PDA
View Full Version : 5.9 Liter CR Dodge Cummins 03-07
Pages : 1 [2] 3 4 5
  1. Clunking and squeeking noise in front end
  2. Tranny Fluid and engine oil change
  3. 05 dodge starting problem
  4. Road tested Air dog
  5. Literally stuck right now!!!
  6. Piston Rings Going Out?!
  7. Short Shifter Kit
  8. Stacks???
  9. Stock Radio Interference Problems
  10. Why is my fuel milage so bad?
  11. 48RE Transmission problems
  12. I messed up on my choice, BAD!
  13. Air dog install 05's and newer Part 1
  14. Body work to be done....
  15. power steering hissing
  16. POWER LIMIT
  17. Rough Idle, Blue Smoke, Runs Better over 1/4 Tank???
  18. P0500 code
  19. drag race times
  20. winters coming!
  21. Next upgrades
  22. auto to manual swap
  23. dual feed
  24. got codes
  25. Need some advice.
  26. Falling on its face at WOT
  27. Removing Fan
  28. new truck and some decent mods
  29. Low Fuel Pressure???
  30. What do you guys think?
  31. Got my Dog
  32. problem with my 04 dodge 2500 cummins
  33. towing twins or a good single towing turbo
  34. how to take off a dashboard for a 2003 dodge 3500
  35. lowering my 03 2wd dually
  36. Fiberglass bumper?
  37. lift pump failed ???
  38. Do it myself CP3
  39. Axle seal leaking?
  40. 03-05 OEM radio?
  41. ?edge juice w/ attitude?
  42. Ball Joints
  43. 2006 dash trim removal - stereo
  44. 05 dash center trim removal
  45. AC help on 2006 mega cab
  46. Help
  47. injector connector tubes
  48. 2006 3500 5.9 Cummin's
  49. Someone please help
  50. My MPG Compared To Yours
  51. injection pump
  52. 2005 dodge 2500 smoke
  53. Dad bought 2004 Cummins
  54. Less expensive modification options?
  55. Need a trans for 06 Dodge
  56. Edge CTS
  57. Need to find a 2006 Engine
  58. Well it was bound to happen sooner or later...
  59. Need help
  60. Propane injection
  61. headlight
  62. Recall Notice Mopar Steering Linkage
  63. What gives!?!
  64. question bout my tranny and rpms
  65. All about a 48RE
  66. Confused. This stuff is intense!
  67. turbo and injectors
  68. Clutch or Tranny Problem?
  69. 07 5.9 Engine Cuts out at higher rpms
  70. Dead spot off idle?
  71. any tips for assembly
  72. OIL BLOWING OUT OF TIMING COVER,COOLANT BLOWN FROM REAR FREEZE PLUG
  73. injectors
  74. Light's out too fast
  75. Front end!!!!
  76. Turbo Upgrade??
  77. I need some help with my cummins, throwing codes P0236/P0237/P0238 and same in PD
  78. injectors or worse?
  79. 48re slow to start.
  80. Help with interior lights
  81. Clutch Confusion...
  82. auto to manual swaps
  83. help
  84. Coolant Questions
  85. New guy in Tn
  86. lift pump
  87. best described as a backfire.
  88. white and blue smoke
  89. Injector buzzing
  90. Over Heating Problem
  91. Factory rims
  92. I want that whistle sound
  93. State Patrol Issues....
  94. Price Quote on Gauges
  95. tranny swap
  96. CP3 Price Help
  97. Coolant leak
  98. Tach Fluctuation
  99. Turbo
  100. All new injectors or just nozzles?
  101. Tires and Bumpers
  102. Gauges?
  103. Smarty for the 5.9
  104. Dodge 48RE
  105. Exhaust Brake?
  106. rear axle seal
  107. What Fleetguard Number ?
  108. Is there really any benefit?
  109. Bosch CP3
  110. 5.7 tranny
  111. Major Squeak!
  112. Engine Rebuild Kits
  113. Good deal on an '03 3500 crew?
  114. oil
  115. hub replacement
  116. How to know if the injectors are good
  117. 03-08 owners sign in whats the best year
  118. Clutch or Transmisson Problem?
  119. Black sut on map sensor
  120. Vibrating 04
  121. Dropping MPG's
  122. belt part numbers
  123. Is this normal????
  124. Length of Megacab Shortbox
  125. Fuel Filter
  126. not really in diesel distress, mostly annoyed.....
