- Losing High end power-any thoughts?
- Front axle seal leak?
- engine stays running
- injector line cracked !!!!!!
- torque converter help is there a way to test it?
- 95 12valve braking problem
- 04,5 auto feels like itsliping on incline at start
- alt, and tach problem on 01 with 12 valve
- HELP with driveshaft
- 02 2500 cummins starting problems
- '92 Ford F-350 7.3L IDI - running issues
- '01 Cummins boost bolt broke off in manifold
- Goerend Trans shot???
- starting problems...
- 2001 cummins turbo upgrade ?
- first gen power steering.
- 96 PSD Died and won't run
- EGT sensor cause EGR Cooler to go bad?
- 100 and ac acting up
- non-running 93 2x4 CTD transporte
- crappy MPG out of my 6.0l
- temp gauge acting up
- freeze plug install 96 CTD
- Try Again, Intermittent Start
- 100 and A/C quit
- oil pan gasket leak
- fuel problem (im guessing) on my 96 powerstroke
- help me choose what to do
- 94 cummins 5.9 starting problems
- 24v cummins raptor install problem
- dana 70 ring and pionon install
- Duramax 14 bolt breather nipple broke off unleading
- guage cluster light
- Engine is way to loud, gas pedal timing is off
- Dealer said my injectors are bad
- charging and shifting problem
- HELP on my stock 1997 powerstroke
- possibly low power issue
- fuel presure gage with air dog pump
- 07 dodge clutch problems
- 89 Ford 7.3 Cold Start problems other threads do not cover
- 92 Cummins DIED, Shut Down. HELP!
- 5.9 Cummins
- Duramax not Driving
- '96 7.3L PowerStroke Started Missing, Died, and Now Won't Start
- 92 6.5 lost 5th gear (nv4500)
- injector pump removal
- My Truck wont stay Running
- F 250 6.0
- knocking noise??
- 01 7.3 doesn't start
- New LP+Pusher Pump...P01689
- 93 Cummins having some issues
- john deere 7820
- 1993 chevy with the 6.5
- Turbo compressor housing leak
- not a diesel but help with my wifes van please!
- 12V shutdown clicking noise from engine
- Busted Line
- Air Dog - changed filter - losing pressure in return line to tank
- Testing HPOP on 06 6.0L and hear bubbling in bottom of motor
- 7.3 wont run in the mornings
- Exhaust filter 100% full-need help please
- Question on Trans removal
- hellpp
- 98.5 transmission jumping in and out of od
- Knocking noise????
- 7.3L HPOP oring leaking bad
- Idle problem
- Steering wheel jerking back and forth when turning
- getrag in ford clutch issue
- Locked Up????
- trying to replace dash and not fitting
- urgent help please.
- Help P0335 on 6.5 L
- how to clear codes
- 2003 LB7 - need Exorcism (or CAN BUS guru)
- stuck in 3rd???
- Wheel hop
- batteries dead
- 5.9 running rough after warm up
- 04' 5.9 Cutting out
- cruise controll
- oil driping
- 2004 Powerstroke acting up
- map sensor bad?
- Help Please! Rough/Choppy idle & loss of power
- Fuel filter, 2010 Cummins 6.7
- 2002 Duramax in trouble!
- 2005 5.9 common rail, rebuilt motor and no start
- 06 cummins fan clutch wiring ripped out
- LLY died
- 2001 durmax 6.6 head gasket help!
- After warranty help
- AC Fluid line replacement
- Stalled a few times idling, twice while driving, now it won't start
- 2006 2500 Power Washed Now Won't Start
- Tranny problems
- Injector replacement or tips?
- help. stuck on I15 north east of LasVegas
- 2k 7.3 229mi
- 03 dodge wont start please help
- what is this????
- Possible Blown Head Gasket Coolant out of Exhaust Modified 04 6.0
- 97 5.9l cummins
- 02 dodge 1500.
- 04 duramax 6.6L running rough
- 6.9 died
- Lift pump, Injector pump or something else??
- 2007 6.7L cummins
- p0087
- Very hard to start, and when it does, funny, wanna die idle, and...
- problem with rear end brakes
- 07 Duramax codes
- 2004 dodge cummins boost?
- 2001 Dodge 3500 5.9L turbo
- 1997 Dodge 5.9 Cummins
- 1999 dodge 4x4 brake issues
- checked code anyone know what this code means
- 05 Cummins no throttle
- Going Limp
- my cummins won't start hot!!! I need to fix it!!!!!!!!!!!!
