PDA
View Full Version : 1st Generation Dodge Cummins 89-93
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. Finding fuel pin and 366 spring
  2. 366 spring ?s
  3. ram air intake horn?
  4. Disc brake conversion, issues three years later.
  5. rotary pump dripping fuel
  6. transmission thoughts and ideas
  7. 1993 cummins ext cab 35'' tires fit?
  8. 1993 350 cummins question
  9. in need of some transmission help
  10. Getrag plus NP205 question
  11. how freely should the turbo spin
  12. 91.5 hy35 and pump tweaking question
  13. Hx35 turbo
  14. Bumping my timing. Help
  15. Is this a good deal?
  16. Steering Wheel swap?
  17. Fuel pin
  18. 93 cummins idle issues.
  19. 1st gen motor and tranny in 2nd gen gas
  20. More power
  21. In need of a roof!
  22. Vacuum pump oil leak
  23. A/C fix up...
  24. Auto Transmission slow shifting?
  25. under cooling in my cummins swap????
  26. Common Airdog problem or something else?
  27. Maximum safe boost?
  28. Tranny noise
  29. Starter button tech...
  30. rear axle swap
  31. The "Dodge Pile" is busted
  32. Finally bought my first one
  33. O/D Help!!
  34. Pump help!!!
  35. 60 mm turbo upgrade question
  36. hx40 vs s300
  37. What is this ??
  38. cc for 91 dodge
  39. Advice, Opinions, ideas
  40. I need help finding gauges.
  41. Best exhaust break?
  42. Throttle switch for exhaust brake
  43. should i trade my 2nd gen for this 1st gen ?
  44. 92 died while driving, only has power to headlights
  45. Gov spring
  46. s300
  47. 1990 #2 cylinder exhuast port is wet
  48. 92 1st gen steering problem
  49. MPG to be expected with a 47rh
  50. Cummins D250 overdrive problems
  51. I want smoke when I really get on the pedal
  52. Turn signals got confused...
  53. t3 or t4?
  54. help with new injectors please
  55. starting a build, any recomendations or tips appreciated
  56. Why is my automatic not getting expected power
  57. New m&h parts, which ones first
  58. Strange noise cannot pinpoint.
  59. Intercooler in 1st gen
  60. EV2 Gauge problem
  61. AAAWWWWW MAN!
  62. Non intercooled 1st gen hx35 hybrid
  63. Speedo problems
  64. Exhaust
  65. Need help with pulling engine out
  66. Smoke
  67. Trans length question
  68. Learned a valuable lesson about changing oil filters
  69. Why can I not find any AC hoses for a 91.5+?
  70. Retaining the stock Over Drive switch function
  71. Turbo/intercooler elbow
  72. Project Vinnie
  73. 2nd Gen Fan and Clutch on a 1st Gen?
  74. 93 fuel issues
  75. hx35W housing on ebay
  76. 47RE trans not going into fourth gear NEED HELP
  77. gen 1 non-intercooled questions
  78. Help me please
  79. Hy35
  80. LMC for First Gens
  81. smoke screw-how many turns?
  82. Turbo help
  83. Broke a bolt on my VE pump
  84. Air conditioner issues
  85. Trying to find gauges.
  86. Wanting to buy a 1st gen
  87. question for you guys
  88. Allison do not shift problem..
  89. lowering my truck
  90. 73 International Travelette-Cummins-First diesel build
  91. 91 Non Tilt Conversion to Tilt Steering
  92. a518 to nv4500
  93. HX52 turbo
  94. First gen super b turbo help
  95. 1st gen 2nd gen hoses
  96. Trying to replace wheel cylinder
  97. d150 cummins swap
  98. Relay overheating
  99. Cummins and ford?
  100. Large Plastic Tube Coming Out of Engine
  101. 94 gas 2500 series dodge to 89 diesel
  102. Gov and Pin change problems
  103. Another auto to manual...
  104. Serious transmission issues
  105. Can I list my truck for sale here?
  106. coolant hoses
  107. Diesel Auto Power injectors
  108. Valvesprings
  109. Crew cab swap
  110. Tilt Colum
  111. Think I broke my clutch..
  112. Hx35 questions
  113. looking at a 93 one ton 2wd
  114. Broken speedometer on '91 Dodge Ram 350.
  115. Injector pump...
  116. transmission identification
  117. BD or DDP injectors?
  118. lift pump benefits
  119. grille frame?
