- Rear Axle Seal
- Wierd Problem-Maybe
- Yet Another And Hopefully My Last Clutch Question
- 3500 Rear Spring Pack
- ATS Gauge Install
- Smarty Software
- Can't Powerbrake Anymore?
- G56 Cooler
- Codes, Help Please.
- Tow/Haul Button
- Disconnecting Lockup By Brake Pedal?
- Who Here Has Actually Broken A 48re Input?
- Need Advice!!!
- Van Aaken Performance Module?
- Fuel Additives And Miles Per Gallon - Newbee
- Leaking CP3, 2 Injectors Going And Turbo # 2
- '03 New To Me
- Smarty Question
- Door Locks
- TC Lockup Switch
- 2 Trouble Codes, Need Some Help Before I Go To The Stealership
- Looking For A Trans 48RE
- Factory CAT Questions
- Smarty Help
- Ball Joints For An 04?
- What Could Have Happened To My Stock Turbo? It's New!!
- Injectors
- Clutch Help
- Muffler Swap
- How Many Gauges
- HF6604 Cross Ref.
- Head Studs QUESTION?
- Replacement Air Filter
- Burnout
- Just Got Back From Zimmeys WOW!
- Who Has A Winter Guard?
- 2003 Cummins Code Difference
- Fuel Presure Gauge?
- What Clutch?
- Buying A 3rd Gen Need Help!
- Problem With Two Timing Boxes?
- Geno's Garage Muffler Elimination Pipe
- What Type Of Rear And Front End On A 06?
- Fuel Pressure Need Help
- Somebody Stole My Truck!!
- CB Placement
- 2005 CTD Owners Look Here
- My Truck Has Died....
- Tcase Question
- 48re Bands Adjusted
- Timbren Suspension Enhancement System
- Time To Build The 48re
- Installing BD Aux Lift Pump
- P 2146 Trouble Code....Jake Brake Equivalent?
- Stock 07 Times?
- Suspension Work Done
- Any Of Ya'll Tried Biodiesel?
- Stock Clutch
- Best Programmer For 2005 CR ?
- Free/Cheap Mods?
- Missfiring Possible
- Alignment Specs
- Exhaust Delima
- Regular 75w90 In My Rear Axle
- Check Engine Light
- '03 Cruise Quit Working
- Smoking Issue
- Fuel Endurance
- Rough Idle And Blue Smoke On Startup
- Blow Off Valve
- Who's Running 315 BFG's
- Differences Between The 04.5-05 Edge And The 06 Edge.
- How Do I?
- Amsoil Oil
- High Idle
- Smarty Jr.
- Overhead MPG
- Okay, Dont Laugh, Does Any One Run A Turbo Timer?
- Need Turbo ADVICE
- HEY ALL WHAT DO YOU THINK?
- Injectors, Which Ones?
- Finally, New Engine
- Others Driving My Truck?
- Bad Noises Under Throttle
- Driveline Vibe
- Gonna Stack
- 5.9 CR Versus 6.0 PSD?
- Throttle Sticking
- Van Aaken C5 Smartbox
- Transmission Acting Up
- Front Pinion Seal
- EGT Guages, Questions?
- 2 Micron Filter?
- Lights Get Dim And Bright
- P0148 Code... Question..
- Low Fuel Pressure 2006 Dodge Cummins
- Another Cummins
- The Day My Tranny Died
- Stock Block Heaters.
- Problems With #6 Cylinder
- Our New Cummins
- Remote Start
- Well, I Fubared That Up!
- Weak Suspension?
- Codes
- Lamp Out And Very Frustrated
- Ram Head Grill
- CB Install?
- Gauges
- Oil Analysis Results....
- Belt Tensioner??
- Looking At '04 2500...Have Questions
- Which Turbo Are You Using
- Truck Honking At Me
- Truck Shuttering
- Help, Antifreeze in oil
- New Superlift Traction Bars Installed!!!
- electrical problems
- losing boost, power!!!
- Tranny slipping...
- Answer From Dealer On White Smoke and Rough Idle
- Have a few codes, need help
- Seat Covers?
- Can exhaust manifold gaskets be reused???
- 06 dodge rough idle
- What Happened!!!
- wifes engine is blown
- INSTALLING A NEW VALVE BODY
- 2WD Suspension Question
- CODE!!!
- Still Some 07 5.9s Out There
- Need clutch advice
- Hard Start
- Wife Hurt my Feelings!
- Looking for a motor.
- Rattle and..........
- wife 05 has these codes
- Antifreeze in oil, Help
- 06 door pannel removal
- G56/Mileage Question
- EMS Hubs
- Fuel Lines?
- What wire on headlight Switch For Gauges?
- transfer case popin
- new keys
- 05 4wd Front Hub needed
- 2006 badges to 2007 badges! (pics)
- air conditioning
- News Story On Cracked Dashes
- What front bumper is this and who makes it?
- stovepipe router
- Help??
- Black Chrome stacks...
- stax
- Dually flairs?
- Torque converter and valve body install??
- Fuel Pressures
- Front Pinion Seal?
- Turbos
- Brake pads...
- suncoast allison for ctd
- Lorenz Suspension?
- This might be a stupid question...
- Sirius Radio Issue -- Only Picking Up Stations 74 - 184
- Billet Valve Cover
- 5.9 Cummins Diesel Engine Low Miles w/ Warranty $4,500
- Tie Rod end parts
- Starting
- What Exactly Will Break In My Stock Auto Tranny If I Up The Power On My Truck
- All season grills
- Help!
- N-fab Nerf Step
- Tow rig upgrades
- two gauge pillar pod with handle?
- str8 pipein
- Gauge lighting ?
- Difference Between 04 And 04.5
- thinkin about new front bumper
- Wheel Width
- Tranny temp guage
