PDA
View Full Version : 5.9 Liter CR Dodge Cummins 03-07
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18
  1. CR injector Reliability?
  2. CR sound?
  3. horse power
  4. Fuel Mileage
  5. 48RE 2nd gear slipping?
  6. 2005 cummins motor in 2004 Truck?
  7. Help with 04 cummins
  8. injector swap question???????????
  9. cp3
  10. manuel trans cracked
  11. Gauges
  12. 48RE - G56 swap
  13. What kind of tires
  14. Module Interest
  15. HP curious?
  16. Please help with wiring...
  17. No power after warm up
  18. 2006 Dodge 5.9l Cummins loud engine knock
  19. mileage
  20. 4in turbo back and stock boost
  21. more injector questions
  22. common rail injectors?
  23. What is 2005 dodge cummins problems?
  24. Commonrail injector problem?
  25. Idle RPM
  26. RECALL
  27. 2004.5 Cummins 5.9
  28. Oil Smell
  29. Battery or alternator problem???
  30. Coolant bundle /Water tube Issue ?
  31. newer truck?
  32. straight pipe question
  33. some help from the BIG builders
  34. crappy AAM axle u-joints
  35. transfer case question
  36. Blow by
  37. fault code p0628
  38. how does the warranty work?
  39. Engine Needed... Looking for Help In or Close to Tulsa OK
  40. Power belt replacement on a 04 cummins
  41. weird acting truck
  42. found a 07 Cummins with 134k good Deal?
  43. Idle/cough?
  44. Fan clutch wiring??
  45. Lost all pedal response...
  46. Water Pump went out
  47. Still will not start
  48. misfire or rough idle at cold start up?
  49. towing mirrors
  50. 3.5 Years On Gel Cells??
  51. Offer made on my truck.
  52. Clunk or banging on downshift
  53. Alternator Question
  54. Alignment/Camber
  55. Fuel Knock and sputtering
  56. CR sounds?
  57. 48 re problims need help
  58. switching from vp44 truck to common rail.
  59. Damaged injection pump?
  60. weak or no power steering?
  61. Interior Lights WONT STAY ON!!!!
  62. 4" downpipe question???
  63. 06 ram no reverse 5.9 48re tram
  64. Injector Question
  65. winter storage prep help
  66. bag of parts??? NOT
  67. 03 lost power steering/brakes won't release
  68. Misses under hard acceleration. WHY? Ideas?
  69. pickup running rough.
  70. 2004 cummins diesel won't start suggestions
  71. Recommened intakes for a 07 5.9?
  72. Lots of Wind noise in Cab
  73. P0628 code
  74. truck wont start.....
  75. Straight pipe or ????
  76. D-tech parts
  77. 2004 cummins won't start
  78. Injector Hold down bolts
  79. got a problem
  80. No or Hard starting
  81. Injector Problems
  82. changed batteries
  83. code 2509
  84. obd2 port wiring diagram?
  85. What's the difference/better?
  86. Not Starting
  87. New truck prob with mpg's need input
  88. Holiday Wishes
  89. 97 catalytic work on an 03?
  90. front axle
  91. Cylinder head pressure?
  92. T/Rex Steering Box Brace
  93. 05 2500 exhast
  94. 2003 dodge wont start.
  95. 2004.5 dodge cummins?
  96. can you put a 2005 tranny in a 2003
  97. hydro assist steering help??
  98. 2007 5.9 Cummins Diesel voltage
  99. Which tranny should i go with?
  100. Stumped on Exhuast what to do.
  101. Leaking injector line?
  102. 18000mi. since aug
  103. 04 dodge cummins 3500 truck runs for like 10 sec and shuts off i think bad cam sensor
  104. 04 dodge cummins 3500 runs for like 10 sec and shuts off plz help
  105. Catalytic Converter Question
  106. Crankcase Vent Filter Screws
  107. replacement taillights
  108. manual trans
  109. wiring probs
  110. 05 cummins throttle issue,mind of its own!!
  111. Common rail questions
  112. Front End Rebuild Questions
  113. stock intercooler
  114. Problems with 03 Dodge Dually 3500 Cummins
  115. 2003 Dodge 3500 4 Wheel Drive 48 RE Transmission Issues
  116. service manual
  117. cant get the smell of anti-freeze out of my truck
  118. Tail light covers
  119. Backup lights
  120. 06 cummins injector
  121. Tranny cable vs electric kickdown ??
  122. Borg Warner??
  123. Installing cab lights on a 2500?
  124. 05' cummins shut off while idleing
  125. mirrors
  126. Is '03 preferred
  127. 48re to 6 speed
  128. sick 06
  129. Banjo Bolt on a 2007 Cummins fuel canister intake line.
  130. Confused.
  131. New Batteries Now No Start
  132. occosaional surge driving me crazy help
  133. sellinjg old truck getting new.
