- 07 transfer case gears grind
- What should I do? Help needed!
- Cummins 6sp manual noise
- help needed
- new ecm on its way...........$$$$$$$$
- Please Help Generating HP without compromising fuel mileage
- Axle Replacement
- Horrible Knocking Noise
- 2004 or 2004.5 ? cummins buying injectors
- Transmission surge
- 2006 intermittent rough idle
- New guy with questions
- Indicator light help?
- Air bag light on and off randomly
- 07 6.7 problems
- New 2006 cummins
- abs still comming on help please
- smoke while idle
- cp3 help
- throwing code after juice with attitude install
- Where can I find the A/C hose assembly?
- lift pump question
- Removing a Smarty JR?
- swaping a 47re for a 48re
- Exhaust Routing
- Modified Cummins Towing MPG
- banjo fitting seals
- number 6 cylinder
- Trouble Starting - runs fine
- Changing the serpentine belt on an '04 help!
- Need help White smoke at idle Loss of oil pressure
- Full throttle = neutral ??
- abs and break light comming on
- 04 Tranny Wont Shift! Need Help ASAP Please!
- Stock Turbo Question
- Another new guy in need of guidance!
- Vibration Noise?
- sway bar links??
- '03 Dodge WON'T START...Need Your Help
- drive shaft hanger bearing
- 06 Electrical gone crazy(TIPM)=Shelled Tranny??
- Error code and warning messages...answers?
- 05 Dodge 48re Tranny
- Fuel Pressure Drop Need Help!
- leaky injectors
- Low Power Issue
- Replacing Injector Connecting Tubes
- manufacturers warranty
- how about this one here
- anybody with an 2007 5.9
- about a quadzilla xzt 2
- 2004 CTD loses power and/or stalls
- Hour meter
- 03 CR rough idle
- 2005 Dodge 3500 5.9L wont start
- dead pedal now stiff pedal
- dodge tranny
- wheels
- Blue smoke @ start up ??
- Cp3 problems
- 2005 3500 won't start just cranks
- suspension.....
- code thrown need to kno what it means any help plz
- need info by tomorrow please
- fuel leak "help"
- compounds?
- lag??
- Mighty diesel
- Smarty jr and mp8
- mud tires for 19.5 rims??
- shocks?
- Boost fooler
- School me on Turbos !!
- My 04 won't smoke
- first start up?
- exhaust and rims
- stock dually rims upgrades???
- 03 cummins HO wont smoke
- WTH is wrong with my truck! HELP!
- Code P0336 and P0480 Help Please!
- What's the best ball joints
- turbo question
- HOW DO YOU ADJUST MANUAL WASTEGATE
- trying to buy this 05
- Enough talk, got the free spins
- What does it take to run 13's
- CPS location?
- Trading up !
- Where did you mount your Airbag gauges?
- gauges gauges gauges
- Nv5600 Parts Questionably??
- Transfer case output / driveshaft...
- Crank Sensor Function?
- edge evo for sale
- help. broken output
- starting problem
- problem with buddies 03
- Major Fuel Mileage DROP Dodge Cummins
- looking at a 2005
- Transfer case selector?
- Cab swap question... Quad to regular
- High EGT's with a edge
- fuel limiting valve 05 3500
- Injector Problem?
- 05 Cummins with 03 long real Smokey?
- Smarty S06 POD tuner for sale! $525 shipped
- banks Iq Software
- new clutch
- stuck valve
- Need Help, 03 5.9CR, no power
- 2003 diesel 5.9 wont start unless I plug the heater in
- Priority A Preventive Maintenance
- which intake manifold
- 06 bad injector and accelerating on its own
- BULLY DOG X BANKS IQ X CHIP MOD
- Need help!! cummins input shaft help
- WVO conversion to Biodiesel
- trouble code p0191
- badlands
- 2nd fuel filter mod?
- air cleaner tube size?
- Seized FCA Screw Thread
- 07 5.9 issue
- 05 WTS light on and no power
- Can someone help with info about manual wastegate 2005 cummins
- question.
- Silencer ring
- valve lash setting
- bad fuel mileage......?
- dyno ?
- lookin for a new tuner
- Funny noise coming from auto trans (48re)
- Leaky injection tube.
- New turbo
- edge w/attitude and power puck stack question
- PLEASE HELP
- 4wd stuck!!
- Help please
- Phoenix friction performance clutches?? Valair??
- anti freeze smell??
- thinking about getting a 4x4 6spd 2003 common rail.. talk to me
- 2005 dodge 3500 diesel/6 speed manual burning oil can;t figure it out
- Rpm surge between shifts
- Take care of your cummins!!!
- Need help/Advice
- oil pressure question
- # of injection cycles?
- torque converter questions
- edge attitude stacked with quadzilla?
- Dropped second gear, list of upgraded parts since going into the trans?
- what style and size of single black stack
- Rear end leaking fron drive shaft input.
- 2004 5.9 wont smoke! help me
- Not impressed with the Smarty
- 24v three peice manifold
- '05 won't start
- CP3's
- Smarty PoD #5 and my Auto Tranny
- twin turbo
- power puck ?
- subwoofer enclosure
- manual transmission
- Heres a boneheaded stunt I pulled......
- performance parts
- CAT turbo
- new guy
- best bang for your buck mods?
- Need crankshaft
- Coffin muffler... Heard of em? Have one?
- tranny cooler and line question
- c_rapps
- Engine smokes and rough Idle on start up
- 4x4 issue
- another injector size question?
- wire help
- Rattling noise
- tranny upgrade
- Convert Open Differential to Limited Slip
- new bumper build
- wondering aobut trouble spots with the 04 3500 6 speed
- fuel filter
- tranny help please
- cracked injector nozzle
- Intake Baffles
- 600hp goal
- EFI Live for cummins
- intake horn
- trans manifold on engine need help quick?
- Oil smell at idle
- Upgrades...
- Which Turbo?
- 03 dodge belt squeeks when i turn motor off?
- upgrade help
- coolant leaking from tube on firewall
- edge evo ht????
- Transfer case help
- Diesel problem
- looking to mod
- Exhaust smell
- Security issue? Im Baffled
- 2006 Cummins 4x4
- heater treater
- Torque converters
- P0341 on a 5.9L technical question
- Shift Kits
- Programing 5.9 cummins
- Suggestions on replacement tc's?
- spyntec hubs
- Heater Core
- Auxiliary Idle Controller
- Door Lock!!!
- 4 gauge pillar mount
- U-Joints..quality not quantity
- Price Quote and advice needed
- Truck slow warming up and staying warm
- baffle in air filter tube
- 03 cummins idles high wont start hot
- upgrades for my 2006
- tranny upgrades??
- Truck needs ether to start?
- trailer wiring problems
- multiple problems
- Erratic engine idle
- 800 to 850 hp??
- Operating temp
- Smoking cylinder 6
- bully dog power pup?
- Edge problem
- Smarty or Diablo
- Wait to start light won't go off
- new trans ideas
- can you put different nozzles on stock injectors?
- fuel delivery issue?
- g56 wont go into gear sometimes
- Occasional Hard Start
- Which aftermarket CP3?
- whats the best 2.6 turbo
- New to Cummins
- 2006 5.9 Litre
- TRANS Not responding
- School bus Cummins
- 2005 ram 3500 277000 miles whats the best programmer for fuel milage
- Just got my Smarty
- dual wheel tire rub
- 06 smoker
- bought junk
- 2003 cummins random white smoke
- Will 04 ranchhand fit 06
- Need help with diagnosing steering problem
- question about airdog kits
