- 05 DURAMAX COOLANT PROBLEM
- Keep the EGR cooler or do away with it on my 6.0 PowerStroke
- advice wanted need to narrow this down before upgrades are attempted
- electrical issue
- Gray and white smoke coming out of tail pipe
- wont start p0645
- F 250 6.9 reddog water leak intake manifold gasket
- 04 F-250 w/oil in the coolant
- wheel bearing hub assembly. 4wheel ABS vs non ABS
- 83 6.2 ran dry need help priming
- starter soliloid fuse keeps blowing
- First Gen Running Rough and Popping through Air Filter
- Help! My automatic transmission is stuck in first gear, no upshifting!
- RH valvebody in RE?
- HELP!!! Leaking diesel from injectors or rail
- broken valve pedestal bolt
- Vacuum problems heat/air con
- temp guage sporatic reading
- still having problems.
- 7.3 only idles
- 07 48re problems
- Timing cover?/ Timing?
- AIR DOG ISSUES, HELP!!!!!!!!!!!!
- Whits Cummins is down
- 05 cummins no start
- Carlisle, PA - need repairs - on the road!
- 6.5 acting up PLEASE HELP!!!!
- Turbo rebuild?
- Bombed 12v non-consistent miss
- fuel problems - 2000 7.3L
- 97 PSD CHUGGING N SMOKING
- 92 dodge cummins pcm help
- Engine Died, need help asap!!
- Thought it was the starter but...
- Track bar bolt
- Truck Died On The Way Home
- bad oil leak
- converter issue? please help
- 98 Ram, lost TCC
- need help 03 cummins wont start
- 95 7.3 Powerstroke Overfueling Bad
- 2004.5 dodge 6speed cranks wont start
- Well I'm not worried yet
- HELP I have a Radiator problem in my 98.5 cummins
- HELP!!!
- 96 ram 2500 4x4 clicking sound in 4x4
- 92 d250 (wait to start light stays on)
- fuse panel problems
- 7.3 no start when cold
- oil & Antifreeze blown out of intake
- air bag light
- wiring 7.3l
- E4OD blown
- 7.3 cranks but does not fire
- no power
- 2000 powerstroke 7.3 misfire or sputter
- 99 F350 no acceleration
- Electrical Fire will not start
- temp gague is weird
- ICP Problem?
- fuel problem, cummins
- Hot wire my truck!
- 01 dodge cummins smoking??
- engine running hot, but not overheating! help
- LEAKING OIL AT GLOW PLUGS
- overdrive problem
- 88 7.3 ran out of fuel, cranks, won't start.
- shake and smoke
- 02 f450 starts, runs great, dies after 15-25 mins
- Automatic transmission
- new clutch! need a slave?
- 2004 F350 6.0 Won't start Need Help
- 03 Won't stay running!!
- Steering Wheel Noise???????
- Algae?
- need exhaust wheel for stock turbo
- changing ball joint
- bad fuel???
- 6.0 Dead After EGR Cooler Repair
- 95 e350 NO START!
- wastegate solenoid (a) problem
- Locked in 4x4 and got a long drive.
- 6.9
- PCM harness connector position
- Oil in radiator
- n14 celect cummins 525hp
- 1993 dodge diesel automatic
- 12valve starting issues
- 98 24v pcm problems
- Cummins. Dead pedal?
- brake lights
- Manual transmission problems - uhoh
- 12v Not starting
- spraying fuel
- 1996 6.5 chevy quits
- '83 GMC 6.2L not chargng battery's
- NO REVERSE!??!
- Help Please Dies while driving normal?
- HELP!!! truck starts, but barely moves
- honk wtf
- 01 pcm in a 98.5 dodge??
- the return of the dreaded death wobble
- speedometer still not working
- '99 7.3l won't crank
- Fuel Problems
- exhaust system of 1999 Dodge Ram
- Transfer case thumping?
- thermostat removal
- power steering/brake(hydroboost) problem
- coolant leaking as fast as i can pour it in
- injector help
- funky brake problem
- 85 6.9l died wont start
- Service 4WD light problems 02 Duramax
- Need some help '04 dodge cummins 3500
- F350 starting issues...
- i need help!!!
- cutting out
- puking coolant
- outside temp big problem
- 7.3 IDI wont start
- Power steering issue...?
- loud rattle at idle
- 2003 cummins won't start HELP please !
- 03 F-350 Diesel turn key no action
- speedo in distress!!!!
- mayday,mayday
- play in driveshaft... transfer case maybe???
