- Need A Good Mechanic
- Trans Locking & Unlocking
- Help Codes
- Check Engine Light / MAP Sensor Unplugged
- P0299 Turbocharger Underboost DTC
- Good News/Bad News
- HELP, HAVING PROBLEMS AND HAVE NOT EVEN MADE THE FIRST PAYMENT
- Replaced Brakes, Got Issues, Help Please
- Fass Owners I Need Advice.
- Major Problems?
- HELP!!!
- W115 Mercedes 300D: Mystery Knob
- ABS And Brake Light On
- Need Help With 1993 7.3 Ford International Motor
- No Dash Lights/Melted Wires 01 Dodge Cummins
- 6.7 Help!!!!
- ABS/Brake Light Are Stuck On
- Pyro
- 2004 Common Rail Help!!!!Could Use Some Really Good Ideas And Help Here????? Stumped
- Help With Batt Light
- Fuel In Rad
- 94 Front Axle Question
- Steering Box Leaking And Steering Slop
- A/C
- Powerstroke Fuel Leak
- Axle
- 2002 Cummins Dodge Mileage Issue
- Stupid Heating Controls
- Oil Pressure Drops 98 12V
- Batteries Keep Dying
- Fuel Pressure Regulator????????
- F-350 Won't Start
- Catalyst Filling Up All The Time?
- Driveline
- 07 Duramax Help
- Cat C7 ----- No Fuel!
- 12v No Start
- A Little Duramax Help Please!
- Help!!! Guys My Son's Truck Died Here..
- Tranny Problems
- Fuel Filter
- 98 Dodge 12V Fuel Leak
- Hard To Start
- 2007 Duramax Smokin
- Temp Gauge?
- Ate 2 Starters In My 83 GMC /6.2
- How Do I Get Rid Of White Smoke?
- HELP!! Boost Gauge on LBZ
- Lacks The Power It Used To Have
- 1999 Chevrolet 3500 6.5L Auto. Running Rough And Smoking
- Losing Throttle 01 Dodge
- VE Pump Won't Idle.
- Lack Of Power
- Story Of A Dip That Bought A Truck Online
- Leveling Kit Issues
- Duramax Tranny Help
- Fuel Pump
- 2003 Ford F350 HD
- INJECTOR HELP
- Transmission Issues
- Chirpping From The Rear
- Check Engine Light And Throwing 2 Codes
- priming 6.2L
- 93 7.3L non turbo won't play
- Faulty Trailer Lights
- Duramax Loses Power
- 01 dodge died
- 7.3 Econoline Van No Power
- Dead In The Street....
- Starting Problem
- No Brakes
- 48RE Code P0868
- "Starting Problem" 1984 GM 6.2L "Running Buffalo".... Sits!
- Cranks But Won't Fire
- Need Help Bad
- Trouble Starting
- 24V Hard Start But Runs Perfect - Please Help
- Transmission Problems, Any Ideas???
- Need Some Help With Some Banks Stuff FAST!!!
- 6.9L Issues
- HELP! TRUCK DIED
- Tach Not Working And Rough Idle
- Center Console Wont Fold Down- Need Help
- Need ECM!!
- Code PO237
- 12V Lift Pumps? Please Help
- Truck Cranks But Won't Start
- Urgent Diesel In Distress!!!
- 1999 Cummins Leaking Fuel
- 6BT Engine Problems
- My Buddies 04.5 Cummins
- Help
- New Here Need Help......Drivers Rear Brake Locked Up
- Lost Speedo, Tach, Alternator (Charging) WTS Light, & Fuel Shutoff Solenoid!
- Help
- I Hope Someone Has An Idea Here ! Help
- Duramax Idle Problems
- DMAX Blowing Off Intercooler Lines
- Need Help 06 Dodge Acting Up!!!
- Brake Lights Will Not Go Off.
- 1995 7.3L Won't Run Right.
- Need Rear Driveline For 2006 F-350 CC L.Box!!!
- Cable Connectors - Chev 6.5
- Still Stuck Need Help
- Code P0720
- Help!!!
- Need Motor For 95 Chevy K2500 P/U
- Oil In Tailpipe
- VE Pump Fuel Line
- 01 4wd Blowin' Fuses
- ORANGEBURG SOUTH CAROLINA
- NEED SERIOUS HELP
- 2007 Dodge Cummins, No Rail Pressure While Cranking, Not Starting
- 1999 Ford F350 Will Not Start
- Truck Just Died And Won't Start P1689
- Apps Going Out?
- Band Adjustments
- ABS Lights And No Speedo
- HELP!!!!
- Battery Gauge/Voltage Question
- Trailer Light Issue
- DIESEL BOMBERS Support List GET HELP NOW !!
- No Power!!!! Running On Four Cylinders
- BLOWS BIG CLOUD OF BLUE SMOKE AT IDOL
- Cruise Control Not Working
- Serpentine Belt
- EGT Question... Possible Problem?
- 2003 Cummins No Start
- I Hope Some One Can Help??????
- Vacuum Pump
- VE Injection Pump
- Redline Issues
- Loud Blowing Noise
- Run Away??
- Low Boost Issues
- 02 Comp Install
- Wil The Stock Air Box From An 05 Work On A 06?
- Thats what I get for being in a hurry
- ABS & Brake Light
- 2001 Duramax Battery Problems
- Rough 12 Valve
- Air Conditioner Compressor Problems
- Gauge Help
- Shim for starter?
- Need Help ASAP!! Please Read
- HELP GOT A 12VALVE THAT WON'T START
- HELP!! Need to prime a "gas station-style" pump
- Noise from motor into turbo
- cam position sensor code / no go
- If the VP goes out, will a code pop up?
- Diesel prices in Canada
- MAP And IAT Sensor Question
- DV socket
- 99 CTD Blue Smoke, Loss of Power
- KW won't start
- brakes
- Need Help
- What size are down pipe bolts for a hx35
- 2001 ctd holly blue psi issues
- Need help fast on ball joint/hub removal
- turbo id Questions
- Tranny Temp and O/D Off lights are on!!!
- Transfer PUMP Gone
- Need help for 99 Dodge Diesel truck pleez
- fuel filter change
- Blower motor?
- Got oil pressure issues
- carrier bearing gone
- Need some pump advice.
- Detroit 12.7 litre 430 hp shuts down and will not refire.
- New to diesels and need help
