fuel pressure question? fuel filter or over flow valve?
Old Apr 6, 2010 | 05:25 PM
hereismylife's Avatar
Question fuel pressure question? fuel filter or over flow valve?
I finally got a temp gauge hooked up at the line from filter to injection pump. My pressure is around 10 psi. I pinched the return line and it goes to 60 psi so does that mean my filter is plugged or the ofv is going out?
How do you know if the filter is clogged ?
thanks
Old Apr 6, 2010 | 05:34 PM
Pinching the rubber line and having the pressure go up usually means that your lift pump is in good condition.
Could be filter - but its more likely the overflow valve.
How many miles are on the truck? When was the overflow valve changed last?
You may also want to clean your prefilter. Very easy to do, remove the bottom of the prefilter, clean and replace. Theres no realy reason to get a new filter unless yours is boogered:
Fuel Pre-Filter Cleaning on Ram/Cummins
Old Apr 6, 2010 | 05:39 PM
Question
I have no heater or pre screen if I am correct.
My line goes right to filter than to pump. I took the heater off.
I was just wondering if you can tell. I guess not.
ofv was replaced about 3 yrs ago.
Old Apr 6, 2010 | 05:47 PM
Ahh, you did not mention that previously.
Some stuff for you to read:
Ram Diesel Injector Pump Problems
And
TSB 14-07-96 Rev. A
Old Apr 6, 2010 | 05:48 PM
Filters are cheap if you havent chaged it within the last year - change it. Diesel fuel is notoriously dirty and full of water compared to other fuels.
Old Apr 6, 2010 | 06:12 PM
I got a new filter and I can change it. I just thinking there has to be a way to see which one it is without replacing it. Esp when you are on the road and it reads low....
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
