PDA
View Full Version : 5.9 Liter CR Dodge Cummins 03-07
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18
  1. 48re rebuild
  2. New purchase 2004 Cummins - dead pedal
  3. weight pulling
  4. stock filter pressure?
  5. 05 steering box
  6. DIESEL COUNTRY NATIONALS
  7. Crankcase Vent Filter
  8. More issues 04 H.O Head gasket?
  9. 48re rebuild in Phx
  10. 05 turbo gasket gone
  11. gas in diesel
  12. oil leaking problems
  13. 48RE stuck in first gear. HELP!!!
  14. Intermittent No start
  15. Engine differences
  16. Should I Run 2 Cycle Oil In My Fuel?
  17. Dodge Death Wobble?
  18. vacuum pump?
  19. will they fit
  20. 4x4 Sticking on
  21. Brake Hiss
  22. 04.5 rail return help
  23. Where is the ac orfices
  24. New owner of an 06, have some questions
  25. COOLANT LEAKING OH crud!!!!!
  26. Anyone with a nv5600 for sale
  27. How often should I change Tranny fluid?
  28. coolant change how often and what kind
  29. BAND adjustment
  30. plugged in to start..
  31. BAD milage need help!!!
  32. How much for an 03 engine?
  33. Codes
  34. disconnecting ecm connectors?
  35. I need a NP 273 Transfer case
  36. NEWBIE WITH A QUESTION!!!!
  37. 2001 Ppump 24 valve engine in a 2005 RAM 3500 ?
  38. 2006 5.9 cummins
  39. steering issue
  40. RIGHT SIDE LIGHTS
  41. Engine Noise
  42. Adding lift pump ,....
  43. Blow By Rebuild
  44. How to disable seatbelt alarm 2006
  45. need to know what to stack with a smarty
  46. rebuild manual or info for a 2004.5
  47. tranny rebuild
  48. Cummins Starting Hard
  49. Injector Nozzle Advice
  50. injectors
  51. Intermittant fan
  52. FRONT BRAKE PADS
  53. Need help, my truck stop running!!!
  54. Low Boost
  55. Compound Turbos
  56. catalytic converter
  57. 06 cummmins smoke in morning
  58. Best SMARTY MPG's
  59. What programmer do I need?
  60. Next step in performance
  61. what causes a 2509 code
  62. Alternator Rebuild?
  63. Strange squealing noise
  64. Whats this???
  65. 05 r2500 4x4 trany New vrs's Rebuild?
  66. 03' auto transmission problem..Help!
  67. turbo help
  68. question conerning charging system on 06
  69. Injector Knock
  70. Problem solved, Thanks to all!
  71. 2006 dodge wont start
  72. some bad turbo surge going into od
  73. batteries
  74. I'M BACK!!!!!
  75. 03-04.5 and 04.5-07
  76. trans swap
  77. True or not???
  78. Code P0251
  79. 2004.5 5.9
  80. water in fuel?!?
  81. cat size
  82. 2006 5.9 4x4 Just sold $6700
  83. Smoky haze coming from oil cap ?
  84. lights
  85. stalling
  86. replacing the cp3
  87. Ah the nasty hub assembly
  88. Strange noise
  89. Dang, now batteries are dead...
  90. no start and stumped! 07 5.9
  91. interior light won't go off
  92. Location of bypass... ?
  93. Brake Pads
  94. Decoding a VIN 1-17
  95. 04 5.9 HP losing power under a load
  96. fuel economy question
  97. Turbo or wastegate issure
  98. Cranks but wont start.
  99. stak
  100. tranny up 06 cummins auto second not grabbing
  101. 07 5.9 Electronic throttle?
  102. Water pump leaking. :(
  103. loses power
  104. DiabloSport T-1000 - DiabloSport Trinity
  105. Phantom vibration
  106. 2005 cummings accleration prolbem
  107. Need wiring skematics -Won't crank over-was having other issues prior
  108. Any ideas?
  109. 03 running rough
  110. engine fan
  111. transmission problem
  112. Coolant change
  113. 48RE Tranny question??
  114. 1st gear slipping...sometimes
  115. Fan Clutch
  116. Laramie steering wheel swap
  117. HELP!!!!!!!
  118. Boost Question
  119. fuel filter/ Injectors
  120. Can it be done? Pro's N Con's?
  121. crankshaft position sensor question
  122. looking for more....
  123. Front End Work
  124. NV5600 How much oil?
  125. Are the injectors the same on.......
  126. Bought A New Truck
  127. keeps on fueling
  128. 2006 5.9 trans trouble need help!!!
