PDA
View Full Version : Diesel In Distress - Support Ticket
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13
  1. 97 psd lots of codes
  2. I need an engine serial number
  3. dump bed kit removal
  4. Need advice-DPF
  5. idle high
  6. what causes turbos to have oil all over the place
  7. 97 ram 3500 parking brake tensioner?
  8. 2000 6.5 turbo runs some and then won't start
  9. egt's went up after installing bd twin turbo's
  10. 94' f250w/ 7.3 idi n/a tps screws
  11. 6.9 hard starts and white smoke
  12. 98 6.5l runs then stalls
  13. 06 CTD Suddenly died while driving, now won't start
  14. just installed airdog 150 and truck has no power
  15. dodge power steering w/ 6815
  16. 83 6.2l stopped running
  17. 97 ford f350 crank but no start.
  18. 1993 k3500 6.5 td cranks but won't start
  19. 04 dodge 3500 wont start unless its plugged in
  20. 2004 E350 6.0 NO ICP PRESSURE
  21. 2004 Dodge 3500 tranny problems?
  22. Random black smoke
  23. code p0234 and p1690
  24. 98 dodge ram 24v loss of power
  25. No Reverse
  26. rpm,s jumping up and down
  27. At a loss... Losing fuel
  28. ford 6.0 help lots of smoke
  29. 6.5 shuts down, time to upgrade parts?
  30. 97 5.9
  31. 2008 dodge 2500 shifting problem
  32. cummins fuuel priming. isues
  33. ford 6.0 problems
  34. help
  35. Injector stuck!!
  36. 07 6.0 235k miles repairs gone wrong
  37. Fuse blow on AIRDOG 150
  38. 98.5 24v 4x4 brake issue
  39. 1995 to 2000 motorswap-loss of power
  40. Hot to bleed clutch slave cylinder? '88 7.3
  41. 06 Dodge 3500 5.9 Trans. (auto) wont drop into gear...
  42. F250 with a no start
  43. Fuel Problems on Mazda B2500
  44. The Dirty LB7 strikes again
  45. noisey motor
  46. PMD Bad???
  47. New to cummins fuel problem
  48. Fuel Problems
  49. transmission help
  50. Transmission help, please..?
  51. Anyone have any idea what this is for?
  52. 1994 cummins dies....
  53. 96 12v cummins
  54. 2006 F350 6.0
  55. Snapped a bolt on exhaust manifold
  56. hard starting
  57. 94 6.5L Slow crank
  58. Replaced O rings...now won't start!
  59. 95 chevy
  60. ECM/PCM Rebuilt
  61. code 336
  62. Cummins ISM Camshaft removal/installation
  63. 95 Dodge Downshifting
  64. 1999 F350 Computer ?
  65. Map sensor voltage low
  66. Need Help!!! A.S.A.P.
  67. 4 wheel srice problem
  68. 2007 Dodge Ram 2500 P0868 trouble code
  69. 2003 Duramax fuel problems
  70. White smoke and missing
  71. Dropped something in tranny!
  72. 2003 dodge cummings looses power
  73. 47RE Problems
  74. 2006 mega cab 4x4
  75. 2006 mega cab 4x4
  76. '01 F250 4x4 problems
  77. 1999 7.3 not getting fuel
  78. 1994 6.5l pouring oil!!!
  79. 47rh not down shifting
  80. 1997 Dodge Ram 2500 5.9 turbo diesel has power lost
  81. 911 Help 95 powerstroke wont stay running
  82. 04-dodge 3500
  83. Any suggestions much appreciated
  84. '03 Cummins 5.9 will NOT START when HOT
  85. 01 lb7 wont start
  86. 1989 GMC 6.2 Service Fuel Filter Light
  87. help 6.5 wont run
  88. truck won't start
  89. Questions on a 99 Dodge 24 valve
  90. 5R110 tranny with water in trans fluid-'08 f350
  91. cummins won't shift won't charge and tach don't work.
  92. 7.3 no start
  93. Trans Slipping During Second Gear Shift
  94. fuel problem maybe?
  95. cummins white smoke and miss
  96. 2003 6.0 Super Duty shutting down when brake applied or warm
  97. No fuel, 7.3 idi
  98. 05 DT466 HPOP?
  99. tranny wont go into gear
  100. what to buy
  101. quick Help SPLINE NV5600
  102. 99 cummins with delayed wait to start light
  103. leaking steering fluid? and making whining noise help
  104. 5.9 clutch
  105. 12 valve running rough
  106. mercedes intermittent dash light problem
  107. 96 oil leak.
  108. Steering Wheel/ Key both LOCKED
  109. NEED HELP!!
  110. HELP
  111. 07 5.9 Cummins stalling/long crank
  112. Clutch / transmission issues.
  113. Oil leak
  114. vaccum pump
  115. 95 dodge 12v white smoke breaks up
  116. fuel pressure needle valve set-up
  117. replaced my vp44 and now it threw a p1688 code, Truck died on me!!!
  118. 01 cummins shorted vp44 wires
  119. 6.2 No Fuel At Injectors
  120. 05 Duramax LLY Tuner?
  121. a case of the shimmy's
  122. fuel filter lossens
  123. Oil leaking into coolant??
  124. ctd oil leak
  125. 1991 cummins question?
