- 94cummins12v Custom Light Bar
- SUPER B SPECIAL
- Turbo Size?
- Rain Caps For 5 Inch Miter Cut Stacks
- Intake Horn
- Turbo
- Headlights
- How To Make SMOKE And Lots Of It!
- 370Hp Injector Install
- Really Quick Fuel Plate Lesson....
- Fuel Pressure Gauge Install Help
- DV's
- Prices For My Truck Stuff.
- Twin Turbo Sensor
- Silencer Ring
- Intake Horn
- What Next?
- Anyone Know Who Has Some Mods For A 12 Valve Cummins
- Convertor
- Trans Temp Gauge........
- Twins
- What?
- 181 DV's Worth It?
- Aftermarket Shops
- KDP Drill Jigg
- Trans Temp Gauge
- Adj Boost Elbow
- Cummins Factory Injectors
- Fuel Plate Or No Fuel Plate?
- New Valair 500hp Clutch Slipping
- Head Gasket Setups
- 3rd Gen Mirrors On A 97
- Exhaust
- KDP
- Isspro Guages
- Temp Difference
- AFC Housing Bolts
- Stage 2 Sticks
- Bad Day To Be A Cummins
- Phat Shaft Turbo's
- LCDVs VS. 191s
- Fuel
- Manual Shutoff
- Stacks
- New Clutch Time
- 4" Exhaust
- Good Place To Set Timing
- Considering New Exhaust
- LCDV's
- 12V & FASS
- Getting A New 12V - Need Help With Build Up
- Where Should I Set My Timing
- Silencer Ring MIA = Lower EGT's
- KDP killed
- banks high-ram
- best fuel plate for 3gsk???
- adjusting tst fuel plate
- visor w/cab lights
- banks brake
- gear vendors
- What do you think power will be. 97 12V
- Accident
- Turbo question
- plate and injector install
- High EGT's
- help? track bar conversion
- gauge pod
- Timbrens
- A/C Clutch
- brake controller
- I want the best fuel mileage
- adjusting stock fuel plate 12 valve
- Could Somebody Tell Me What This Is?
- Delivery Valves
- Moving Stock Plate Forward
- help! toruqe plate
- ford 7.8 turbo
- finally!
- How much boost?
- Longevity
- Homebuilt Preluber. Worth it?
- Truck not down, but....
- ICEBOX is in
- can you say FUEL!!!!!!!!!
- 5000 or 5500 rpm gsk
- Crazy transfer case ?
- Cummins w/an Allison
- best cheap 1st mods?
- torque plate
- pyrometer
- Cheap Mods On A Stock Truck Thread.
- 318 To 5.9 12 valve transplant
- Tuning Tips
