- Motor noise
- Help
- lift pump route 04.5
- need exhaust parts
- Need towing mirrors
- Is this a fair price?
- Truck Mysteriously shut down and wont restart
- Drivers side brakelight not working on Truck camper
- 03 RAM HO CUMMINS
- Tire vibration or near death wobble
- banjo bolt sealed washer
- Exhaust ???
- exhaust ?
- Roar at slow speed/slight pedal input
- 04 injectors for a 07
- help with trans problem please
- Fuel Bowl Bypass
- p2146
- tire psi question?
- rear universal joint part numbers
- 04 raattle
- Throttle position sensor
- broke and broke down
- Interior Questions
- Clutch Chatter
- surge and seams like rough idel
- clearance question
- tailgate bushing?
- Headlight adjustment
- starting problem
- back fire
- Where can I buy a new 5.9 CR longblock?
- headliner removal?
- SeaFoam in a diesel
- Turbo Overboost Code
- warrenty question
- 2003 No power
- How long will the stock clutch slip before it wears out completely?
- Fuel Gauge?
- Code: P0148
- new truck
- maintenance and add on questions
- Baldwin BD 7317 dual flow oil filters
- Turbo Squealing under load
- angel eyes :)
- clutch
- Torque converter wont lock up...
- Engine Bay "hoarding"?
- Trans Temps ?
- Need some quick steering help!!!
- Strange change on startups
- miles?
- Symptoms of a dying CP3?
- HP?
- About to buy
- stock lift pump went out
- How much boost before throw codes?
- More 48re questions, hoping for tranny guy response
- converting a auto 2003 to a g56 six speed
- Sudden loss in fuel mileage
- LOOOww dyno numbers!!!!
- dead at the pizza shop
- A/C problems
- Quick Tranny question
- The difference between an 04 and 04.5
- Power Steering/ Steering Gear Box
- what tranny does the 04 high output have
- stock boost pressures
- can someone get me a picture of this?
- codes P1751 and P1753
- possible purchase
- Major Truck Problem! R.I.P TRANSFOMER
- HELP !! 5.9CR converision
- cummins fan
- CRACKED INJECTOR WHAT TO DO??
- A few service questions
- Tstat and Water pump brands
- 06 quad cab
- Question...
- Converting the truck to a 4x4?
- Which model?
- 06 Dodge cummins AC not working all the time
- Tire Question
- Need Some Tranny Options
- 07 mega cab
- Tranny Questions..
- sputter and white smoke???
- Fan Speed Code
- lowering an 04???
- 2006 A/C problem?
- 6 spd swap questions
- Cruise problems
- help??
- Mega cab year choice
- blow by
- Smarty or PPE for 04 Dodge?
- 2004 problems
- truck not starting
- Amazing what one sensor will do
- 06 4x4 making "final drive/wheel speed" noise
- how to deactivate "horn honks when in gear and door open"
- help me fix my truck
- 2007 dodge i deleted the dinger noise
- MBRP Cat Delete Pipe
- rebuilt 48re NO GO!
- Help
- U-Joints
- Crazy wipers!!!
- Trans cooler
- Boost elbow on 2004 Cummins
- Is there any drone with a straight pipe exhaust?
- A/C Driver side only
- Need some help, might be crazy but.....
- exhaust manifold compare BD or ATS
- please help p0016 & p0341 code
- Driveshaft 2004 drw,auto,longbed
- ok boys... tell me what's wrong.
- What do you think on this one?
- 04 Questions
- rebuilt trannys
- Where can I get a new plastic engine cover deally?
- Dash Light
- Got a Fan Speed Code
- hit a fork in the road, need some advice/input
- Couple questions from a new cummins owner
- Crankcase Breather Filter
- Cummins emblem
- 06 CTD NO GO
- Valve Body Nightmare
- rough and missing at idle.
- cruise control problems.....
- 04.5 ho6speed compair 06ho6speed
- 2005 Dodge 48RE
- 03 parts vs. 05 parts
- dodge warranty
- Gear Ratio Change
- pics please
- Cheap OEM Dodge parts online?
- 48re on the outs?
- New to me 2004 Cummins 4x2
- New Truck!!!
- Weirdest 06 tach yet
- Looking at an 07
- Axle Width
- Tires
- block heater
- 3rd gen (2003)How to enable the High idle?
- cold starts wtf 2005 5.9
- Aux trans cooler
- Injector line noise
- 2004 Dodge ?
- 03 dodge fuel problem??????
- Price Help....
- Bad Idle
- NEED HELP PLEEEEEEASE!!!! Torque converter
- What it worth? 2007 3500 5.9
- Noise and hot cp3???
- I'm Going All Out
- Looking to convert
- BEST MPG WITH 04.5 6speed 4:10
- Thinking about buying a common-rail.. any advice?
- torque converter lock switch
- Hey remember 8 lug!
- Transmission builder props...
- 04.5 wont not rev through the rpms smooth?
- oil pressures high
- 35s on a stock 2005 4x4
- Over head computor
- fuel guage isnt working
- hooking up a transfer tank to oem tank on the truck
- Well, crap!
- rough idle down, little bit of a slight knock started
- random white smoke
- HE341Ve problems
- A-Pillar Gauges
- IF THE LIFT PUMP GOES OUT DO YOU PUT ONE IN THE TANK?
- Trouble codes
- 3rd gen cummins brake pad install?
- External wastegate
- 5.9 Idling High
- Oil Leak
- Reverse Lights
- 06 24V is blowing 2amp ignition fuse
- Tranny ?
- bolt pattern
- over reved it....ooppps
- Questions Timming-over rev...oops
- wastegate "woosh" sound in 04.5-07 cummins?
- 5.9 CR 4spd Vs 5spd Vs 6spd Manual? HELP
- lets see some pics of those badass 3rd gens
- brick seats
- Waste Gate Code
- tying the gauge lights into the dash lights
- want to buy a smarty
- Need Tires
- 48RE noob - What to do!
- clutch noise
- Saveable Block
- common problems with Cummins 5.9
- Trans temperature sensor on 6 spd
- vexed about driveline
- white smoke
- 68RE behind a 5.9???
- Tach
- TRANSMISSION HOW CAN I HELP IT LAST??
- Lock up switch?? Can it be done?
- loud
- What exhaust ?
- 50 psi???
- New Truck
- BioDiesel
- RP Max ATF???
- Front Alt Bearing Squeeks
- edge programmer
- Which one ?
- 12v into an 04.5
- new truck
- Code P2669
- Interior lights
- Temp
- Tranny cooler?
- fuel guage problem?? help!
- ABS and E-brake light coming on then going off
- Best mod for MPG's?
- Which wire to power Walbro relay?
- heat insulation
- TRANS OIL CHANGE CAN YOU GET OIL OUT TC?? HELP
- BIG CAMPER PULLING A BOAT 04.5WHAT SHOULD DO FIRST
- BIG CAMPER PULLING A BOAT 04.5WHAT SHOLD FIRST
- MODULES ANY INFO ON US DIESEL???
- EGR JUST MAKE PLATE?
- Oil Pressure?
- HOW DO I MAKE MY EGR GO MIA
- Black oil
- which type of amsoil
- Rail pressure gauge
- Code P0628
- Strange front end noise
- need some tranny help
- Friend looking at a 2003
- early 04 dodge 2500 power loss
- What is a sport bumper??
- Which pump and why?
- engine stalls/cuts out 04.5 six speed
- Check Engine, Brake, and ABS lights stay on.
- Confused! What does the 04 have?
- Transmission and Smarty questions
- video of my rig
- 06 Cummins
- lift pump