  120. triple turbo
  121. Charging Air Condition
  122. LUCKY !
  123. Cooling Fan?
  124. EMERGENCY!!!!
  125. 91 CUMMINS
  126. idle problem
  127. too quiet
  128. Gauge Mounts
  129. Battery over heating
  130. 1992 D350 Torque Converter Locking/Unlocking .... Impossible Non-Lockup Tranny
  131. Transmission identification
  132. Upkeep
  133. Brake Fluid Leak
  134. 4BT drag car
  135. Would a trade be crazy?
  136. truck is gutless now
  137. Need help diagnosing?
  138. By-Pass Filter
  139. Steering loose
  140. 93 cummins tuning
  141. Speedometer question?
  142. first gen fenders?
  143. good first gen air intake???
  144. parked the cummins for 12 hours now it wont start
  145. Vibration and Grinding
  146. my B-day present.
  147. 91.5 Intercooled not charging. no start. no crank.
  148. Replacing Fuel Shutoff Solenoid
  149. Speedometer gear in Getrag?
  150. Help figure this out?
  151. Bucket seat foam
  152. Air intake is to low
  153. Change out distribution block after disc brake conversion
  154. 93 dies when clutched after high RPM
  155. Getrag Clutch
  156. 93 cummins only clicks
  157. correct way to body lift
  158. single stack kit
  159. Lift for 91??
  160. 1987 12v cummins no start issues
  161. Charging issues
  162. New with questions!
  163. Fuel Tank
  164. RPM Tach
  165. what gear end ratio was in the d250 2wd 91.5
  166. put on an external voltage regular no i am having wierd issues
  167. 5 spd swap tranfaer case problem?
  168. how to identify wht year my engine is.
  169. 93 cummins no power to anything
  170. Fuel Prime
  171. those of you with a p pumped first gen please help
  172. Looking to buy a D250. Help?
  173. smoke screw/ star wheel
  174. Axle Wrap??
  175. Getrag input bearing
  176. Speedometer and VSS questions-
  177. 93 Cummins 3.54 Gears 60MPH Max Issue
  178. new lift pump suggestions
  179. Turbo problem?
  180. Passenger side window
  181. 92 cummins auto won't hold 100 km/hr
  182. Help with gauge cluster lights
  183. Pump Timing
  184. 1989 12 Valve leaking injector
  185. Wh1c cold side
  186. tachometer install
  187. Injectors
  188. Replacing Lift Blocks
  189. Truck won't start
  190. Door Speakers?
  191. 76 dodge
  192. Head Gasket failure check?
  193. P-Pump swap
  194. Diamond Eye and adjustments
  195. Front driveshaft issues
  196. 89 Dodge 1 ton 4x4
  197. getrag 2wd to borg warner 4401
  198. wipers wont shut off after over charge
  199. 1991 dodge ram 250 cummins not charging battery
  200. afc/manifold issue
  201. RustBucket Teaser Pictures
  202. made up my mind. now what?
  203. shifting into overdrive
  204. 1993 d350 hot shot rig?
  205. Death Shake in Rear End!
  206. waste gate
  207. Some questions
  208. hx-35???
  209. Tail Light wiring
  210. KSB leak!??!??
  211. Freeze Plug size ???
  212. Suspension and stuff...
  213. external voltage regulator charging at 24volts .... help
  214. New master cylinder
  215. Hx35/injector combo
  216. 1991 dodge ram 250 diesel
  217. Whats the difference??
  218. .040 piston pertrusion
  219. Radiator Options
  220. Common rail MLS head gasket on a 12 valve???
  221. I NEED OPINIONS!
  222. two questions
  223. cummins gaskets
  224. Part interchanges for 1991 power ram
  225. cummins swap
  226. MORE POWER?
  227. just a couple of questions
  228. 1992 with a p pump
  229. Seat swap
  230. Borgeson steering shaft
  231. Call me crazy.... 24v head?
  232. rear diff pinion seal
  233. Power estimate
  234. Need help with brakes please
  235. Daytime running lights
  236. help no wait to start light no start
  237. Another how much is this worth thread...
  238. VE rebuild
  239. '92 Cummins in NPR.
  240. NV5600 swap
  241. Need New Turbo
  242. h1c mod
  243. Need More Air
  244. OVERDRIVE PROBLEMS
  245. HX35 TURBO????
  246. bleed in fuel filter housing??
  247. "New" Truck and New to Diesel!
  248. Need input: 2nd gen body on a 1st gen frame
  249. Need help cummins smokes wont start, injectors are getting fuel
  250. New VE for my 89 :)
