View Full Version : Diesel Engine Conversions
Pages : 1 2 3 [4]
  1. 64 gmc conversion
  2. Diesel Mud Buggy
  3. intercooler questions?
  4. 2002 Ranger conversion to a 4BT?
  5. F350 conversion
  6. gas to diesel 2000 dodge 2500
  7. 1998 GMC 6.5 diesel
  8. 2005 Ford Super Duty - The Perfect Swap
  9. 12 valve cummins in an 88 chevy 1500 short bed stepside
  10. swap an 2001 LBZ into a 2001 gasser?
  11. 250 into a 150?!?!?!?!
  12. 97 powerstroke convert to 2000 motor and computer
  13. Diesel Conversion For F-150
  14. new to diesels looking for information
  15. 8.3 Cummins in a "pickup"
  16. DT466 in a GMC 3500HD
  17. i'm a dumbass, an a newbee to diesel's
  18. 93' chevy 3500 cummins swap
  19. 2001 Jeep Cherokee want a 4bt in it
  20. 96 F-250 Common Rail?
  21. cummins swap
  22. cummins swap
  23. 93 chevy 1 ton/5.9 cummins
  24. 1st generation cummins
  25. early chevy 5.9 swap
  26. OM617 to NV3550
  27. chevy idea/help
  28. 1968 Corvette Diesel
  29. 2001 cummins automatic trans conversion
  30. any other adapter mfg's
  31. Dodge V10 to Cummins Swap
  32. 94 F150 CONVERSION--
  33. F150 CONVERSION--
  34. 5.4 Triton 4BT Cummins swap?
  35. Cummins in cherokee?
  36. need 4bt cummins
  37. Shifter stick
  38. "Reverse Conversion"
  39. Kubota 3 cylinder industrial engine conversion
  40. motor mount id part number help?
  41. 4bt cummins in s-10
  42. 95 chevy front drive shaft ideas..options...
  43. 12 Valve into a 1999-2003 F350 ?
  44. 84 6.2 liter diesel to 97 3/4 ton chevy swap
  45. 4BT Slave/Master Problem
  46. 72 K20 LB7 4x4 D-Max Update
  47. 6bt in a buick regal?
  48. swapping 6.9 or 7.3 in 78 FORD f-250
  49. 6.5 to cummins conversion?
  50. Chevy/Cummins swap
  51. Engine Adapter is there any interest ???
  52. Chevy body on a dodge frame
  53. Pcs Transmission controller
  54. Convert Ford E350 10cyl to Diesel??
  55. Back 2 The Future 5.9 Cummins
  56. Mits. 4D56TD Swap
  57. Swap a 04.5 5.9 Cummins for a first or second gen.
  58. in know this has been done before
  59. 12 valve bronco swap
  60. 87 jeep wrangler (617 coversion)
  61. will a Dana 300 last?
  62. newly aquired engine
  63. which t-case to use
  64. 2 wheel 1/2 ton cummins
  65. Needed Cummins
  66. 85 chevy 1ton cummins
  67. cummins in half ton
  68. 79' chevy k20 conversion...Help!
  69. gas and diesel firewall
  70. 4bt FRANKENJAEEP
  71. This Truck Is Sweet
  72. 2001 Chevy 2500HD conversion
  73. So many ideas, so little money.
  74. 6.0 cutting out
  75. check this out
  76. Call me 6.7l crazy
  77. The Fodge update
  78. 1991 Dodge 350 van swap
  79. 4BT in W100
  80. Allison automatic trans for Cummins
  81. Cummins in a GMC
  82. Cummins In 05/06 Chevy or GMC?
  83. 72 K20 4x4 + LB7 Duramax motor
  84. Progress on the 78 Ford Cummins
  85. Diesel Engines for sale
  86. 4bt Conversion
  87. Thermo King 4 cylinder(Isuzu)
  88. Diesel bronco
  89. Kubota Ranger Swap
  90. cummins in a chevy
  91. Outlaw Diesel is out of their mind.
  92. 4bt Cummins Rat Rod??
  93. 1971 Chevy K-20 Cummins Project.
