PDA
View Full Version : Diesel Engine Conversions
Pages : 1 2 [3] 4 5 6 7
  1. My gas to diesel triumph
  2. Public Thanks to FTE. :)
  3. 79 gmc k2500 cummins swap
  4. Is anyone ALIVE out there?
  5. Mercedes 2.L 5 cyl
  6. Transmission for V2203 in a 91 Mazda B2200 EXT 2 Wheel Drve?
  7. Finishing up a mercedes diesel conversion, few questions!
  8. Thinking V2203DI in a 91 Mazda B2200 EXT? If I even should?
  9. International MXT vt365 swap to DT466p
  10. Mercedes OM617 makes a whooshing noise when cranking.
  11. Hopefully starting my swap soon.
  12. 1969 dodge
  13. Chevy avalanche to 6bt
  14. KUBOTA V2203DI Hours ? Please
  15. Kubota V2203DI into a 91 Mazda B-2200 EXT Am I Crazy?
  16. Swapping '96 F150 Body on 1991 W350 Dodge Cummins frame
  17. dt466 help
  18. Kubota SAE Flywheel Housing?
  19. 2004 GMC Sierra 4x4 3500 Cummins conversion
  20. Anyone in the Phoenix area?
  21. in reference to the pulling a truck out of a ditch:
  22. Swapping a 361 with a T6.354.4 in a Dodge Bus
  23. How to align AX15 Bellhousing
  24. 7.3l or 4bt?
  25. 1996 Ford F150 Cummins Swap Question
  26. v2203e to di
  27. OM617 fj40
  28. help with 2008 fummins 12v
  29. Best engine for Jeep build
  30. diesel tow rig
  31. SAE 3, spicer 3053 questions
  32. 1978 fummins help
  33. need advice / opinions
  34. swap om 606 grand cherokee wj
  35. Ford conversion
  36. Standalone shutoff solenoid for swap?
  37. Chevy Cummins Vss Issues
  38. om617 ip timing issue
  39. 1984 Chevy Cummins For Sale
  40. 16n/a vw built into a 1.9 tdi ???? help
  41. Powerstroke chevy half ton
  42. 7.3 powerstroke into a 94 chevy c1500
  43. Can someone help
  44. 2005 F-250 converted with 12 valve Cummins 6BT
  45. 7.3 issues
  46. Possible S10 Blazer Build
  47. fummins intercooler tubes
  48. Mazda MZR-CD 2.0L Turbodiesel
  49. what is the cost to build a fummins
  50. random parts questions fummins!!
  51. Cummins 4BT Bolt Interfaces and Mount drawings
  52. 1993 international 4900
  53. Putting a 6.2 into a 1962 c10
  54. Jakes Transmission Built th400 for cummins swap 86 crew cab GMC
  55. om617 jeep swap started,questions
  56. 7.3 idi part swap
  57. 7.3 powerstroke 6.7 Cummins swap
  58. cat in place of cummins
  59. 6.0 Powerstroke in a OBS
  60. Sacramento Diesel Conversion
  61. John deere 4039t ? F150
  62. Chevy S10 ZR2 4x4 Mercedes OM617 Diesel Swap
  63. Dodge 1500 4BT 4x4
  64. Jeep cherokee xj with a v2203 kubota
  65. 1997 chevy 2500 gas to lb7 duramax
  66. chevy cummins t case
  67. just another om617 in a yj
  68. First Diesel 7.3 Powerstroke
  69. 6bt swap in a k1500
  70. Koch adapter with ax15 questions
  71. injectors
  72. Cummins ISC 330-HP
  73. 1999 Ford Ranger 4x4 with yanmar
  74. 95 F350 with/460 swap to a cummins?
  75. 96 F350 cummins 12 valve exhaust manifold flip or not to?