  127. g56 shifter boot fixed
  128. factory satellite radio stations
  129. 2003 3/4 six speed
  130. Fuel Pressure Readings
  131. 3rd Gen Cracked Dash
  132. 03 common rail popping
  133. 5 speed
  134. 06 5.9 blowing a little smoke ?
  135. Waranty ?
  136. To Go Manual or Automatic
  137. 03 Cummins fuel rail....Biodiesel/WVO...anyone tried these? or heard?
  138. Conversion kit for fuel pump?
  139. 03 Cummins - cold start problem- gone worse ..update
  140. extended warrentys?
  141. 03 cummins popping
  142. Cold Start Problem--Gotten Worse
  143. Poo88
  144. 2004 truck what motor does it have?
  145. Stuck in 4 low
  146. pcm's fried
  147. 05 5.9 missing and lots of blowby
  148. Turbo removal difficulty
  149. Power Windows Quit Working - Fix Inside
  150. weird squeaking noise
  151. New guy with?
  152. broke DOWN
  153. Shutters
  154. Looking for some advice. Vp or Common-Rail
  155. Injectors - Description, Operation, Removal, and Installation
  156. Satellite Radio-hard wired
  157. Loosin my mind!!
  158. 03 cummins starting issues, please help!
  159. turbo question
  160. silencer ring on on 06?
  161. Reinstalled Edge NEED HELP!!!
  162. Powerstoke and Cummins
  163. Manual Electronic Shifting on an Automatic
  164. WHISKEY TANGO FOXTROT?
  165. Need help! Relay fan ???
  166. Tie Rod Update
  167. Ring and Pinion
  168. 03 Dually Rear Brakes
  169. did they use the 6 speed trannies with the 5.9
  170. Need Suggestions!!!
  171. problem with tach on 06 cummins ?
  172. a pillar pod
  173. water methonal or a programmer
  174. Oil leak frustrations...
  175. Belt routing diagram
  176. !!!My Truck Is Possessed!!!
  177. is this a side effect of 2-stroke?
  178. find out gear ratio
  179. MBRP exuast
  180. getting a p170 code
  181. a recall to check out
  182. Crazy Larry??
  183. Anybody heard of a transmission actuator?
  184. 06 ram with rear rotor question
  185. Stacks
  186. Brand New Motor!
  187. code is killing me...
  188. MIL P0480 and P0243
  189. help dtc code u0001 can bus
  190. Fuel mileage Auto vs. Stick
  191. Buying a new to me truck any suggestions?
  192. Next step for my buddies truck?
  193. First Diesel need help on what to install.
  194. Maintenance ?
  195. 05 Cummins:edge vs. bully dog
  196. AEM methanol injection system
  197. new shoes
  198. Diesel tune up (sevice)
  199. code?
  200. Boost fooler with edge juice
  201. What Injector for me
  202. Which one is best
  203. tranny trouble
  204. sluggish 06 3500
  205. Inj. Lines
  206. What Turbo is best for me.
  207. who has dealt with warranty hassle on there truck
  208. Steering Recall for HD 03/08
  209. 04.5 cp3 pump
  210. Down pipes?
  211. xzillerator upgrade
  212. tst powermax
  213. Ignition kill switch
  214. MPG's on 06' 5.9 stock?
  215. MAP SENSOR
  216. ambient air temp sensor, 04 cummins
  217. can anyone answer this one
  218. Transmission Help
  219. Official Diesel Nut
  220. e fans
  221. Leveling kits
  222. what is a smoke switch?
  223. 04.5 water pump?
  224. Stupid Door Lock!
  225. Do they have Diesel Darwin Awards?
  226. Tranny coolers.
  227. cummins rattle
  228. Rough idle
  229. 03 cummins wont start
  230. Engine Light
  231. water pump / thermostat replacement
  232. ooo what to do next!!!
  233. fluids (maintenance)
  234. Seat belt warning light
  235. Air intake guard removal
  236. A/c issues
  237. fuel system upgrades
  238. superchips
  239. Debadging ?
  240. CP3's
  241. Need advice on Mega Cab...
  242. new guy looking for a few anwsers
  243. 5.9 SO and HO?
  244. converter or not
  245. Door lock questions with turbo timer?
  246. need help with mpgs
  247. Gauge set up
  248. Fuel economy help
  249. Decode Your Vin...
  250. dead 05