  134. Fog light's
  135. Fcm??? issues
  136. Silencer ring
  137. 2wd to 4wd
  138. low speed binding from stop to 5mph
  139. P2149
  140. loss power
  141. Just a reminder
  142. replacing my heater core every two weeks?
  143. Rear wheel hub caps
  144. What size tire
  145. Wire up anzo lights????
  146. truck stuck in liimp mode...
  147. truck stuck in liimp mode...
  148. Hydrogen in diesels
  149. turbo problem
  150. i have two questions
  151. 2006 3500 4x4 Rear End?
  152. Cold weather starting
  153. smells?
  154. Maintenance..
  155. vibrations !!!
  156. over heating- air pressure in coolant...
  157. Replacement Clutch, 2005 G56 Trans?
  158. electrical issue maybe?
  159. Batteries?
  160. Interior
  161. 2004 Dodge CTD Possible no start
  162. 05 5.9L Surging under throttle--no power increase?
  163. tranny question
  164. 4 codes
  165. Good diesel shop?
  166. 07 cummins in an 04.5
  167. Annoying issues - help me fix!
  168. Why does a/c comp run on defrost?
  169. Need a Torx Bit
  170. Jake Brake Malfunction
  171. Went and did it!
  172. Turbo
  173. Should I upgrade my tranny?
  174. 5.9 Factory Exhaust Upgrade..Aftermarket?
  175. Servicing an 06 auto tranny & rearend ????'s
  176. 05 ENGINE INTO AN 06
  177. Big-A
  178. Spec questions on an 07
  179. Timing knock and won't start
  180. NO SMOKE?
  181. CR or not...? NOOB ALERT!
  182. 03 Cummins Fuel Mileage Drop
  183. Changing Low Gearing
  184. brain tease
  185. oil change input
  186. Name that noise! Unit bearings???
  187. 04.5 Dually
  188. Those with dynatrac...
  189. Frustrated with a vibration..
  190. What to look for?
  191. Gear Case Leaking... should I do a cam too?
  192. no start
  193. Do the 3rd gens suffer cracked manifolds?
  194. Seats for these trucks
  195. Done with 6.7 back to 5.9 YeeHaw
  196. 48re to NV5600 swap
  197. Help! 07 Cummins 5.9 Gear slapping noise
  198. Please Help
  199. clutch problems
  200. Noise...
  201. High Egts..
  202. another 48re question! bands?
  203. 48RE issues
  204. NOTHIN BUT PROBLEMS SINCE I GOT IT!!
  205. Dodge 5.9L What to Look for
  206. Dodge Balljoints Can...
  207. smarty
  208. newb with questions
  209. Looong Cranking 04 Dodge Cummins
  210. automatic problems
  211. need an opinion
  212. Hard start sometimes when cold
  213. dodge limited slip
  214. what tranny fluid?
  215. Sound and vibration like its coming from rearend
  216. new truck
  217. fuel filter
  218. exhaust and turbos
  219. Just a suggestion:
  220. Third member
  221. 5th gear's rattling?
  222. 06 mega cab lift needed
  223. Shifter adjustment
  224. CR Pressure Relief Valve
  225. Transmission problem
  226. 48re to 68re swap?
  227. freeze plug
  228. rough idle
  229. steering linkage
  230. 04 won't start
  231. New 'LARGER' Air Filter Installed!
  232. NO BALLS
  233. Installed NOx Filter, Now Won't Make Boost
  234. Noise? What - Oh THAT Noise....
  235. Need help please
  236. is it my injector pump?
  237. Front Pinion seal
  238. Taillights For 2005 Dodge
  239. oil leak
  240. 2004 dodge ecm problems?
  241. Power Steering Quirk...
  242. Tranny fluid ?
  243. power board steps
  244. Codes PO646 & PO882 ?
  245. p1757
  246. Intercooler Issues on an 05'
  247. Under Center Seat Console
  248. Broken steering linkage.
  249. Tranny Nightmare, Help!
  250. empty weight of 05' qc 4x4 cummins
