PDA
View Full Version : 24 Valve 2nd Gen Dodge Cummins 98.5-02
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
  1. luke warm heat
  2. 01 Clearence lights
  3. clips for factory fog lights.
  4. 98 24V cummins alternator external sensor
  5. 01 dodge@idle/ need help
  6. NV4500 Mystery Noise
  7. Military 37s on a dually
  8. Quadzilla adrenaline 4k tunes help
  9. Dana 80 Rear Probs
  10. New FASS installed, engine vibrates
  11. 53 block cracked
  12. 47re Hp and Tq
  13. rv275
  14. In take air fooler.
  15. weird???
  16. open egt thermcouple
  17. ECM replacement source help. 1999
  18. 01 24 valve slight surge on highway?
  19. 2001 Steering and suspension
  20. Fuel pressure
  21. 2001 dodge 1500 sport convert to dually
  22. TC Lock-Unlock/engine stalling problem!
  23. Anyone tried a T-46 Turbo?
  24. Coolant leaks and temperture fluctuates
  25. control arms
  26. Detroit locker
  27. delayed shift on rebuilt transmission
  28. Can someone tell me what a brake controller does?
  29. lift pump?
  30. ENGINE/TRANS SURGE AT 55MPG
  31. Anti theft
  32. alt. surge
  33. radio issues fix
  34. 2001 47RE
  35. Stumped on a 5.9 code P0341
  36. Long going stutter/bucking problem just eliminated!
  37. Brakes??
  38. IP???
  39. Heater Problem
  40. 94-99 fuel tank
  41. edge smarty stack questions
  42. 3.54 to 4.10
  43. turbo time
  44. 99 24v dually spewed all its trans fluid
  45. 2001 dodge diesel
  46. Hello 99 trans!! any suggestions
  47. 01 lockup switch
  48. New gauges
  49. They say real trucks rattle, but I dunno.
  50. 1999 Dodge 2500 "No Bus" but gauges work except voltage?
  51. 99 high idle?
  52. 2002 24v shifting problems
  53. 1998 Cummins Power problems
  54. dana 70 diagram
  55. dana 60 fluid?
  56. Cold Start Idle Haze - Thoughts
  57. Converting dually to single wheel
  58. Heater Grid Relay
  59. Harmonic balancer ???? Maybe ?
  60. 35s with leveling kit??
  61. 2001 cruise control
  62. 2001 5.9
  63. 2001.5 4x4 Quad Cab Short Bed 6spd For Sale
  64. 99 Cummins Problems
  65. Strange plugged fuel filter
  66. 01 cummins fuel gauge questions?
  67. temp gauge fluctuates
  68. 2001 cummins boost promblem
  69. 01 cummins knock
  70. shift knob replacement
  71. 01 cummins low fuel sensor question
  72. swapping 12v block into my 24v
  73. Hard spot in throttle then will not shift from 1 to 2 gear wtf !
  74. New to the forum
  75. Banjo Bolts
  76. transmission?
  77. My motor makes a very strange noise after it high ideals for a minute
  78. power steering pump
  79. 99 sport build
  80. New to the forums and need help!
  81. Should I change my head studs or head gasket now?
  82. Need help with locking brakes
  83. Red hot alternator
  84. Vp going bad?
  85. 2001 Cummins Cold Start
  86. Cold heat
  87. APPS or VP?
  88. Pac break question
  89. wheel fitment
  90. Transmission fluid change 47re METAL PIECES FOUND
  91. Idles fine in park and neutral but in drive it stalls
  92. Stacked on quad
  93. Truck has misfire????
  94. 99 stock turbo upgrade
  95. i need transgo shift kit instructions
  96. Factory lift pump wiring harness missing ???
  97. 125hp Edge Injectors??
  98. lift pump?
  99. Fass install
  100. 235 vs 245 Engine
  101. blowing fuses
  102. Schied diesel vp44 and injector questions
  103. Farm boy injectors??
  104. my first oil change.
  105. 4 codes
  106. Grid heater issue.. Help confirm my thought
  107. transmission!
  108. chicken lights
  109. Quadzilla vs.??
  110. need to find a way to worm my truck up quicker ? high idle switch ?
  111. odd smell
  112. high idle
  113. Rpm spikes and no Alt charging
  114. dodge wheels
  115. Banks High-Ram intake install gone WRONG. HELP!!!
  116. HELP LEAKING INJECTOR LINE
  117. 2nd gear slip
  118. Dead Peddal?
  119. 47RE tranny problems
  120. Weird Sound? Annoying!
  121. transmission problems
  122. Map Sensor Testing?
  123. Random loss of power while driving
  124. How to remove this nut??
  125. Turbo problem?
  126. Best turbo and injector upgrade
  127. Intermittent Cruise Control Problems
  128. Fuel Gauge doesnt work after DS1
  129. smarty / edge settings
  130. np241 vs 241dld
  131. need immidiate help with removing dash!!