  126. Clicking under hood 1986 6.9 won't start
  127. Help w/2003 Dodge 2500
  128. Fuel delivery issues
  129. Stuck Again !
  130. erratic shifting
  131. 24v pcm and ecm not connecting with scan tool
  132. 04/gmc c6500 w/duramax oil in cooling system
  133. Help. Windows won't roll up
  134. 2001 cummins high idle miss
  135. 1984 F250 6.9 just replaced vacuum pump now won't start--clicks!
  136. 99 powerstroke sounds like miss
  137. 04 cummins will not start (help)
  138. PLEASE help!! hard to start, and extremely sluggish behavior
  139. Fuel in Coolant, Injector questions
  140. Code P2284???
  141. P 1690 code missing and white smoke!!!!
  142. 1993 cummins temp problem
  143. Push rod trouble
  144. gas in my diesel
  145. need help
  146. 05 Liberty TRD that bucks at 2500 RPM
  147. ISB 6.7 low power, engine protect light on
  148. Getrag to a NV 4500 swap
  149. 2001 cummins 47re transmission problems
  150. '08 6.7 cummins turbo issues??
  151. Truck starts but immediately quits running..HELP!
  152. Bad FICM
  153. no power, no codes ,no clue!!!!
  154. lookin at 97 12vl but loping all the time at idle even whn warm
  155. 2003 Duramax Multiple Issues Smoke/Low Coolant/Hard Start
  156. cummins oil leak left side of block
  157. 1997 dodge cummins bad rearend
  158. Intermittently Dies
  159. 95 F250 Oil cooler rear header
  160. Stumbles only when warmed up
  161. F350 Ford 2004 FICM readings...
  162. 03 24v Cummins Dies Out
  163. 02 Powerstroke front brakes not releasing
  164. 96 Dodge 5.9 Will NOT start been sitting????
  165. 7.3 powerstroke keeps dieing
  166. 1991 ford f-600 transaxle swap
  167. Need to have truck up and running asap
  168. 12 valve will not lite
  169. 98 5.9L 12v Cummins converter lockup problem
  170. 4wd not engaging in my 2007 dodge 2500 6.7
  171. 99 cummins wont shift into od
  172. cummins broke down
  173. 05 dmax rearend broke
  174. NEED SOME HELP ON A 2007 5.9 CUMMINS
  175. 6.5 Missing cold... Need help...
  176. 7.3 not starting, need some advice
  177. oil pressure
  178. 96 Dodge 12 valve Wont Start
  179. tach/trans issue
  180. 88 7.3 idi NA no start or turnover
  181. Fuel relay Cummins?
  182. 03 Ford e350 7.3L PS Power Loss, Rough Idle
  183. lb7 dmax no start after new injectors
  184. 12 valve fuel pressure question
  185. transmission problem plz help 48re
  186. 97 Powerstroke white smoke, no power
  187. 2003 Ford E350 7.3 dies going up hills
  188. 1993 idi n/a throttle cutting out repeatedly when wide open... HELP!
  189. newbie letting you guys know my oil leak is fixed
  190. No black smoke??
  191. OIL LEAK in My f350!!
  192. 98.5 cummins
  193. Another 7.3 Wont Start Thread.
  194. Are ZF 5 speeds all the same?
  195. 96 powerstroke
  196. Turbo oil return line
  197. Coolant for VGT?
  198. What the heck
  199. help
  200. 01 24v cummins need help
  201. Overnight nigtmare
  202. Died while gettin on highway
  203. 12v in 1990 f350 issue
  204. 1995 Dodge 5.9 Cummins Loss of Power
  205. OBD2 Cummins 04 common rail problems
  206. 96 pump issue
  207. 04 lb7 dmax balance rates western ma
  208. 2000 7.3 glow plug issue
  209. 5.9 12v cummins with a mind of its own
  210. 99 f250 no low end power
  211. Transmission 01 dodge
  212. 07 5.9 Wobble when wheel left of center.
  213. 1993 Chevy 6.5 starving for fuel
  214. 01 CTD 6 spd wont move!!
  215. Alarm on my instrument panel
  216. brake issues
  217. 95 12 valve no low end power!!
  218. Duramax starts funny
  219. 2nd Gen 5.9L Cummins Knock at Idle
  220. Smoking, NOT the good kind!
  221. 97 7.3 will not start
  222. Need to find someone to rebuild lift pump on '88 7.3 IDI
  223. 04.5 Cummins issue's need help!
  224. cummins actin weird
  225. 4BT hard start issue revisited
  226. 97 f250 running ruf help
  227. 99 cummins turns over to slow to start
  228. 2005 F250 6.0 EGR and oil cooler issues
  229. Water in fuel light.
  230. 2008 Ford F550 6.4 wrecker, no start!
  231. My truck is acting up again!! Plz help need ideas soon!
  232. 98 dodge sercurity gone insane
  233. New guys, please read here before posting tech questions...
  234. 90 cummins.... heater/ac fan stuck on low...
  235. 2004 F550 goin down!
  236. 2002 7.3 litre rough idle/no power
  237. egt's WAY TO HOT
  238. Ghost in wiring?
  239. PTO wont engage
  240. Can't get pressure behind schrader valve after fuel filter change on 6.9
  241. Now the block heater's out....
  242. 7.3 littter wont start
  243. '06 Hummer H1 alpha, lly, stalling issues
  244. engine extremly loud at idle?
  245. 2001 dodge cummins
  246. New transmisson has a problem?
  247. 01 Cummins random cutout on boost
  248. cummins smokes blue
  249. Ford 6.4 Wont Start
  250. Fuel Leak 12v
