PDA
View Full Version : Diesel In Distress - Support Ticket
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13
  1. head gasket
  2. smoking and missing 92 cummins
  3. what could this be?
  4. help
  5. 7.3 4R100 tranny not shifting 3-4 until warm
  6. 1990 7.3
  7. wont idle and pours smoke
  8. Manhattan ? anyone close ?
  9. truck shuts off on hot unlock
  10. 2006 6.0L No Start
  11. 94 6.5 Chevy misfire and smoke
  12. 02 cummins leaking fluids
  13. 89 Shut down while driving - no start
  14. air in fuel?
  15. ElectricKickle problem
  16. Weak powerstroke!!!
  17. white smoke and miss
  18. couldnt fix it with a hammer .. must be electrical
  19. Help 96 7.3 fuel leak hard to start
  20. help
  21. White smoke even after warm up
  22. Help!! 2000 24v acting strange
  23. OIL COOLER END HEADERS CAPS
  24. injecter pump not pumping
  25. 94 7.3 E350 No Start
  26. 6.9 f250 85 pickup no start help
  27. Bad voltage
  28. P0087-p0540 on d-max
  29. 6.5 needs help!
  30. 12v not starting...replaced fuel lines,cleaned tank,no starting
  31. anyone ever rebuilt a power steering box
  32. Hard Shifting 48re
  33. Broke The Fitting To The Transmission to Cooler Line
  34. need help with throttle cable bracket on 47re
  35. Injection Pump Solenoid???
  36. Injector Pump Diaphram
  37. 911 need help asap!
  38. '92 Dodge Cummins with no charge from the alternator
  39. 93 7.3 no start w/out starting fluid
  40. Dual Battery Terminal Rreplacement
  41. FORD VAN WONT START
  42. HELP!!! 06 Seized on I-95 at FL/GA Border
  43. 12 valve not start
  44. Truck stuck in limp mode no matter what I do!!!!!
  45. Old Man's stuck on a haul in FL in the 06...
  46. 05 Cummins turbo noise
  47. 02 dodge trouble
  48. 96 powerstroke rough running
  49. 01 cummins not starting
  50. 98 47re stuck in gear
  51. black smoke
  52. Strange Code
  53. Possible cause for Cummins locked engine
  54. torque convertor lock up solenoid
  55. lock up problems
  56. Water in fuel light on
  57. overdrive....
  58. 12Valve breakdown
  59. 01 dodge intercooler boot
  60. turbo help
  61. Blue smoke while engine is cold, no smoke going down the road.
  62. Neighbors are complaining about smoke.
  63. trouble codes
  64. 2006 Dodge Cummins CR w/ code P2146
  65. 99 4x4 cummins auto tranny issues
  66. O6 2500 Ram No A/C
  67. CUMMINS TROUBLE!
  68. dodge truck trans problem
  69. 99 7.3 shuts down when cold
  70. Need rear driveshaft
  71. Tie Rrod End?
  72. 95 f350 glow plugs????
  73. 2000 f250 will not start
  74. 2007 6.7 a/c issue???
  75. not sure what is going on
  76. 01 Duramax w/ low Oil pressure
  77. vp problem or something else?
  78. 7.3 problems currentley in the big house
  79. 12 valve cummins transmission problem (HELP)
  80. 03 dodge hard to start and surging
  81. Fuse blowing
  82. clutch trans problem!?
  83. Throttle sticking Help!
  84. stalling 1999 f350
  85. Cummins 48RE Problem with 1st gear
  86. Bad Vibration..
  87. 6.2 gmc dies under boost
  88. 93 6.5 wont start!
  89. MBRP Exhaust 97' F350 Problem!
  90. help help help!!!!
  91. Truck wont start / low voltage / WTF
  92. Billowing white smoke then stops
  93. No oil pressure
  94. Wastegate - Sucking air - 99 7.3 PS
  95. tranny electrical probs.
  96. 6.5 issue, not a problem yet...
  97. O/D Blows engine fuse
  98. 07 5.9 Cummins Cutting Out
  99. powerstroke in need of help
  100. no OD or lockup cummins
  101. 1996 e350 wont start
  102. '01 Dodge Diesel transmission will not shift into OD...Please help!!
  103. powerstroke ipr location
  104. tour bus 99 e-350 7.3 need one part
  105. white smoke again
  106. 2003 ford 6.0 no power ?
  107. 6.5 problems again
  108. 24 valve problem
  109. Leaking coolant 2001 Cummins
  110. Powerstroke - wont start
  111. hesitation/ stumble
  112. power steering pump fittings and plugs
  113. bad vibration between 1500 to 18000 rpms
  114. Perfromance trans won't shift at WOT
  115. '01 Cummins keeps dying
  116. brakes???????????????
  117. Help Please Exhaust Full
  118. 1995 Cummins Hard Start
  119. 99 F250 Starting Hard Getting Worse
  120. knocking
  121. still no go
  122. 1996 6.5L keeps dieing.
