PDA
View Full Version : 5.9L 12V Bombs (Aftermarket)
Pages : 1 [2] 3 4
  1. Which turbo for 600hp daily driver
  2. anybody?
  3. HX35 R.I.P.
  4. dyno?
  5. GSK Springs
  6. lets see who is closest.
  7. governor spring install ??
  8. hx 50 question
  9. 3GSK or 4GSk?
  10. HELP New Fuel plate and too much SMOKE?!
  11. wastegate
  12. which stixs?
  13. 4 gsk?
  14. Delivery Valves
  15. boost fitting question.
  16. In need of knowledge
  17. SDX Injectors 5 x 14 (weston specs)
  18. Limit of STOCK injectors
  19. Valair or Southbend?
  20. Southbend possibly problem?
  21. what size tires are you guys runnin?
  22. Fuel Plate #10 or Bosch 300 Injectors
  23. quick question
  24. which transmission
  25. what clutch?
  26. 4K GSK Cruise Control Surge
  27. 3K GSK or just tighten stock springs 3 clicks???
  28. guages????
  29. HTT 62/71-13 SS
  30. rpm defueling
  31. Found a 1994 CTD 4x4 to tare up
  32. First timer, moderate mods...
  33. cummins 12 valve fuel plate
  34. Water/methanal
  35. smoke question
  36. smokems vs. ii
  37. why it shift like that after vb?
  38. A 94 cummins what should I do with it?
  39. drag racing
  40. IC Boots
  41. timing question.
  42. boost elbow
  43. Custom Valve Covers
  44. who makes a good traction bar setup?
  45. low boost excessive smoke
  46. hp rating
  47. looking for some advice from the experienced
  48. help now
  49. BHAF
  50. head studds
  51. Clutch/Fuel Plate
  52. I Got My Fuel Plate Dont Think Its A 5
  53. hx35 hotpipe to s400
  54. Debombing/Rebombing
  55. 843 p7100
  56. Citydiesel DV's and 370 marines!!!!!!!!
  57. What turbo??
  58. will it handle it easy?
  59. dv help.
  60. removing the fuel plate.
  61. power
  62. what fuel plate
  63. dtt tranny?
  64. 97 tranny Question
  65. a real billet tc?
  66. Need some help
  67. Sun Coast Loc-Up Controller
  68. how to switch vb?
  69. looking for a clutch
  70. B2 turbo under Hx35??
  71. 4 gsk with a auto trans???
  72. 3gsk how to install?
  73. timing chart
  74. #100 fuel plate
  75. with a t an vb how much more hp?
  76. Fuel Plate Diagram.. Thought some could find it useful
  77. s360 on top
  78. rack plug
  79. retarding timing
  80. ht3b twins
  81. 5X16 injectors? too big?
  82. egt?
  83. s300 turbo?
  84. What is the best "Out Of The Box" performance P-Pump?
  85. Another Turbo Thread
  86. studs vs studs+oring
  87. were can i buy a #100 fuel plate?
  88. turbo
  89. Injector Testing Today........
  90. 4wd shifter
  91. fiberwerx prerunner fenders
  92. TC Lockup Switch
  93. fuel plate question
  94. hood stack
  95. fuel plate specs
  96. turbo? lost please help....
  97. 12 valve Twin Ram Intake
  98. Hood Stack vs Stacks
  99. one piece headlights
  100. how to tell you gov spring are not tight enough
  101. help please
  102. 98 12v
  103. Auto Trans Upgrade
  104. Autometer EGT help
  105. need more power
  106. loping?
  107. Rack Plug
  108. #11 plate questions
  109. s300
  110. intake manifold elbow
  111. what can i do to get power?
  112. got the timing set to 15* and KDP done.
  113. HX55 DP?
  114. o ringing
  115. get money son
  116. wat now
  117. 6spd
  118. short shifter
  119. good cam
  120. increased EGTs/with new fuel plate
  121. turbo timer
  122. steering shaft
  123. yeehaw
  124. #100 PLATE IN STOCK LOC. OR SLID BACK A HAIR
  125. 5k rpm?