  129. NEED HELP PLEASE!!!!!!
  130. 03 cummins transmission
  131. 03 tranny probs
  132. 06 dodge a/c problem
  133. How to increase MPG on 03 Dodge RAM 2500
  134. Crazy Truck, Please help!
  135. injectors
  136. i need a price
  137. i am new to the diesels so this might be crazy ?
  138. egt's
  139. "HeadLight Help"
  140. What 48RE Tranny upgrades are reccommended??
  141. cam position sensor irratic signal
  142. Wheres my Lift Pump?
  143. '04.5 3500 needs new front end, is this what I need?
  144. fuel filter
  145. Lift Pump??
  146. Tranny rebuilt now this
  147. front bumper
  148. Valve Body
  149. 183000 Miles-Motor Oil
  150. steering stabilizer
  151. Front end garbage
  152. 48re clutch slipping?
  153. power steering leak
  154. what do u think
  155. Trans gague
  156. bad transmission or super chip issues?
  157. Got my 05!!
  158. nv5600 input shaft
  159. oil pressure 05
  160. Stiff Gas Pedal and delayed Shift to second
  161. 03 cummins tran need help!!!!!!!!!!!!
  162. New Cummins Owner
  163. 2004 high idle
  164. Opinions Appreciated
  165. overheating while towing
  166. Help White smoke and oil consumption
  167. 2003 cummins 6spd manual?
  168. turbo- code..is it serious?
  169. Switchin from powerstroke to cummins..
  170. Clutch
  171. fuel system problem
  172. new 04.5 dodge cummins.
  173. NEED HELP?
  174. lift pump code.
  175. Engine Knock
  176. Engine warranty
  177. led gauge bulb help
  178. Will not start without removing the fuel filter!!!
  179. 2004-05 FACTORY DODGE MANUAL
  180. wheel problem???
  181. Want a limited slip, need parts
  182. my 2005 dodge...
  183. 5.9 cummins starts and dies
  184. Warning signs of bad injectors
  185. power and smoke??
  186. tire size?
  187. Is my transmission toast?
  188. B What best filteration system for CR dodge cummins?
  189. Difference in 03 injectors and 04.5 cummins injectors?
  190. i feel pretty dumb asking this...
  191. new truck maybe
  192. 2004.5 Cummins will not start after engine swap
  193. LOUD NOISE FROM TURBO
  194. 06 cummins missing probs
  195. 04.5 dodge cummins?
  196. Synetheic gear Oil NV5600
  197. Smoking?
  198. stock turbo part number?
  199. coolant temp gauge
  200. Bad turbo?
  201. White smoke
  202. swap
  203. Best way to pick up Switched and un-switched power
  204. 04 cummins using oil?
  205. manufacture dates for half model years
  206. coolant problems
  207. 2003 Ram 3500 Front Wheel Joints
  208. Tail gate and subwoofers
  209. PDQ Volumizer manual
  210. 03 turbo
  211. Recommended towing mods and maitnenance
  212. 2004.5 5.9
  213. Best choice for Transmission Rebuild?
  214. Wanted: NV271 transfer case
  215. 5.9L Cummins 3rd Gen wanted for 07 Ford
  216. G56 southbend 3250 dd reviews?
  217. cherry bomb muff
  218. Start up after months of sitting
  219. nv 4500 fluid
  220. starting problem
  221. 04 dodge cummins.
  222. cold start problem
  223. Is this normal?
  224. Major issues.. Need help.. 2004 H.O
  225. when should injectors be changed?
  226. 2006 Dodge 3500 accelerates on its own.
  227. Oil Leak when under load
  228. trouble codes & descriptors
  229. Rims and Tires on a 2007 Ram 2500
  230. apps sensor question
  231. Air dog question
  232. Possible injector problem?
  233. Looking for an aftermarket oil pan for my 5.9
  234. Truck Won't Start
  235. Truck Won't Start
  236. 05 cummins .040 over
  237. 12v into an 03
  238. fuel plate question
  239. 06 3500 Problem
  240. what is it worth
  241. Injectors
  242. Winter grille cover
  243. transmission fluid in the fuel?
  244. 2006 Dodge 3500 - Smoking/Knocking
  245. rear main leak
  246. 2003 question
  247. weird noise
  248. PROBLEMS W/ 230 hp cummins in a F750 2006
  249. No.4 fuel line
  250. Pickup surging