- 02 Ram Cummins very loud squeaky belt!!
- wont start 04 ram 2500 diesel fuel filter, batteries, and vacuum line worked on
- Ford 6.0 no oil pressure!!!!!
- 03 Excursion starts and runs but stalls if you drive it like out of fuel
- Excessive Fuel Leak 12v
- 2001 Ford 650 5.9 diesel No start
- 1990 f-350 IDI -wont start
- 99 ford f250 powerstroke
- Odd, fuel no start problem
- 2003 cummins stalling when a load is applied
- Clutch
- Help No Idea what has happened!!!!!
- cruise control problem
- 98 K3500 transfer case wiring harness.
- 2005 F350 superduty overheating bad
- warm starting problem
- 1993 F250 won't start
- dtc code 01 cummins
- duramax starter NEED HELP
- 02 duramax, crank but no start.
- removing fuel lines on 2002 d max
- 1996 GMC 2500 6.5 tubo diesel shutting off
- clutch issue
- Replaced head gasket, Now weird squeel
- 2002 dodge no start
- HELP QUICK PLEASE
- Mis-fire!
- Batteries dead as hammers
- Motor/Tranny acting up. at work need help fast
- broke crank sensor off in block ... now what
- Fuel Filter's
- '95 F350 Powerstroke
- 2001 6.6 duramax
- 92 CUMMINS wont shift into OD with wait to start light is on
- no run F-350
- gauge help
- Annoying & unneeded warm up valve
- 2003 Dodge 5.9 keeps spitting out fan belts Help...
- Ts 6 position chip problem
- truck overheated now it wont run.
- GETRAG PROBLEMS
- help- ve pump problems
- 7.3 Turbo won't work
- 2003 Cummins cutting out
- truck wont start. please help!!!
- 05 1/2 cummins with hole in block
- 1996 c3500 code problems
- 2002 24valve needs help
- 1996 c3500 electrical problems
- need help with 47re
- lift pump not running
- heater core
- loosing compression??
- Leaking fuel supply line, Crazy oil pressure Reading
- Shaky 6.5 Chevy!
- 2nd gen tps sensor
- Fuel Leak
- Is it the transmission or torque converter
- 1994 Cummins no Boost
- Installing engine
- he341 spins hard
- 01 Dodge cuttin out
- 2nd Gen Down
- gen 3 cummins p2121????
- Duramax heads
- NEED HELP ASAP
- replacing a gasket
- problem with idle on 12v cummins
- starving for fuel?
- lift pump issues?
- AC Problems
- help
- I5 WA state diesel repair shop
- 2007 Classic Duramax starting issues
- 1995 Powerstroke No start no fuel pressure at shrade
- 48RE rebuilt trans problems, please help asap
- need help on 01 cummins
- 2001 Duramax LBZ Continued Idle Smoke
- Loss of power
- Sputter cough die
- 03 lb7 Misfire and black smoke
- pump problems
- Just died. Now won't start.
- white smoke
- Cummins wont turnover.
- Please guys, I need help right away!
- My truck died after I put the pedal to the floor
- 07 duramax idle problem
- 03 LB7 TCM/ECM/shift issue
- rod ring on piston
- KNOCKING
- knock
- 2000 F-250 Dies
- Truck isn't running over 40 MPH - please advise
- hurt 91 f350
- Dodge Tranny Problems?????
- Friend having issues in Victoria BC
- o1 cummins hard to start
- Cummins fuel in oil......
- 95 cummins (surging)
- 06 Dodge 2500 All tore apart Hub is stuck!!!
- oil pressure went goofy
- air bag light 1995 chevy
- 7.3L going goofy
- Sounds like a HUEY
- cummins surging
- lost power to ODBii port on 06 duramax
- WILL NOT KEEP RUNNING ?
- Oil and Water Sending Units
- 99 f350 7.3 no oil pressure
- 95 Powerstroke just chugs
- Ford 6.0 Tranny
- 01 ram fuelsender problems
- 01 powerstroke head gasket.
- need an np205 guru..
- 7.3 won't start when hot
- 92 chevy 6.5 turbo
- No pressure
- !998 diesel 6.5 stalling
- transmission problem
- 6.5 turbo dies will restart but will die again
- what tha $&%!
- Some help for a friends truck
- Low power, and possibly transmission problem
- 02 Dodge power issue
- '97 Dodge truck just shuts down and stops!????
- OD, Speedometer, and some other stuff
