PDA
View Full Version : 5.9 Liter CR Dodge Cummins 03-07
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. 03 2500 Ram 5.9 code
  2. Injectors
  3. Removed insrument cluster - now won't start
  4. transmission fluid in radiator on 03 ram2500 diesel automatic
  5. Help Identifying Lift?
  6. resetting odometer and turning off "lamp out" light
  7. trans issue
  8. going back to stock wheel size
  9. 07 5.9 Upgrades for a newbie
  10. Advice on 04 5.9 cummins
  11. transmission cooler and lines?
  12. pac brake
  13. Hi everyone! First Upgrade?
  14. 06 48RE trans
  15. Trans issue
  16. 2003 V10 to diesel conversion
  17. Quadzilla Adrenaline with IQuad
  18. Strange idle only when the engine is warm
  19. Hp clearification
  20. O4 3500.
  21. Power and trans
  22. 2007 5.9 self primed? Or no?
  23. advice on steering upgrades
  24. abs and parking light stuck on
  25. Possible pcm troubles?
  26. 03 5.9 cummins 6spd
  27. 48re Rebuild Issues
  28. Help Me Set Up my Smarty Jr Please-
  29. im not crazy
  30. Fresh 5.9 Rebuild not starting
  31. Power loss, then restart and it works fine.
  32. Engine was changed
  33. P0341 P0541 possible fuel issue?
  34. Wheel compatability
  35. 4X4 on the fly or manual
  36. Transmission comes hard out of park.
  37. help
  38. 4x4 light comes on when in reverse
  39. P2509 P0069 P0192
  40. Intermitent Engine surging at slow speed
  41. New member
  42. where to start?
  43. Check engine light is on
  44. Brake light broblem
  45. no bus problem
  46. my 6.7 2007 Cummins
  47. grinding/rubbing noise from front end when accelerating sometimes
  48. Warm 2003 CR slow crank and late or no fire
  49. 03 5.9 white smoke
  50. Wait to Start Light
  51. What oil do you guys recommend
  52. cluster
  53. Turbo
  54. Runs hot while plowing and towing
  55. need advice for a special project
  56. 04 cummins suspension problems
  57. upgrades
  58. Help Please! G56 dd 3250
  59. Brake Problem?
  60. Front Driveshaft U-Joints?
  61. crunch behind steering wheel then airbag light
  62. still high rail pressure
  63. 2004.5 48re makes noise shifting 3-4 when towing
  64. 06 TQ locked up
  65. '03 5.9 Shuts Off, New Injectors
  66. fca maybe
  67. Mods for under a Grand
  68. '05 Harmonic Balancer Question
  69. 2003 Dodge 2500, Replaced TPS, dead pedal, Throwing p2121
  70. 04' throwing codes
  71. Code p1757
  72. ECM trouble
  73. 2007 Ram 2500 oil burn??
  74. high pressure
  75. 06 transmission not shifting right
  76. 2004.5 rebuild - No Oil Pressure
  77. Tranny randomly downshifts when in OD
  78. 2003 maps sensor
  79. TRANS HEAT EXCHANGER DELETED
  80. a/c control selector switch
  81. A/C blowing warm when temp of motor goes up?
  82. Turbo
  83. Clunking noise right side tire area
  84. 48re overfill ?
  85. smarty s-06 pod TNT-R software
  86. ecm
  87. Loss of power, stalling, no DTC codes
  88. NEED ADVICE ON 48RE TRANS REBUILD AND NEW TQ
  89. Where to put my pyro
  90. 2003 Cummins no start, not the fuel pump... codes
  91. Carrier bearing problems
  92. towing with smarty
  93. adjustable ball joints
  94. Having issues
  95. 03 ram 2500
  96. P0148 code with power loss and smoke
  97. 03 5.9 complete rebuild do's and donts....
  98. blow by and cylinder compression
  99. First diesel
  100. truck don't want to shut off
  101. start sounds different. no shutter on shut down .
  102. reflash
  103. try this
  104. need help
  105. 48re noise
  106. 2003 Dodge Ram 3500 Cummins diesel starting problem
  107. gasser to cummins
  108. 4.5" Banks straight pip exhaust
  109. Start Problems
  110. Smarty Jr
  111. 48re question
  112. 07 5.9 exhaust question
  113. 180 thermostat ??
  114. bad fuel mileage
  115. lots of cranking no start
  116. 03 ram 2500
  117. PULLIN MY HAIR OUT OVER A CP3
  118. No Boost
  119. fass 150
  120. Need help
  121. start side wont work
  122. 48RE Need some help
  123. Excessive Smoke w/ Smarty S06 POD Revo
  124. Goerend's 48RE where do I get one built?
  125. bad lope sound when decelaration
  126. My 5.9 Dodge Cummins won't start warm
  127. help me please
  128. Ideas for lowering engine compartment temps?
  129. ssr tuner
  130. Shifting problems
  131. AAM 9.25 broken diff cover bolt
  132. tranny problems
  133. Lots of white smoke but no power loss
  134. 07 5.9 upgrades?
