looking for 14cm exhaust housing
Old May 1, 2010 | 02:30 PM
cumminspwr11's Avatar
Default looking for 14cm exhaust housing
im running a hx-40 compressor and wheel with a 12cm housing right now and i think my egts may be too high. im waiting on the probe for my egt gauge to check it. I have the 160hp pump with 90hp injectors, #0 plate, 181 dvs, 3k govenor springs, and a 2095 rack plug. anyone have any good advice on which way I should go for more power? also I dont know what size the compressor wheel is, if i remember right it is a 7blade wheel, did the 40s come with different sizes? Im think a 14cm exhaust housing would be the next step form here and was wondering if anyone had an extra one laying around
i was also thinking maybe a custom set of twins using my current turbo and another built using a 22cm holset exhaust housing i have
Last edited by cumminspwr11; May 1, 2010 at 02:30 PM. Reason: Automerged Doublepost
Old May 1, 2010 | 11:00 PM
tltruckparts's Avatar
are you using a truw hx40 or a 35/40 hybrid. because they dont make a 12cm hx40 housing and a 14cm is pretty much impossible to find they werent regular production
Old May 1, 2010 | 11:08 PM
dan33klein's Avatar
has to be a hybrid, smallest hx40 housing is 16cm
Old May 2, 2010 | 12:10 AM
they make a 14cm theyre just super rare. it was a trial thing holset did they never went into production but theres a few around
Old May 2, 2010 | 10:03 AM
dan33klein's Avatar
sounds like next to impossible!!
Old May 3, 2010 | 11:18 AM
high tech turbo and gillett diesel both have the 14cm housings for like $200. as for my current turbo, i took a hx35 apart and put the exhaust fan and shaft into a hx40, so im able to use the 40 compressor but also use my stock 12cm exhaust housing, didnt cost me anything cause i found the 40 laying around the shop and i noticed better power but the boost levels stayed just aboth the same
jeffersonl
Nov 15, 2015 07:35 PM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
D-350 dually
Apr 11, 2015 11:38 PM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