  132. 24 valve question
  133. Repair kit for 98.5-02 VP44 Electronic Control Unit
  134. Time for injectors.
  135. mpg difference between 6 speed and 5 speed
  136. trouble adjusting new anzo headlights
  137. Freezing 24V Cab. Best way to warm it up?
  138. ddp 110 hp injectors
  139. 2002 cummins 6 speed transfer case oil
  140. Bad miss,white smoke
  141. Water separator smells like gas?
  142. smarty
  143. Vp 44 pump connector
  144. Tow Hooks
  145. blown codes
  146. 99 2500 Cummins MPG low?
  147. Speedo Problem!
  148. advice/opinion(s)
  149. Water in passenger floorboard
  150. Water in passenger floorboard
  151. 100 RPM spikes, trying to shift?
  152. Oil leek from gasket?
  153. Airdog Filters!
  154. Loud knock when cold, goes away when warm
  155. Programmer help
  156. need pic help
  157. OverFlow Valve
  158. oil leaks
  159. Injector advice needed
  160. Free spin hubs, yukon vs spyntec vs dynatrac
  161. DEAD PEDAL DRIVING ME CRAZY HELP
  162. Feedback on this boost elbow
  163. phatshaft 62 internals?
  164. Stumped on this 24 valve
  165. 1999
  166. fuel filter housing leaking again!!
  167. Shifting Issues
  168. phatshaft boost elbow issues
  169. Temperature fluctuation :jigabop
  170. Auxiliary fuel tank install tips
  171. BHAF options
  172. Electrical starting problems
  173. help!!
  174. Head studs or no?
  175. 24v cooling system problem..very wierd..check out!
  176. 1999 cummins better mpg?
  177. coolant leaking threw headstud after retorque
  178. turbo upgrade
  179. 5.9 upgrade
  180. 99 supply pump problems
  181. u joint catastrophe
  182. 2001 24 valve injection pump?
  183. SHOULD I TRADE MY 24 VALVE
  184. Outerwear for Amsoil EEAU 4090
  185. gauge differences
  186. Clutch sqeaks and oil temp
  187. Noises when hitting bumps
  188. Egt readings?
  189. Bad Heater core or t-stat?
  190. Looking into to clutches
  191. Lift Pump?
  192. Quadzilla repairs/modifications
  193. 24 Valve Rough Idle/miss
  194. 01 cummins hard starts and has thin oil?
  195. burning oil
  196. Fuel pressure gauge install?????
  197. Fuel pressure gauge install?????
  198. boost question
  199. No start, anything but a vp44.
  200. HELP LEAK
  201. P0720 Help Please
  202. Keyless Entry
  203. Stacks???
  204. need help now!
  205. alternator diodes, torque converter, vp 44
  206. Who Has done the Most 24V Motor swaps...?
  207. 98.5 Cummings 3500 high idle?
  208. surging fuel pressure
  209. valves
  210. APPS, ECM, or what?
  211. timing question
  212. fuel presssure gauge
  213. Injector Chart Understanding please
  214. Sad News
  215. 2000 Ram 3500 Fog Light Help Needed!!!
  216. TURBO SUGGESTIONS
  217. Is this a good price for 2001 dodge 2500 diesel?
  218. CRANK SENSOR!!!???
  219. truck fixed, finally
  220. Turbo Gurus - - need input
  221. Fuel Pressure Gauge with a FASS question
  222. Injectors
  223. anyone running bd super b twins?
  224. single to dually
  225. 1999 cummins exhaust tips
  226. fass lift pump intall help
  227. Problem with it cummin!!
  228. 1998.5 24v installing a fass pump need help
  229. fuel del. issue
  230. turbo boot wont stay on!
  231. New truck/tranny problem
  232. what turbo do i have?
  233. 98.5 hole in block
  234. Engine chirping
  235. Intermittent power loss
  236. 98.5 to 2001 swap is it possible
  237. yellow check engine light
  238. 2nd gen 24v shrieks when I shut it off
  239. Cummins acting funny
  240. 2002 24v water will not.drain.from fuel filter
  241. Wat to do with a one ton
  242. 360 to cummins swap
  243. Need help fast
  244. donaldson oil filter
  245. Piston protrusion
  246. High idle issue and WTS light not coming on
  247. truck wont start
  248. Advice for purchase on 2002 2500
  249. More Power? Auto vs Standard?
  250. What's next?