  135. test for injectors?
  136. where can i buy dun m injectors
  137. Engine Serial Number frustrations...
  138. 2005 3500
  139. snap snap snap?
  140. Blue smoke
  141. Blue smoke
  142. Cannot find any rear brake hoses!!??
  143. 06 Rebuild - Cam question
  144. Turbo suggestions
  145. Does it exist?
  146. 5.9 no power black smoke.
  147. 2005 Cummins 5.9L rebuild manual
  148. throttle revs up on its own
  149. 2004 cummins won't start
  150. smarty Jr. vs edge evoht?
  151. HELP!
  152. 2003 cummins no start - no power to lift pump
  153. disable auto locks
  154. Idle?
  155. Hello and help
  156. NV5600 PTO Cover Stuck!
  157. 2004 Cummins Turbo problems???
  158. 03 2500 rear brakes
  159. knocking in front end
  160. dually adapters
  161. Value 05 cummins 2500
  162. EFI LIVE EAST TEXAS
  163. 06 cummins 5.9 fuel pressure
  164. Stalled out
  165. Cummins work truck took a shit
  166. need a turbo upgrade!!
  167. Smoke switch
  168. Smoke switch 2005 cummins 5.9L
  169. 2004 cummins
  170. Check engine light come on truck starts to limp
  171. no power until 2200 rpm
  172. 03 3500 2wd lower control arm bushings..help!!!!
  173. thinking about buying an 06 6speed
  174. new truck 2007 mega cab 5.9 auto
  175. 03 grid heater/glow plug bypass
  176. what's this clank?
  177. Victory/Arson III Cp3 Mod Kit for Commonrail Cummins
  178. twin turbo piping
  179. Better Edge CTS Mounting Option
  180. New to Bombers, fuel milage question
  181. cold air return
  182. Auxilary hydraulic pump
  183. 2004 2500 long bed 4x4
  184. Smarty jr
  185. S-B ConFe slipping??
  186. 03 qclb 6speed
  187. Is there less than a 2" level kit
  188. Cut off exhaust tip...how to extend?
  189. engine vibration
  190. pdc replacement help
  191. Dash Swap
  192. front 4x4 hub
  193. smarty good for stock 48 re tranny?
  194. preventing rust from wheel areas
  195. Drawstraw Help
  196. Has anyone figured out the rattle that comes right off idle on a 03-04 555 engine?
  197. Clank noise and battery gauge
  198. Growl at low speed braking
  199. Strange whining
  200. Electrical Issue, Dome Lights, Door Locks, Keyless Entry, Radio
  201. VSS Sensor destroyed? 48RE
  202. What auto tranny to use in swap?
  203. Realistic towing weights with my 5.9 2500
  204. 3rd Gen Ram Holset HE351CW turbine outlet adapter flange?
  205. were to jack(on my engine)
  206. 03 Cummins not wanting to start/ long cranking
  207. 12 valve conversion
  208. WMO in a CR... whos done it
  209. fass system advice.
  210. 2007 2500 5.9 front u joint -removing hub
  211. PATC torque converter?
  212. oil delimma
  213. Cleaned AIT and MAP P0234 still happening..
  214. decisions decisions
  215. Intermittent power loss
  216. Ford 6.0L swap to 5.9L CR
  217. need some advice...again
  218. smarty chip?
  219. more advise please
  220. Lift pump
  221. 2004.5 code P0148
  222. programmers?
  223. HE341/351 Conversion
  224. Boost Fooler
  225. STEERING
  226. COMPRESSOR WHEEL
  227. Tachometer
  228. 05 5.9l troubled starts
  229. Truck is making fuel- dealer can't figure it out
  230. injectors.
  231. Surging RPM after engine is warm
  232. Emissions Light
  233. Missing/Loping on Startup
  234. 2007 6.7 liter advice
  235. programmer questions
  236. help
  237. ignition switch going bad
  238. What exhaust manifod ?
  239. leaking water line next to turbo
  240. Problems Starting after sitting over night
  241. parking brake light and abs light on all the time
  242. Please help
  243. 07 3500 mega cab long bed
  244. Industrial injection injectors
  245. need some advice
  246. P0700 limp mode
  247. voltage meter
  248. truck has left me stranded any help will be appreciated
  249. 2007 Cummins Ram 2500 as a DD
  250. spare key