  76. 1991 Ranger 4x4 with v2203
  77. 12V Cummins in a 2003 GMC Yukon XL 2500
  78. 2010 lmm duramax opinion
  79. MAZDA B2600 powered by Benz diesel
  80. Do you have TIPS on setting timing on Ford Ranger Diesel 2.2 perkins
  81. Cummins 12V questions
  82. Build OM 617 benz in a jeep cherokee with AW4
  83. 1998 Chevy Cummins Swap
  84. Before I get started
  85. shutting down a benz
  86. Powerstroke/Cummins engine swap
  87. engine dispute
  88. 2004 F350 Cummins conversion. What auto trans to use.
  89. superduty cummins
  90. Parts list and Steps for OM617 swap into a Wrangler YJ
  91. '72 Jeep CJ5, Isuzu 4FB1
  92. How to make a diesel conversion legal in New York State?
  93. Cummins swap?
  94. fuel pump
  95. Cummins ford swap into v10 ford fuel system ???
  96. hydroboost brakes on ford v10 cummins swap??
  97. This Would Be A Fun Project
  98. Gas 6 speed to 7.3?
  99. cummins qsb 3.3 info please
  100. Gds 60mm upgrade...good enough???
  101. Diesel scooter, single cylinder
  102. new swapper experianced modder
  103. SUPERDUTY CUMMINS NV4500 VERY LOW TOP SPEED
  104. Supercharged Scout 800 om617 Build Thread
  105. California Diesel smog loophole?
  106. 4bt in a 97 dakota 2wd
  107. 97 Cummins and 72 Suburban conversion
  108. OM617 to wrangler questions
  109. 1997 GMC CUMMINS ROLLBACK
  110. Dont exactly know where to post this...
  111. Something I always wanted to do What do you guys think?
  112. chevy cummins conv
  113. Fummins Throttle Linkage Instead of a cable
  114. 24v to 12v
  115. 2003 6.0 powerstroke to 93 12v powersteering and breaks help!!!!
  116. 7.3 to 7.3 turbo
  117. power strokes
  118. 87 W250 318 v8 to 12v cummins NEED HELP!
  119. converting a gas engine to diesel
  120. Chevy cummins for sale
  121. Ford-n-Benz blew the head gasket and overheated
  122. CONVERT 1995 47RH TO GETRAG G360
  123. 1999 v10 with zf5 5 speed to cummins 12v
  124. 85-90 dodge crewcab brake light wiring headache.
  125. 1984 CJ8 Currently Receiving OM617
  126. 93 ranger om617 conversion
  127. What we did,, Summer of 2011
  128. 1971 IH Travelette Crew Cab DTA466 swap
  129. 6-BT SAE #2 Flywheel Housing & Clutch Q's
  130. GMC flywheel for NV4500
  131. goin from a 1/2 ton 2x4 to 1 ton 4x4
  132. Mercedes om603 diesel into Chevy c2500
  133. 2004 f150 fx4 new model with max force 5?
  134. Engine/Trans advice needed
  135. 94 suburban cumminS
  136. 1996 Ford 250 5.8L gas to 5.9L Cummins??!!
  137. Diesel swap
  138. Tired of the 6.0
  139. 4BT in a cherokee?
  140. Help om617 to 88' wrangler swap!!!
  141. 10 speed road ranger
  142. ENGINE SWAP
  143. 96 chummins 2wd
  144. Speedometer help with np241!!?
  145. perkins in a ford p/u
  146. 84 ford bronco 2 and 04 f150 triton v8
  147. diesel for a 79 cherokee chief conversion
  148. SPEEDOMETER FUMMINS HELP !!!
  149. Cummins Swap
  150. om617 with ax15 into 2wd s10
  151. 12 valve mount dimension
  152. From the field to the street
  153. 93 chevy 2500 6.5 to 12 valve cummins swap
  154. 48re shifting
  155. Cummins conversion on the NBS
  156. Conversion 94' 7.3 L non turbo to 97' powerstroke
  157. sources of kubota motors used pulls rebuilt
  158. Caterpillar 3208T in a Dodge Ram frame...
  159. M38A1 Kubota V2203 engine swap
  160. Bought 12v 5 speed - Need Advice on Swap Vehicle
  161. 4bt or 6bt into 1990 k5 blazer?
