Valair Ceramic single clutch like?
Old Apr 4, 2010 | 11:16 PM
woolyhorn's Avatar
Default Valair Ceramic single clutch like?
Just wondering what the Valiar full ceramic single clutch is like, because they seem popular.
Old Apr 4, 2010 | 11:24 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
seems to be pretty tough for a single
Old Apr 5, 2010 | 07:57 AM
85_305's Avatar
Being Evaluated
and pretty cheap! Screw spending 1800$, a similar valair is like not even 400$
Old Apr 5, 2010 | 09:09 AM
96blackcloud's Avatar
i had one and liked it but your not suppose to tow with it you could weld it to the flywheel, i now i have the next one up the kevlar/kevlar and love it grabs hard, not to bad for city driving with the 3800# PP used stock hydros, and i can tow with it, i dont think the its rated as high 450hp-950ftlb compared to the 500hp-1000ftlb.
Old Apr 5, 2010 | 09:17 AM
85_305's Avatar
Being Evaluated
Look at the kevlar/ceramic. Very similar power ratings as the 1800$ southbends
Old Apr 5, 2010 | 01:08 PM
woolyhorn's Avatar
So you cannot pull a trailor at all with a ceramic? How does welding the clutch together work with shifting? That sounds hard on the transmission.
Old Apr 5, 2010 | 02:19 PM
not actually welding it together, but from the ceramic not wanting to slip at all and grabbing to hard slipping it can cause a lot of damage to your flywheel to the point where it might fuse together hence kinda like welding.
Old Apr 5, 2010 | 02:30 PM
biged681985's Avatar
it all depends on how u drive, and how heavy u tow. he clutch is ment to hold power, but not slip at all. its either engaged, of not, no inbetween. if u have a 2wd lo set up in ur truck, it will make the clutch seem less grabby.
85_305, what all have u done with ur clutch to be so knowledgeable? your prices that u posted arent even close to the same clutch. the 1800 is a DD disk clutch, or someone was tryin to screw u over big time. im guessin u just dont know what u are talkin bout.
Old Apr 5, 2010 | 03:26 PM
I'm running the Full Ceramic Single in my 01 6spd. Its a very aggressive clutch. Sometimes I think about going with a Ceramic/Kevlar Single Disc but I'm going to wait and just do a Dual Disc. Last Summer I pulled a good size Pontoon to the lake and sometimes is was a pain in a a$$.
Old Apr 5, 2010 | 06:40 PM
see i was goin to stick with the ceramic/ ceramic but i couldnt find anyone that didnt heed the warning of no towing and how it felt so i swapped out for the kevlar i like it so far still grabs pretty good
