- injectors
- Compound Turbo set up
- Injector questions.
- truck ideling high
- Lucas Prince of Darkness POD injectors
- scheid diesel 60 hp bosch injectors?
- Banks??
- over drive in a automatic?
- First Gen Gov. Spring
- First Gen Boost
- run away question
- VE Pump tuning
- fuel line upgrades
- what hp more hp out of 89
- strait pipe?
- pods
- Power Upgrades for an Intercooled 1st Gen
- How hot is too hot?
- Looking For Some Extra Power
- 2nd gen radiator in a first gen
- Low Pressure Piston Lift Pump
- boring out a motor
- BHAF and Old Smokey mount in the works
- Trip to Virginia and the 366 spring
- Need advice on hp upgrades
- dual 4" exhaust with 6" tips
- Star wheel
- Injectors
- One Way to Install A Powerstroke Intercooler
- KDP, wrong gasket
- 05 head gasket on a 93
- turnin up my 91 cummins
- nitrous to propane???
- Kickdown
- 14mm or 16mm turbo housing
- Fuel Screw Loc.
- Finally Found A Roll Pan
- hx40? to BIG?
- BD Super B Turbo
- Call Me A Bottle Baby If You Want But It's Nitrous Time
- 3200rpm Spring Install
- Turbo applications
- turning the pump up
- Walbro 392 Electric Fuel Pump And 3/8" Fuel Line Install
- ASA Modified's CAI.....
- No faith in the VE pump
- C.R. turbo an upgrade for 1st gen?
- grinding the fuel pin
- Stuff Is Falling Off My truck Again, This Time it's The Turbo
- AirDog Dodge FP-100-150 1989-1993 Install Manual Rev. 3-3-09
- Tow rig bombing
- first gen showin up a chiped 6.0
- 600 hp first gen
- first generation slide show
- injectors
- Idle adjust
- what tweaks can i do
- transmissions Promblems
- Fuel Pin Pictures
- Getting Full Throttle Out of Your VE Pump
- Stuck fuel pin
- Rollpan
- Cobra stage 4 twin turbo
- After Market Tach Install and In Dash Gauge Mount
- fuel pin question
- Denny T Stage II Fuel Pin Review
- Injectors
- Suggestions On Which Injectors To Buy
- Pullin Power
- 1st Gens Suspension Wise
- Gov Spring Numbers
- H1C/H1E Hybrid... Lets Call it the H1D...
- Trying To Figure Out The Mod Path For My Dodge
- VE PUMP RELIABILITY
- Reducing Vibrations On A 91 Cummins
- VE pump does not like -76 degree temps
- Got The POD's in... HELL YEAH!!!
- Cheap Nitrous Kits - Budget Nitrous
- H1C/H1E Hybrid
- 1989 Dodge Ram - VE Pump Tweaks On The Cheap
- Cut Fuel Pins....
- 12 Valve To 24 Valve
- VE Diesel Injection Pump
- Part Numbers For 1st. Gen Trucks.
- hx-35 swap
- Aeroturbine
- SMOKE
- VE To A P-pump
- 89 12v High EGT's
- 12 valve questions
- Trans temp
- Turning Up A '93