- 1998 Dodge 2500 12valve
- 91 7.3 IDI
- temp gauge not reading?
- 6.2 HARD START ROUGH RUNNING HELP
- 6.2 runs rough hard starting
- head lights blink after 30 min
- Need help w/ my 6.0
- Airbag light just came on
- 7.3L f-550 2000
- Need help tranny problem
- powerstroke wont run under a load
- Truck wont start how do i check the cp3
- Blue smoke....
- NV4500 - NV5600 Questions!!
- something wrong in the front axle.
- 05 dodge 48re 1-2 shift problems
- Iveco cold-starting issues, glow plugs?
- powerstroke no wait to start no tack
- Cough, choke, puke
- wont start when engine warm
- Help smoke/boost/power/ASAP
- 4wd grinding... whats your thought?
- the dreaded powerstroke no start cold
- 96 chevy 6.5td wont shift autotrans
- speedometer not working
- first got an oil change
- 01 Cummins not heating!!!
- F350 7.3 smelling Rich
- 4wd on 1999 Ram 2500 won't work
- dtt shift enhancer blinking
- Check engine light, 2001 7.3 turbo
- cold no start
- Too much oil>>>>>>>>>>>>
- Cummins wont fire. Need help ASAP!!
- 2004 f350 diesel problems
- 1995 dodge won't go into 4 wd
- 99 F350 won't stay running
- 48 re sensor
- fan for heat and cold air shuting off???
- injector pump leak
- 02 Cummins cutting out
- 7.3 Ford, battery keeps draining, now no juice
- no brakes no steering !!
- 03 sd 6.0 wont start
- somethings broke, and idk what
- o3 cummins wont start
- dead pedal no codes
- blew diesel fuel heater fuse
- Powerstroke won't start when warm
- Safe to drive untill fixed??
- 04.5 Cummins Hesitates off idle/Hard to Start
- 06 Dodge hunting for gears
- p2121 p2127
- 2003 Cummins with Tranny Trouble
- Anyone in Phoenix area available to install 7.3 drop in engine?
- 01 dodge cummins surging problem
- 6.4L DPF Delete Tuner Programmer 08 F-350
- Need a little help again please!!
- 5 speed trany
- 6.5 head ache, won't start
- 93 GMC 6.5L Turbo, sticking valve (or lifter)
- I need a new FICM for my truck...
- 03 Ford 6.0- idles bad/shakes bad @ 40+mph
- 1999 F250 7.3 PS Will not run more than a minute or two before dieing.
- ford 7.3 diesel powerstroke blowing fuses
- Starter Will Not Crank Just Clicking
- workhorse custom chasis
- trany going out
- Turbo spooling no psi?
- soleniod problem on glow plugs
- 1993 Dodge Ram 5.9 wont start
- White smoke
- 7.3 Leaking Diesel
- 98 Jetta AHU Problem Code 0575
- '04 6.0 liter black smoke/rough run now won't start
- trany will not stay locked up
- vacume pump
- truck wont start help
- runs.. then dies.. then runs fine
- puzzled, 85 6.9 barely cranks
- 03 psd wont start
- omg my poor 01 cummins
- Weird behavior after sitting for 5 weeks without power
- The dreaded death wobble
- 95 powerstroke no HPOP pressure
- 99 FORD with start problems
- turbo on 12 v cummins
- 93 cummins auto trans no overdrive
- Wastegate????
- 24v motor swap issues
- 96 dodge wont start
- 24v possibly valve adjustment/broke pushrod??
- 1999 dodge accessory plug fuse?
- Transmission problems
- HELP
- loose #6 exhaust rocker valves and pushrod
- Grease Converted 1995 Ram2500 CTD Hard Starting, Idle Stalling, and fluid sloshing
- What the heck is this?
- 03 duramax lb7 light white smoke at idle
- 2001 cummins low power!!!
- Need help bad
- 48re headache
- No Transfer case in Hayes, KS
- Bad fuel milage, too much oil, cracked injector body?
- 6.0 wont get up and go
- 1992 f350 7.3 won't start
- more problems
- ehh got some codes
- 95 Powerstroke surging on startup.
- Code PO254 and TST PowerMax3 On 98.5 Cummins
- 1990 7.3 hard starting cold
- leaking fuel injectors
- bluish white smoke
- '98 Ram 3500 with no 5th gear
- thermostats
- head gasket
- smoking and missing 92 cummins
- what could this be?
- help
- 7.3 4R100 tranny not shifting 3-4 until warm
- 1990 7.3
- wont idle and pours smoke