  126. gauges an my numbers
  127. exhaust manifold
  128. what fuel plate cut is best
  129. Aftermarket Radiator
  130. 12v fuel plate
  131. moving stock fuel plate forward
  132. what to set my timing at?
  133. turbo timer??
  134. cummins 12v
  135. KDP fixed?
  136. stacks lower egts?
  137. NEW TIP
  138. Silencer ring
  139. hx40
  140. Scotty II
  141. Exhaust mods
  142. turbo compressor housing thought
  143. WTHeck
  144. stock turbo mods
  145. 3000 or 4000 rpm p pump governor springs
  146. 3000 or 4000 rpm p pump governor springs
  147. How do i tune the afc?
  148. trailer towing
  149. h40 style compressor outlet
  150. Transmission upgrade?
  151. Air Intake
  152. delivery valves
  153. Stock exhuast manifold vs. Aftermarket
  154. injectors
  155. would like more power
  156. chevy wheels
  157. biggy b will a turbo off of an 04 will fit 95
  158. Fuel Plate Question
  159. EBay parts
  160. intake horn
  161. hey guys i just got my first diesel
  162. Odd Application for a 12v
  163. more about fuel plates.
  164. 500 hp
  165. how can i make a downpipe
  166. fuel plate
  167. how much power can i expect to make
  168. injectors.
  169. Converting to a p7100
  170. intercooler pipes/boots
  171. Pulling Truck Fuel System.....
  172. #100 plate? will it hurt my drivability or mpg?
  173. boost elbow installation on a 1997 12v
  174. Umm more fuel.
  175. heres a new one
  176. 4k kit install
  177. Tranny won't shift right
  178. BHAF
  179. Valve Spring Replacement
  180. can anyone recomend a reputable diesel shop?
  181. what does lazer cut delivery valves do?
  182. help with gauges
  183. truck mods
  184. idea for filter skin?
  185. Cold Air Intake?
  186. best combo for 450 rwhp 850 ftlbs?
  187. wat fitting on the pyro
  188. fueling question
  189. ht3b switzer with 26cm undivided housing
  190. lowend power
  191. thanks
  192. Fuel plate description?
  193. turbo change
  194. 12V vacuum location?
  195. DTT
  196. any one know about 4 k gov kit?
  197. Which lift pump to buy?
  198. 3000 or 4000
  199. GSK spring kit question
  200. any one make intake heat shields?
  201. Fuel Plate
  202. twin turbo thought
  203. injector and DV valve questions
  204. Gov Spring Questions
  205. 12V programmer ??
  206. injectors
  207. propane or water/meth
  208. 4000 gov springkit
  209. pump identification?
  210. Banks Powerpak Kit
  211. water methanol
  212. Boost Elbow - where is the link?
  213. Injector and Fuel Plate ?
  214. home made 3000 gsk
  215. balanced
  216. turbo ?
  217. pressurizing coolant system
  218. 5 inch exhaust
  219. down pipe adapter
  220. Need some help please
  221. Going to the dyno
  222. turbo upgrade?
  223. 4000 gsk install ? with picture it is all apart
  224. 3000 to 4000 gsk ?
  225. New exhaust
  226. Head work?
  227. Gauge Kits
  228. blockin the waste gate.
  229. Down Pipe
  230. fuel plate
  231. Star wheel
  232. pyrometer question
  233. 370 marines vs 370 new eras
  234. is this a true 887 pump?
  235. Will these mods require a turbo?
  236. How much HP?
  237. injectors
  238. About the mack plug/rack plug?
  239. 550-600 Hp Goal
  240. 3000gsk vs.4000gsk
  241. what is this air filter
  242. 12v hp mods help
  243. 12 valve ez pulling mods
  244. Will These Housing Actually Help ?
  245. looking at the next upgrade...
  246. Fuel Plate
  247. School Me on Fuel Plates
  248. ATS 3 piece mainfold
  249. P7100 pump question
  250. not enough rpm's