  94. lots of ?'s and need lots of ideas
  95. 1998 ford f-150 4x4 lariat from 4.6 triton to cummins 4cyl diesel
  96. Sweet Conversion!
  97. Bradley GT Diesel
  98. Looking for DT466/530 swap info
  99. is it possible
  100. '95 F350 Engine Swap
  101. new project
  102. what diesel should i use?
  103. 6.5 TD into an 85 Yota
  104. 3208 cat in chevy
  105. Toyota MR2 Diesel
  106. Diesel Jeep Ideas
  107. gmc 1500 hd to duramax
  108. Need to set things straight
  109. ENGINE SWAP
  110. Didnt think this would work
  111. Cummins 10 speed conversion
  112. Mercedes Diesel To GM trans??
  113. NV 4500 QUESTION
  114. M11 Cummins
  115. Detroit Diesel Rail Car
  116. Duramax Powered Buick GNS
  117. My Project
  118. In Search Of A Donor For A "Heart Transplant"
  119. Gear Ratios And Ultimate Speed
  120. '92 VW 1.6L Diesel
  121. Mercedes OM617
  122. Van Conversion
  123. Diesel Vette
  124. 1994 F-150 4x2 Automatic Transmission
  125. 1994 K1500 6BT SWAP
  126. 12V In A '71 Ford?
  127. 1976 Ford Bronco Conversion
  128. Common Rail Swap Into A '99
  129. Jeep 2.8L Diesel Conversion Kit
  130. 4BT Cummins
  131. 7.3 IDI Intercooled Turbo in 90 Bronco
  132. 1947 Ford 1.5 Ton 'Heavy' W/ A Cummins
  133. Similar Frames?
  134. 1972 Chevy K20
  135. Jeepster Commando 4BT
  136. REAL Jake on a 5.9
  137. 1976 F350 with a 1160 Caterpillar....
  138. ANYONE DONE A PERKINS CONVERSION?
  139. 1995 K2500 Cummins
  140. 1966 Ford Bronco - Buckin' Bronco
  141. Switch Engines
  142. Cummins 4BT In Foxbody Mustang
  143. Any Tech Info On Hot Rodding A 4BTA
  144. 7.3 Powerstroke Swap
  145. 1977 GMC K3500 - Built To Suit
  146. Ford/Cummins/Allison.....New Project........
  147. Cummins/ Allison Combo
  148. Chevy Cummins
  149. Red Chevy With 7.3 Powerstroke Pulling...
  150. 2007 Jeep Wrangler Rubicon JK 5.9L Cummins - The Ultimate Diesel Jeep
  151. 1500 Chevy Duramax??
  152. Pic ?
  153. VW In An S10/Ranger...?
  154. Chevy Cummins Conversions, Check In Here
  155. Anybody See The Twinned Ranger?
  156. F150 Gas To Diesel Conversion
  157. Sweet Conversion Project
  158. The Doubler™ Is An All Gear, Dual Transfer Case System
  159. DT466 In A OBS Stroker?
  160. DT466 School Bus Conversion
  161. 6bta = High MPG?
  162. 68 Bronco
  163. 1982 Buick Regal - Darth Vader: Diesel Alternatives
  164. Diesel Samurai Conversions
  165. Cummins Vete????
  166. Cummins Motor Mounts
  167. Duramax In A 88-99 GM Truck
  168. Advanced Adapters Website
  169. 6V-53T And A 5 Speed Allison
  170. Detroit Diesel Conversions
  171. Motor Swap
  172. Cummins 3.9 4BTA In 1500 Dodge MPG
  173. 1991 Cummins
  174. What To Look For In A Wrecked Truck
  175. Dakota + 800 HP Commonrail
  176. Class 8 Dodge Ram..Heheheh
  177. Cummins 3.9 4BTA In 1994 Dodge Ram 1500
  178. Where to get a motor?
  179. anyone got $15000
  180. gas convert to diesel
  181. HOWS THIS FOR A SWAP
  182. 90's Chevy cummins converts
  183. 95 Dodge 2500 360 To Cummins Swap
  184. Cummnis 3.9
  185. Dodge 1500 318-6BT Conversion
  186. Here is one for the Dmax guys (GNX clone)
  187. Diesel monte carlo!!!○
  188. 12V Into Dually Chevy CC (Pics Inside)
  189. Who Has One ?
