- Where is my turbo whistle?
- 6.5 turbo on 6.2
- 6.5L Puffing Black smoke when accelerating
- 6.2 UpGrades
- obdi dtc 99
- need power steering pump help '99 6.5 3500
- 1997 6.5 will start but wont idle
- 6.5L TD stalling and other problems.
- boost
- PMD Failure...First Things Noticed??
- 6.5 mech pump swap to manual pump questions
- 6.5 TD wont start sometimes and misfires when I mash down on it
- What Torque Converter Do I Need?
- RPM Gage fluctuating should I be concerned?
- Engine runs rough
- need more HP
- 4" exhaust: put it on, got some questions
- 6.2 runs hot at highway speeds
- gutting
- locked up
- Heater and water senser on fuel filter
- technically if i...
- 6.5 electronic to mechanical
- 6.2 and 6.5 heads
- 93 6.5 floods when step up idle comes on
- Code scanner
- Strange Vibration noise when 6.5 is at Idle or A/C is on.
- DTC 57
- 1999 Chevy 6.5
- I HATE THIS TRUCK
- obd1 code88 tdc error
- lift pump problems?
- 97 6.5T accelerates on it's own.
- main seal
- 6.5 upgrades?
- please help 6.2.
- Wire wastegate shut
- 6.5 Diesel Turbo Problems?
- service engine soon
- DTC 92-#2 cylinder balance fault
- code p0236
- questions about 95 chevy 3500 6.5 turbo
- Exhaust system
- Useing coolant
- please help weak 6.2
- Running problem with 6.5 diesel
- wiring
- How far can I turn the fuel screw??
- Swapping 6.2l diesel into 80' corvette
- 6.5 lift pump rewire?
- 1994 chevy 2500 6.5 turbo diesel
- 93 CHEVY 3500 EXT CAB DUALLY 6.5 TURBO
- 6.5 starting problems
- Is there a way to test a PMD
- 2000 gmc 3500 cargo wont start
- 6.2l vacuum pump ?
- injectors
- found the problem/no fuel to injectors
- 6.5 Starting Problems
- bosch injectors
- Got the codes-1995 6.5 TD
- 1995 6.5TD misses
- New 6.5 owner
- Whats the best ?
- exhaust pipes
- Highest mile post
- 96 6.5turbo truck for sale
- looking at 1983 6.2 non turbo
- progress on no fuel issue/still have trouble
- messed up 93 6.5 td
- OS filter
- NEED HELP !! NO FUEL FROM INJECTION PUMP
- trans question
- OK ISSUES
- bigger oil filter?
- Still no fuel to injectors after replacing IP
- air in system
- 1997 c3500 cranking on it's own...help
- 1995 Chevy Tahoe Interior
- Glow Plugs
- 6.5 diesel chevy p/u dies, stalls suddenly!
- 83 5.0 gas to 6.2 swap questions
- what if i cut the exhaust off in front of the muffler
- 6.2 non turbo questions
- How to accurately establish a value for insurance purposes
- here we go again!
- Test vacuum lines
- Dash controls don't work
- 1990 fuel filter housing rebuild
- 93 6.5 runnin hot
- Caught some codes !
- Pics of my rig and finally mileage after a trip
- 95 6.5 turbo diesel Tahoe, starting issues
- tires
- poor accelerator response, hard shift 1-2
- wireing issues
- ??? How do I save $250 ???
- 6.5 will not start
- Fishing for help
- wood.... frankkfort
- 94 3500hd Steering gear
- Another stalling 6.5
- 6.5TD fuel system issues
- how do these break the crank
- S-10 with 6.5TD??
- Thrusday May be last day
- Heath Max-E Tork prom
- Newbe help
- Q's about a 6.5
- missing bad
- Tow Mirrors
- need answers
- Any one running WMO in their 6.5
- Newbie Q's for buying a 6.2?
- transfer case fluids
- Bought an engine, now have ???s
- which alternator? and U joints.....changin em
- manual torque converter switch or a good place to buy a tc
- 1 ton or 3/4?
- 6.5 HO Injectors-Worth it?
- 6.5
- Houston area tranny guy?
