning i doesnt wanna start have to turn the key a coulpe times but its cranking not the starter. but after it fires up it will start great for the rest of the day even if its cooled down what do you guys think
Old May 9, 2010 | 11:04 AM
estrada5.9's Avatar
So it cranks and cranks or does it click and click then starts?
Old May 9, 2010 | 11:47 AM
codes?
Old May 9, 2010 | 01:23 PM
Hammer's Avatar
If its the 97 in yoiur signature then I would say its allowing air into the fuel system and loosing its prime.The sitting overnight versus driving it and daily starting is why it is hard to start.
Old May 9, 2010 | 08:25 PM
Racer9's Avatar
It's also posssible the idle is too low. Try a little throttle to start, if that helps, go here; Ram Diesel Problems
Otherwise, a common problem is the old rubber fuel lines getting old. They start to let air in and you lose prime. Takes a few minutes to get it back.
Old May 9, 2010 | 10:14 PM
94 12valve's Avatar
check you shutdown soleinoid it could be going bad
Old May 10, 2010 | 07:27 AM
no clicking all cranking and i have to give it gas to fire but the idle is set at 950 so it should be good it lopes heavely once it does fire then smoothes out
Old May 10, 2010 | 10:09 AM
Governor springs might need some tweaking.
dskewes14
Sep 14, 2015 09:19 AM
06kyleP
Jul 19, 2015 06:10 AM
Squirt
Jun 19, 2015 12:40 PM
custom7.3
Nov 24, 2014 05:16 PM
7.3stroke
Oct 27, 2014 06:25 PM