  162. Need help with PCS/E4OD calibration
  163. Which engine in this 4x4 ford Van?
  164. 6.2 diesel in an s10???
  165. 5.9 Cummins into 76 Chevy
  166. Om617 not wanting to start hot
  167. 1996 F150 Frame Question for 6BT Swap
  168. FOR SALE: 1995 powerstroke engine, ZF5
  169. 1995 f superduty (450) 12v cummins p-pump install
  170. Intercooler size Question...
  171. 12v swap into 2001 HO 6 speed wiring/PS/AC questions
  172. Cab & Chassis
  173. chevy cummins with 4l80e
  174. Late Model GMC 2500 engine swaps?
  175. What Cummins?
  176. 6x6
  177. 1987 f-150 conversion to 4bta?
  178. international truck with john deere engine
  179. 2500 cummins swap
  180. 1/4 ton Nissan Diesel Conversion
  181. Kubota tractor powered aluminum Jeep
  182. 1970 F100 w/an International D301
  183. ZF5 to a NP205
  184. 06 Tundra Crew Cab Cummins 4wd
  185. 1997 f250 nv4500 tranny mounting questions
  186. cam
  187. auto to manuel cummins
  188. New Guy.... Needs Advice...12v into 1984 1 ton.
  189. Gearing / speedometer question
  190. Rockwelled F-150, Motor swappage..?
  191. Wanting to drop a Cummins into a '77 Econoline
  192. any idea about diagnostic tool?
  193. 1974 Ramcharger Cummins swap
  194. om617 turbo upgradee
  195. 12valve P7100 in a 1500...
  196. DT466 hot rod with Allison 545
  197. 2003 f350 12v swap water in fuel light?
  198. Mileage question
  199. superduty 5.9/8.3 cummins swap.
  200. 1978 F350
  201. 2005 f350 gauge cluster
  202. 2003 F350 12v Swap wireing questions
  203. Chevy or Dodge intercooler for swap?
  204. t case for nv4500
  205. 02 Ford Cummins?
  206. OM617 or other possible engines : '87 D50 Dumptruck
  207. 12V Cummins into an '04 F350 gas... worth doing?
  208. 59 Chevy/Cummins
  209. linkage
  210. truck gone
  211. Best recomendations for a tach and any other gauges I need?
  212. cummins zf5 harmonics?
  213. 2005 F150 4BT Swap
  214. Adding turbo in 4d68 Mitusbhishi Naturaly aspirated Diesel engine
  215. How beefy is that front end?
  216. 47 RH issssssues!!!!
  217. DT466 build
  218. Clutch Pedal and possibly brake pedal
  219. 89 Jeep Cherokee Mercedes 606 Diesel
  220. 53 GMC Panel Mercedes CDI Diesel
  221. Conversion question
  222. 1985 4Runner to MB OM617.950 turbo
  223. 99 jeep cherokee 617 swap
  224. Building a 79 f250 12v cummins
  225. Ford Cummins swap test drive
  226. 78 Fummins build
  227. destroked or fordcummins
  228. f350 auto to manual
  229. 5 speed cummins swap
  230. diesel swap
  231. diesel swap
  232. diesel swap
  233. Intercooler piping/tubes
  234. 1984 chevy 4x4 dually 12v conversion
  235. gas to diesel swap
  236. 97 to 99 powerstroke
  237. 1999 dodge ram 2500 12 VALVE
  238. can u add the turbo of 4d68 T engine in non turbo 4d68 engine
  239. Converting to diesel?
  240. Converting to diesel?
  241. Easiest way to swap with lifted truck...
  242. OM617 in a Honda Odyssey, or similar?
  243. Fitting Turbo in Mitsubhishi Lancer Diesel (India)
  244. Chummins or fummins?
  245. cummins in a chevy 3500
  246. 1939 Chevy and 460 IH
  247. Cummins 3a1.7 in dodge d50???
  248. Which tcase, 271 ford vs 241dhd?
  249. Need input on building a go kart using a three cylinder yanmar
  250. Vacuum and Power steering pumps