- How do you know if your turbo is bad on a 6.5
- 6.2 auto trany blues
- Top Mount Inter-Cooler installed
- i think i might have a overdrive issue
- diesel turbo off
- picture
- Looking into 1982 suburban w/ 6.2
- just bought a 6.2
- 97 6.5 has intermitent fuel at injectors, wants to start for a second then nothing ?
- Long Trip Comin... what oil;s to use?
- gages
- Slighty hickup
- Over revving
- Deisel Blues
- 92 6.5 losing prime
- No start 93 6.5
- will a 2004 duramax air box work?
- Glow Plug Harness
- bad flexplate
- Where to buy reman 5521 injection pump?
- No Headlights
- Glow Plug uh-oh
- Throwout bearing noise I THINK
- Cabin air filter...
- 94 3500 4x4 conversion
- glow plugs
- New PMD Installed...another possible issue...
- 6.2L Mileage
- Speedometer trouble
- smoking bad and missing out
- takeing off 6.5 turbo
- 94 k2500 w/o trb Injector pump?
- 94 stalls after sitting for 30 min.
- 6.5L TD Driving the Me Nuts...to PMD or Not
- What is this plug in?
- 85 silverado brake problems
- 85 6.2 gp controller
- Any thoughts on this fuel???
- torque converter unlocks and service engine light comes on
- Setting the timing ???
- boost gauge
- Looking for horses...
- motor change
- Rotella T Oil Any Good?
- Truck Stalls Outta Nowhere....confirming bad pmd?/
- 6.5 Chugging issues
- 6.2 blocks with 6.5 heads and turbo.
- could use a little advice, po238?
- 83 c10 transmission questions
- got three chevy diesels and ready to pull my hair out
- need a 6.2 block or
- hey im mitch
- pmd removal ?
- Help......code po216????
- Harmonic balancer pulley shot?
- 95 GMC 6.5 runs for 10 sec. then stalls and wont start
- No Vacuum Pump
- Oil pan removal
- Kelsey-Hayes fuel pump & PMD?
- 96 TD Injectors
- Dad Stuck New 33" Cooper STT's On the 82
- 95 6.5 Engine swap
- motor swap
- Tank you,Crazy,Rican Dsl,Woody 35
- 1990 1500 6.2l Diesel stalls while driving.
- fuel leak
- amount of electricity used to heat block
- 6.5L question??
- Heater not working
- Code 78 how do I get rid of it
- exhaust size
- cold air intake
- does the turbo on a 6.5 have a T3 or T4 flange?
- How do I get more psi out of the 1993 6.5?
- installing locker
- Arp studs
- Trans. and rear axle
- Power steering to Manual steering (maybe)
- missing issue
- A/C Problems
- Vacuum pump problems?
- How to read codes
- 95 6.5 dually oil pressure problem
- rear oil seal
- 1996 chevey turbo dsl wont start
- Batteries Won't Charge
- engine shut down
- two thermostats or one ?
- I am doberdawg, 63 yrs old & reside in Central California
- 2002 3500 cutaway express 6.5
- In need of more reliability
- Vacum Pump/Wastegate Actuator
- Glow plugs
- Oil pressure gauge acting weird
- sts turbo parts check Help!
- truck can't find idle
- Clacking sound from floorboard
- turbo non turbo parts swap
- P0380
- ECM Codes
- turn the key and nothing
- 6.2
- Lost
- 1997 chevy van 3/4 ton 6.5 TD
- Unknown Noise
- bio diesel
- DTC P0236
- 6.5
- NEED NEW BUMPER!
- Starts and idles but runs like crap
- Gear Ratios
- Engine issues!
- engine oil cooler lines
- Electrical diagrams
- 6.5 Weight
- noobey questions 6.5l
- Pillar or Dash Mount Gauges??
- hello all just a quick question here
- Injection Pump Inlet Thread Size?
- DTC P0231- stalling issue
- 96 6.5l turbo diesel stall
- Cooling a 6.5
- which oil filter ???
- Low MPG
- Reflash ECM
- Possible Ingition Switch Issue?
- trans swap QQQQ
- White Smoke at Start