  123. 6.9 international wont start
  124. won't run
  125. gear oil leak
  126. 7.3 shut down while driving and will not start
  127. 2004 ford powerstroke 6.0 p2262
  128. 7.3 won't run when cold
  129. 1990 Dodge won't start, no crank
  130. lining up input shaft with pilot bearing
  131. antifreeze pouring out of reservoir
  132. Shop says need injectors
  133. Truck won't start?
  134. 06 dodge fuel rail problem
  135. 2001 dodge 5.9 tranny fluid everywhere
  136. 12v no start
  137. no fuel from injector pump
  138. 6.5 TURBO WILL NOT START HELP
  139. 03 cummins running rough.
  140. 93 7.3 changed fuel filter still wont crank
  141. 2000 Dodge Cummins Fuel Guage
  142. white smoke?
  143. wiring
  144. 2002 7.3l wont start NEED HELP!!!
  145. Need your expertise! 5.9 Cummins won't start
  146. 03 Duramax. Lost prime? bad IP? won't run
  147. 7.3 with a little white smoke at idle
  148. 04 ford 6 liter trouble
  149. 7.3 idi wont crank please help
  150. ticking noise after injector install
  151. 2007 Cummins Problem - Help
  152. Removing front brake calipers: PITA
  153. Changed Oil Wont Crank
  154. 2004 Ford F350 PowerStroke changed oil and fuel filters and wont cold start
  155. maybe turbo? maybe wastegate
  156. 94 # 6 not firing
  157. Case 580d fuel leaking from exhaust
  158. 03 Cummins - cold start problem- gone worse ..update
  159. 95 12v starting issues
  160. no start dewy morning, eaasy start warm afternoon
  161. Tachometer that stops and starts
  162. codes..truck is sick help
  163. 7.3 Won't start...
  164. WTFreak!
  165. Need Help my truck is crippled!!!
  166. Ecm codes and heavy surging
  167. i need help bad
  168. 99 dodge cummins
  169. Code P0341-sensor not in block--01 cummins
  170. Stranded in NV
  171. 99 ford f250 cranks hard
  172. 03 dodge tranny issues
  173. 2003 48RE slip in between 1-2 upshift
  174. '05 Dodge in Jackson MS, P0111, runs rough
  175. WON'T START
  176. abs brake light with soft pedal
  177. 2000 Dodge won't start
  178. tv cable
  179. trucks stalls while driving
  180. Need help with brakes
  181. HELP 99 Ram Stuck on the side of the freeway.
  182. 1997 12 valve cummins electrical issues
  183. IDIOT NEEDS HELP...READ ON>>>
  184. white smoke at high RPMs
  185. Won't start after deleting EGR
  186. *HELP* 6.0 will turnover, no start
  187. Starter Sticking!
  188. newby needs help
  189. Ram/Cummins intermitant starting problem
  190. 95 6.5 TD about to give heart attack
  191. LB7 Duramax CP3 Mod
  192. Sudden Oil Leak
  193. need help
  194. Once again problems with new motor!!!
  195. 92 dodge D350 schematic
  196. HARD STARTING
  197. HELP Please! 12V won't start
  198. Clutch
  199. 475 isx problem
  200. lost 4th gear
  201. 6.2 injection pump
  202. 03 5.9 code poo88
  203. 03 5.9 injector install
  204. 03 cummins sounds like b series,power of a pinto
  205. I hate wires... help, please.
  206. 6.7 smoking
  207. 2003 F350 7.3 stalls
  208. 2003 CR - Having Starting Issues
  209. Tow mirrors.. electrical problem
  210. 7.3 Powerstroke wont start after sitting 12hrs or more, any help for me?
  211. '07 Chevy Classic Duramax, Limp home mode?
  212. Leaf spring or shock problems...
  213. airdog install now fuel gauge isnt readiing right
  214. bully dog help!
  215. 95' 12 valve cummins
  216. Oil Pressure
  217. 6.5 turbo diesel transfer case
  218. 1993 Silverado 6.5 turbo starting issues
  219. wierd problem with a D-Max
  220. smoke effect
  221. Truck Died--No fuel to injectors
  222. 6.0 exhaust leak at Y pipe going to turbo
  223. 99 cummins overspeed
  224. AC only on drivers side???
  225. 03 Dodge CR
  226. Loud Whistling Noise
  227. Shift points
  228. Desperate in need, 02 Dodge 5.9, 6 spd.
  229. List of codes after EGR blocker
  230. 01 cummins cam sensor
  231. 99 Ford F350 7.3 Scan code problem
  232. Dodge Down in N.Dakota
  233. 1987 6.9 ford overheating??
  234. 06 tdi jetta no start
  235. can't figure it out...
  236. 02 dodge steering problems
  237. Runaway FORD!
  238. Update new motor but got questions?
  239. Brakes and Steering in cahoots together.
  240. How to remove the egr cooler
  241. Lift pump problem or something else?
  242. Nissan Patrol GR 2.8 TD trouble
  243. 6.5 Will Not Turn Over
  244. HELP - Going Out of Town
  245. 96 powerstroke
  246. charging issue
  247. 03 Cummins will crank but no start..HELP!!!
  248. Warmed Up, Died, Won't Start Again
  249. update on truck is dead
  250. 2001 Cummins 5.9 falls on its face
