- 95 prospector 1/2 ton 4bt front axel
- governor spring
- Valve Cover
- Factor temp gague, What's going on??
- need advice
- POWER STEERING PUMP SHOT?
- CoalTrain Diesel
- Replacement Parts Catalogs?
- Drag racing the 89
- Fuel guage / speedo
- A518 Transmission
- fuel shut off silenoid
- Transmission Fluid Change Question
- Governor Spring?
- Need some help and basic advice 93 dually
- How to Video
- Turbo off a 99 Cummins
- w250 suspension sagging x-cab 92
- How exactly do you install a EGT, tranny fuel pressure and boost gauge?
- Help turning up the pump
- What tires to use on a dually?
- front hub lock nut socket/tool
- Death wobble. WT???
- bully dog power pin
- check your front brakes
- AirDog Set-up
- In need of 1992 Auto Trans
- no start/ engine maintenance light
- Star screw
- Here we go ( Changing evaporator coil )
- Speedo way way off
- Air conditioning
- Stock 24V Intake
- he351vgt?
- 1st gen tie rod ends
- ve manual cutoff
- 90 cummins
- Couple Questions
- rear axle question
- WTF!!!!
- A518 auto for what standard ??
- Which turbo?
- New Era 370's Vs. 435's
- torque converter
- 47rh conversion
- ?'s Fuel Pin
- 1992 cummins 2500 fuel tank
- Truck Running hot. What Turbo?
- Newbie on the Block :)
- Throttle Positioning Sensor HELP
- Difference Between 1st and Second Gen Injectors
- HX35, 16CM housing and downpipe
- School me in the spedometer setup
- crossmember
- High Idle?
- Air con Delete
- pick your brain
- Coolant Temperature Sensor Location
- im confused soo confused
- looking for
- Opinion time
- Need gauges
- im tired of this POS automatic
- shifter??
- DennyT stage 2 fuel pin
- Truck won't start - Lift pump?
- Loss of power, and died.....the 93.......
- Banjo Bolt search please!!!
- Help, i need opinions here...
- Under fueled?
- I got screwed!!!!!
- Video of my 93 with stacks driving
- transmixer problem
- vw site
- injectors
- My tranny
- not shifting right
- Air to Dry Ice Intercooler....
- 7.3 powerstroke intercooler
- rear axel
- lift kit ????
- 3.07 open differential
- tps picking up some noise?
- 1st Gen Screen Saver!!!
- pictures of engine
- What yall think?
- WTB:KY 89-93 cummins
- 3rd gen seats in 1st gen fit?
- ECM/PCM in a 92 - What does it do?
- power screw
- My 93 with some new stacks
- PDR Twin Turbo Set Up
- shut off solenoid
- found 1991 cummins
- Windshield Wipers Not Working? Look In Here!
- this is really gettin old
- any 1 have?
- NV4500 Swap info needed.
- 1st Gen low or no buck upgrades
- hello all
- New 1st Gen
- brake question. puzzled!
- 1st Gen Toys.....
- 1993 Stalls out when coming to a stop
- Major loss of power
- HX40W - Will this work on Gen I ?
- Tachometer hookup....
- 1st gen pillar gauge pods.....
- '92 Gen I A/T - Shift problems
- turbo question
- fuel tank
- My Strange Power Steering Problem. Any Ideas?
- got me another one......
- pos ve pump
- fuel press. gage
- not cummins dodge diesel
- turbo
- 93 I/C cummins sensors
- 93 first gen auto trans info
- leaking fuel
- first gen transmissions?
- still having problems
- Speedometer works, Odometer doesn't
- ladder bars
- need help with the ve pump
- 02 Ram 2500 engine swap with 1990 Cummins???
- water / meth injection
- ve pump question
- looking for a 1st gen
- Intrigue with the HX35/HX40
- power loss
- GDS 60mm Inducer....
- pods
- Water Pump
- Grid Heater Problem
- Valve Adjustment
- 1st/2nd gen lugs and wheels
- vehicle speed sensor
- Throw out?!
- Help.I Need a Dash
- how bad is this
- will turbo from an 01 fit on a 93
- truck wont start need help
- Running cold
- Injector Question
- Turbo Questions
- New side moulding for 1990 D250 LE
- help tranny problems
- 1st Gen. Slideshow
- 92 first gen 5spd
- Bosch VE Pump Operation
- I need advice on a 91'
- loss of power and than the engine died
- cummins in a ford
- Edge Products, Dodge Ball Bearing Turbocharger
- 24 valve in 1st generation?
- anyone know where to oreder a speedo cable
- Stacks or no stacks
- brakes
- Gasser Diesel Swap
- VE PUMP INFORMATION FROM BOSCH
- Would like opinions on my new 12valve experiment
- 91 D250 Probs and Questions
- Pulling the cab off, Unbolting steering shaft question!
- hi guys-- bosch ve pump indexing accel shaft
- Need More Power
- Good Read On VE Pump
- 1 Gen. Dodge body panels, weatherstripping, felts, interior panels, etc.
- 92 D350 Hard start
- Early 90's Dodge
- Turbo Upgrade
- Got a question?
- Transmission problem
- Cool 1st gens.....
- Is it worth $1500?
- What to look for in a 1st Gen
- Old Smoky power pin
- HX35 for sale
- Tuning?
- The finished project
- driveshaft again
- Cracks in the cab under cowl 1991 dodge
- Coolant Temp. Sensor
- hydraulic clutch
- Getrag
- HX-40G
- Fuel tank Straps
- In Need Of A Driveshaft.
- Intake
- Intercooler
- Lift kit
- What To Buy ?
- 93 12V
- Any Advice
- Rebuilt From The Frame Up CTD
- What's It Worth.... 1st Gen Std Cab
- Exhaust
- 1st Gen Whipping A Vette
- 2wd To 4wd! YAY! :)
- Coolant Leak
- How Much For A '93 Full Motor?
- RPM's @ 100KM or 60MPH?
- Missing
- Help. Underlay Is Soaked Again, Floor Is Starting To Rust Grrr..
- What Do You Love About Your 1st Gen?
- What Gauges Do I Need?
- Front Suspension Crisis
- NEW TRUCK!
- Another 1st Gen Coming Home.....
- Speedo Won't Work!! HELP!
- A/C And Windows Stopped Working
- Motor Swap 1st Gen 318 to 5.9 Cummins?
- Power.
- Exhaust Manifolds?
- New Truck......
- Hughes Converters??
- HX40
- 1989 4-speed?
- 91 DRW Front Brakes Wear Uneven
- Auto Or Stick
- 91 Cummins With Low Oil Pressure
- 89-93 VE Pumps / Rotary Pump Breakdown Diagram
- Gov. Spring
- What Injectors Do You Recommend.
- New Goal
- First Gen CTD Locations.....
- Steering Wheel Alignment
- Intercooler
- Mileage And Injectors
- Need To Go Faster In Reverse
- Does This Look Bent To You?
- Plow
- HX35 Turbo Or Compressor Upgrade
- 1st Gen Injectors
- Torque Convertor
- 14mm VE Pump Head
- A518 TC Lockup Switch?
- HX35W Swap
- Leaking Fuel
- Cruise Control
- Part Number For Door Clips....
- Amsoil Air Filter
- Need Front End/ Engine Bay Pics
- A/C Blower Motor And Or Switch
- Parts Help
- Dually Tire Question
- Truck Engines Used As Industrial Engines
- Fuel Pressure Question
- NP 205
- You May Have Seen This Truck In The TDR Calendar
