- tranny problems
- Fuel Plate Question
- Lock Up??
- ahhh crap
- stock speaker size?
- Ohio Craig's List Ad
- Steering shaft
- Pre filter O-ring
- 97 fuel filter leak?
- how much would it be?
- 2 different axle splines?
- Fuel Plates
- BD boost elbow..
- where is my boost going?
- stock tranni
- Bread Truck 12v
- Redline MT-90
- hard to put in gear....squeeking
- rocker arm
- valve cover plate
- timing
- Anyone know how to remove the trans cooler line check balls?
- New goodies
- Torque converter cooler
- 191 delivery valves?
- ford cummins swap
- what web site to get a stack
- anybody try this? prolly dumb thing to do
- tranny cooler... fuel tank
- compressor wheel?
- more take off power?
- does anyone know how to block off an EGR!!!
- highest idle
- some questions for you
- front axle u joints?!
- new to me can you tell ?
- dyno
- breakin
- AFC screw setting..
- Sway bar issues..
- 16X8 factory aluminums
- new truck
- exhaust
- front coil springs
- kdp fix
- all gauges the same?
- who makes a nice steering box
- 2003 dodge wheels on 97 dodge
- Sending Unit
- stock injectors?
- Electrical Problem
- pump question
- lost power when towing
- 44lbs of boost
- Favorite mods
- SuperB and Stock Exhaust
- injector QUESTION
- Ball Joints??
- a good diesel shop
- EGR??
- pullin toy hauler
- changin to a 1 ton
- Replacing the seal between the vacuum and steering pump
- home made stack
- runnin two stroke oil?
- ats commander lock up contrller
- MBRP Exhaust
- timeing should be?
- exhuast
- Killer Dowel Pin?
- any advice would help PLEASE!!!
- New Turbo
- a couple of questions
- i need help with installing injectors
- extra fuel tank
- injector sizes?
- a shift kit
- carrier bearing in long dodge drive shaft
- For More Information About Your Truck
- small mods
- stupid front end
- do i need a KDP kit?
- truck frame
- new injectors NEED MORE AIR...conical filter??etc
- need a new one
- I have fuel problems
- more fuel hard on pump?
- preventing a problem before it happens
- trip odometer
- South Bend Clutch
- NEW INJECTORS install,NO START
- any one have a.....
- trailer brakes?
- Clutch Replacement Options
- 12 valve rebuild ???
- installing injectors TOOLS NEEDED?
- star wheel
- valve size
- auto price vs. manual
- boost hits a wall.
- new guy
- miss and smoke
- blue smoke over 2000 rpm?
- headgasket failure
- Transmission
- another piping question
- intercooler piping size
- Propane Injection
- steering
- makin it pretty under the hood
- 5 speed input shaft
- boost question
- hard shifting after fuel plate
- wont start after plate
- Headliner
- Oil in the coolant? Oil Cooler/Head gasket?
- which way to slide fuel plate
- where to get some cheap gauges?
- fuel cutoff relay:how to check
- Injection Pump
- future bombs
- Gov.Spring Kit.
- who has cut their intake plenum off and done a port/polish job themself?
- Single wheel to a dually
- topper or bed cover for more MPG's?
- Turbo Silence Ring?
- 2003 V10 47re in a 1998 12-valve?
- exhaust gas temp
- intercooler boots
- Electrical issue
- The star wheel
- help asap!
- switchin tranny from auto
- tranni valve body
- pop testing injectors
- Diesel drag racing on Pinks all out.
- anybody have one?
- vacuum gauge???
- helppp
- Dumb question maybe?
- What turbo to use?
- White Smoke
- Do Injectors go Bad?
- only 80
- fuel plate ?
- 12v to 24v block
- any one from arizona?
- Waste Gate Adjustment
- TRUCK PULLING HOW TO'S??
- #10 Plate compared to #5
- Lots of blue white smoke.
- Bout to tackle the head gasket on my 97 12 valve
- HOME MADE INTAKE MANIFOLD
- 94 auto cummins
- installing gauges
- Blown Head Gaskets
- Rear end gears?
- HOOKIN CHAINS
- Weird clicking sound?
- Fuel Sender Repair
- SLED PULLIN GEAR
- what would cause this????
- overdrive problems??
- Annoying transfer case shifter noise
- rack plug
- 6sp
- 94 cummins how much horsepower
- How fast should it go
- Leveling kit from KORE
- plugging wastgate
- HELP
- Transfer case parts
- will tires hold,not load rated
- fleetguard filter number
- 3rd gen mirrors
- help on tranny
- WHEEL SIZE?
- FUEL MILAGE?????
- creeking from the front end
- how much power
- 04 cummins vs 96'
- back flushing coolant
- tool to remove injecectors?
- HELP!!!!!!!!!!!!
- fuel tanks strap
- tranny temp. or fuel pressure?
- short bed frame
- Waste Gate Question
- throttle
- removing fuel plate
- dodge ram keyless entry
- Why?
- turbo spool
- 1995 ram 2500 2wd ctd
- afc housing star wheel won't turn
- Need Suggestions on NV4500
- 1st steps to a fast diesel???
- want to buy a dodge?
- wierd problem starting, NEED ADVICE
- Fuel Gauge Not Working
- timing
- Turning up your P-7100 IP
- Fuller RT610
- Problem starting
- AFC housing break off bolt
- luk clutch?
- Money pit.....BALL JOINTS
- engine serial number - where to find
- turbo brain fart
- HELP! What's wrong with my truck?!
- Transfer case question
- new truck, need power
- boost
- turbo wobble
- Converting an auto to manual
- voltage
- help
- Questions
- 12 valve
- clutches??
- Max Boost on stock 96 12v turbo
- some help.
- tire wear
- 5" exhaust
- differental Q's
- Fuel shutoff diagnosis
- Cylinder wear???
- PACBRAKE VAC CYLINDER REBUILD??
- poor mans big honking af?
- AFC housing
- boost elbow
- Oil leaking around injectors
- 97 3500 srw
- NEW TRUCK
- Boost Press location
- 95 cummins reg cab for 2500
- EGT sensor location
- how to get more rpms cheap
- Fuel Pressure Question
- Antifreeze
- oil leaks
- AFE Filter Part #'s
- Beat by a Duramax
- what makes auto tranny shift?
- Engine Cleanup
- Yikes
- Difference between cummins engines?
- Power and fuel mileage loss 1996 12v
- timing question
- STARTED UP RAN FOR sec now wont start during cranking
