PDA
View Full Version : 5.9 Liter CR Dodge Cummins 03-07
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18
  1. Need a trans for 06 Dodge
  2. Edge CTS
  3. Need to find a 2006 Engine
  4. Well it was bound to happen sooner or later...
  5. Need help
  6. Propane injection
  7. headlight
  8. What gives!?!
  9. question bout my tranny and rpms
  10. Confused. This stuff is intense!
  11. turbo and injectors
  12. Clutch or Tranny Problem?
  13. 07 5.9 Engine Cuts out at higher rpms
  14. Dead spot off idle?
  15. any tips for assembly
  16. OIL BLOWING OUT OF TIMING COVER,COOLANT BLOWN FROM REAR FREEZE PLUG
  17. injectors
  18. Light's out too fast
  19. Front end!!!!
  20. Turbo Upgrade??
  21. I need some help with my cummins, throwing codes P0236/P0237/P0238 and same in PD
  22. injectors or worse?
  23. 48re slow to start.
  24. Help with interior lights
  25. Clutch Confusion...
  26. auto to manual swaps
  27. help
  28. Coolant Questions
  29. New guy in Tn
  30. lift pump
  31. best described as a backfire.
  32. white and blue smoke
  33. Injector buzzing
  34. Over Heating Problem
  35. Factory rims
  36. I want that whistle sound
  37. State Patrol Issues....
  38. Price Quote on Gauges
  39. tranny swap
  40. CP3 Price Help
  41. Coolant leak
  42. Tach Fluctuation
  43. Turbo
  44. All new injectors or just nozzles?
  45. Tires and Bumpers
  46. Gauges?
  47. Dodge 48RE
  48. Exhaust Brake?
  49. rear axle seal
  50. What Fleetguard Number ?
  51. Is there really any benefit?
  52. Bosch CP3
  53. 5.7 tranny
  54. Major Squeak!
  55. Engine Rebuild Kits
  56. Good deal on an '03 3500 crew?
  57. oil
  58. hub replacement
  59. How to know if the injectors are good
  60. 03-08 owners sign in whats the best year
  61. Clutch or Transmisson Problem?
  62. Black sut on map sensor
  63. Vibrating 04
  64. Dropping MPG's
  65. belt part numbers
  66. Is this normal????
  67. Length of Megacab Shortbox
  68. Fuel Filter
  69. not really in diesel distress, mostly annoyed.....
  70. g56 shifter boot fixed
  71. factory satellite radio stations
  72. 2003 3/4 six speed
  73. Fuel Pressure Readings
  74. 3rd Gen Cracked Dash
  75. 03 common rail popping
  76. 5 speed
  77. 06 5.9 blowing a little smoke ?
  78. Waranty ?
  79. To Go Manual or Automatic
  80. 03 Cummins fuel rail....Biodiesel/WVO...anyone tried these? or heard?
  81. Conversion kit for fuel pump?
  82. 03 Cummins - cold start problem- gone worse ..update
  83. extended warrentys?
  84. 03 cummins popping
  85. Cold Start Problem--Gotten Worse
  86. Poo88
  87. 2004 truck what motor does it have?
  88. Stuck in 4 low
  89. pcm's fried
  90. 05 5.9 missing and lots of blowby
  91. Turbo removal difficulty
  92. Power Windows Quit Working - Fix Inside
  93. weird squeaking noise
  94. New guy with?
  95. broke DOWN
  96. Shutters
  97. Looking for some advice. Vp or Common-Rail
  98. Injectors - Description, Operation, Removal, and Installation
  99. Satellite Radio-hard wired
  100. Loosin my mind!!
  101. 03 cummins starting issues, please help!
  102. turbo question
  103. silencer ring on on 06?
  104. Reinstalled Edge NEED HELP!!!
  105. Powerstoke and Cummins
  106. Manual Electronic Shifting on an Automatic
  107. WHISKEY TANGO FOXTROT?
  108. Need help! Relay fan ???
  109. Tie Rod Update
  110. Ring and Pinion
  111. 03 Dually Rear Brakes
  112. did they use the 6 speed trannies with the 5.9
  113. Need Suggestions!!!
  114. Problem With Tach on 06 Cummins ?
  115. a pillar pod
  116. water methonal or a programmer
  117. Oil leak frustrations...
  118. Belt routing diagram
  119. !!!My Truck Is Possessed!!!
