lost 5 pounds of boost
Old Apr 22, 2010 | 06:38 PM
NoMo6.0's Avatar
Default lost 5 pounds of boost
i have a 98 12 valve with a 215 hp pump #6 plate 140 hp nozzles ats turbo,snow water injection,fass lift pump new filters.i wouldnt say i know it all but im no dummy either.....anyways i just put a 4k gov spring in and thats the only thing that changed and as a result i lost boost. i have 60 lb valve springs so the valves arent floating,it seems like i lost fuel??i have 50 lbs of press to the pump,i went from the stock gov springs to the 4k and lost boost.....any ideas?????
Old Apr 22, 2010 | 06:48 PM
12vcummins96's Avatar
check for boost leaks
Old Apr 22, 2010 | 06:52 PM
NoMo6.0's Avatar
Default thats what i thought
no leaks.......
Old Apr 22, 2010 | 07:10 PM
85_305's Avatar
Being Evaluated
make sure the ppump is tight all the way down. Make sure air/fuel filter is good. Check wg line.
Old Apr 22, 2010 | 10:18 PM
lodal cummins's Avatar
make sure the measurement from to stud to spring retainer is between .045 and .050. sounds like you did not get the springs set tight enough for real good fueling
Old Apr 22, 2010 | 10:19 PM
oglejust's Avatar
what he said ^^^ i think u need to give the springs another click or 2
Old Apr 24, 2010 | 01:34 PM
NoMo6.0's Avatar
Im at 0.85 on both springs
Old Apr 24, 2010 | 05:51 PM
oglejust's Avatar
then theres gotta b a leak somewhere..
Old Apr 25, 2010 | 02:34 PM
NoMo6.0's Avatar
Thanks for all the help,found a split in my intercooler.Had to pull it to find it
stewart.william.c
Feb 11, 2015 01:39 AM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
offroad00
24
Oct 23, 2014 03:28 PM