  120. is this a side effect of 2-stroke?
  121. find out gear ratio
  122. MBRP exuast
  123. getting a p170 code
  124. a recall to check out
  125. Anybody heard of a transmission actuator?
  126. 06 ram with rear rotor question
  127. Stacks
  128. Brand New Motor!
  129. code is killing me...
  130. MIL P0480 and P0243
  131. help dtc code u0001 can bus
  132. Fuel mileage Auto vs. Stick
  133. Buying a new to me truck any suggestions?
  134. Next step for my buddies truck?
  135. First Diesel need help on what to install.
  136. Maintenance ?
  137. 05 Cummins:edge vs. bully dog
  138. AEM methanol injection system
  139. new shoes
  140. Diesel tune up (sevice)
  141. code?
  142. Boost fooler with edge juice
  143. What Injector for me
  144. Which one is best
  145. tranny trouble
  146. sluggish 06 3500
  147. Inj. Lines
  148. What Turbo is best for me.
  149. who has dealt with warranty hassle on there truck
  150. Steering Recall for HD 03/08
  151. 04.5 cp3 pump
  152. Down pipes?
  153. xzillerator upgrade
  154. tst powermax
  155. Ignition kill switch
  156. MPG's on 06' 5.9 stock?
  157. MAP SENSOR
  158. ambient air temp sensor, 04 cummins
  159. can anyone answer this one
  160. Transmission Help
  161. Official Diesel Nut
  162. e fans
  163. Leveling kits
  164. what is a smoke switch?
  165. 04.5 water pump?
  166. Stupid Door Lock!
  167. Do they have Diesel Darwin Awards?
  168. Tranny coolers.
  169. cummins rattle
  170. Rough idle
  171. 03 cummins wont start
  172. Engine Light
  173. water pump / thermostat replacement
  174. ooo what to do next!!!
  175. fluids (maintenance)
  176. Seat belt warning light
  177. Air intake guard removal
  178. A/c issues
  179. fuel system upgrades
  180. superchips
  181. Debadging ?
  182. CP3's
  183. Need advice on Mega Cab...
  184. new guy looking for a few anwsers
  185. 5.9 SO and HO?
  186. converter or not
  187. Door lock questions with turbo timer?
  188. need help with mpgs
  189. Gauge set up
  190. Fuel economy help
  191. Decode Your Vin...
  192. dead 05
  193. 03 wont start without ether
  194. Pressure Relief Valve
  195. 48RE giving up the ghost?
  196. Just Installed my New Exhaust
  197. Grinding calipers to fit 16.5" rims
  198. Autometer sender or AD going out?
  199. silencer ring and BHAF
  200. windshield pod
  201. di procal gauges
  202. truck wont start
  203. Fuel filter change/now no start
  204. 04.5 fuel water seperator location?
  205. I'm finally back in a truck!!! WooHoo!!!
  206. What motors will work
  207. will this work???
  208. twin stick tranny?
  209. 2009 Tailgate Emblem on my 2006
  210. Where to look?
  211. Exhaust
  212. Fuel Prices?!?!?!?!?!?!!!!!!
  213. looking
  214. Brake Part # help
  215. Which way right or left?
  216. Dyno Day
  217. picking up my 04.5 this week
  218. 04.5 2500 saftey?
  219. Dilemma; Turbo or power adders
  220. Fuel pressure gauge
  221. towing turbos
  222. engine cranks too long
  223. what should boost be limited at
  224. common rail injectors
  225. mp8 stacked?
  226. 04.5 brakes
  227. lift pump- who's best
  228. life expectancy of stock turbo
  229. Smarty Beta 4.3?
  230. S480 - how much boost is ok????
  231. Tach Gone Bad
  232. Bad cmp?
  233. gauge connection
  234. CP3
  235. Turbo Help!
  236. amsoil 4510 air filter
  237. delete pipe
  238. Does anyone have a xillaraider II? If you do how do you like it?
  239. New Turbo break in?
  240. how do i get to 12+sec quarter mile times
  241. No Heat
  242. Take-off shudder??? U-Joint??
  243. Adjusting Parking brake on '04 3/4T
  244. Coolant Questions
  245. Differences between S-06 & Jr. POD's
  246. get more smoke.
  247. 03 ball joints / help
  248. Running rough at 60-65 mph....
  249. hit the rollers
  250. All new fuel system
