PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 [2] 3 4 5 6
  1. How much boost can a stock cummins turbo handle
  2. how much boost can a stock cummins turbo handle
  3. pump timing geat help.......!!!!!!
  4. turbos turbos...
  5. 95 cummins 4x4 5speed should i buy?
  6. timing suggestions?
  7. afc trouble
  8. Dodge Trans Issue
  9. CHRISTMAS IN SEPTEMBER!!!
  10. stuck throttle
  11. Automatic Transmission Controller
  12. Noob with a question...
  13. Stock RPMs?
  14. HELP ME!!!
  15. G56 6speed tranny swap
  16. 400 HP?
  17. Straight Pipe?
  18. WD-40 + NV4500
  19. water in fuel light
  20. bogged down
  21. 4th gear lockup issues
  22. injectors
  23. no wait to start light
  24. need help plz tranny issue
  25. pump timing
  26. 1994 dodge ram 12 valve cummins acceleration
  27. Wipers come on when honking horn?
  28. Injector
  29. nv4500 output shaft
  30. help!!
  31. Help on a 95 12 valve
  32. Transmission cooling lines
  33. Blue Point Timing Sets
  34. Turbo Info--Craigslist
  35. 4 wheel drive..hubs wont lock
  36. delivery Valves?
  37. question
  38. NEED HELP
  39. truck jerking
  40. moving fuel plate
  41. Banjo bolt replacement
  42. lookin for p7100
  43. Cold start problem
  44. Skyjacker, or Fabtect
  45. 0-60mph
  46. starter
  47. Smoke screw
  48. star wheel adjustment
  49. 95 dodge 2500 5.9 cummins
  50. i need help!
  51. Smoke screw
  52. 1st cummins,, good deal?
  53. fuel plate question
  54. fuel plate
  55. fixin KDP damage
  56. Intercooler boots
  57. o/d while pulling a load
  58. pump timing
  59. Anyone have a stock turbo exhaust housing??
  60. clutch failure
  61. neutral start safety switch
  62. gauges...
  63. p3000
  64. Need a Clutch
  65. 2065 rack plug
  66. 1996 dodge diesel code 77 ?
  67. hate automatic
  68. heartbroken
  69. p7100 pump tuning
  70. 96 12 valve brake pedal goes to the floor
  71. Slow Starting
  72. tranny smell/ cooler
  73. stock tranny coolers
  74. programmer
  75. new convertor no lock up
  76. SOMEONE TELL ME WHAT PUMP TUNNING CONSIST OF?
  77. tranny smell
  78. speedo quit
  79. check list of things to do before storing truck
  80. rough start
  81. odometer fraud
  82. 47re line fittings?
  83. 97 12v dually $$$
  84. front main seal install
  85. 47rh cracking od housing
  86. MY TRIP FROM PHX TO SANFRANCISCO
  87. hp and torque estiment
  88. Why is my truck missing still?
  89. Any Bombers in Vegas that can help with the timing on my truck???
  90. clutches
  91. radiator cap bad?
  92. adjustable wastgate elbow
  93. Jumps in RPM at Hwy speeds
  94. another fuel plate post
  95. fuel filters?
  96. yes another mpg problem!
  97. 97 12 valve sputters on cold start
  98. 8.3 , 5.9 family
  99. how much boost with a stock motor
  100. 12v dies only SOMETIMES?
  101. tranny or convertor?
  102. what controls the PCM?
  103. Is my boost gauge working
  104. 95 auto, What's the best mpg I can get??
  105. speedometer
  106. band adjustment screw replacement question
  107. how much is it worth??
  108. oil leak
  109. fuel leak
  110. alternator problems
  111. lookin to buy
  112. check it out!!
  113. return line leak
  114. shifter removal
  115. first gear shift fumbles
  116. gauges
  117. clutch urgent.
  118. over speed hx35
  119. buying a 95 pros and cons?
  120. transmission/transfer case question
  121. how to take off towing mirrors??
  122. How to find"dead nuts" Top Dead center on a 12v?
  123. Need some newbie questions answered
  124. Horse Power???
  125. high rpm stumble.
  126. KDP pin issue..
  127. p pump fuel shuttoff smoking
  128. passenger light not working...
  129. Harmonic Balancer Position..
  130. Lift pump tick or not?
  131. hx 35/40 ugrades
  132. Need Some Help
  133. people that have bypassed the fuel heater
  134. tranny shops
  135. power steering help!
  136. HX40 on 94 cummins?
  137. rpm sensor problems
  138. star screw
  139. missing!!!
  140. shift points??
  141. 47RH OD/TPS Issue... HELP!!
  142. Need to remove washer fluid bottle...
  143. 95 tranny?
  144. high EGT's!
  145. overheating or not?
  146. prefilter
  147. reving motor in neutral/park more wear??
  148. loosing coolant
  149. 47re Fluid questions..
  150. valve sticking maybe
  151. Pump "settings" for towing and mileage
  152. tranny issues
  153. tranny ?
  154. KDP
  155. Looking @ Buying a 12v
  156. rpm vs mph
  157. what are the tubes?
  158. help diagnosing a miss
  159. what are dv's
  160. timing tool kit for pump timing
  161. wobble in front end
  162. coolant leak
  163. turbo porting.
  164. sending feul line from spin on to injection pump bolt stripped
  165. need pump help
  166. torque spec on stub axel
  167. power steering leak
  168. biggy b how can u tell if you have slipped timing on ur pump ?
  169. tranny whine?
  170. 12v surges off idle BAD!
  171. intake piping
  172. pump timing
  173. altenator
  174. PCM issue
  175. 96 cummins dieing when reved
  176. doubts after sligth tunning
  177. where to buy
  178. 01 TRANSFER CASE ON A 96 SPEEDO HELP
  179. Fuel Plate
  180. ever heard of it?
  181. adjusting the bands
  182. Roof liner
  183. Need Help... No Power!!!
  184. star wheel.
  185. help
  186. Whats it worth?
  187. fuel gauge
  188. FUEL FILTER OFF
  189. bypass oil filtration drain?
  190. steering box
  191. hmmm oil pressure?
  192. water in passenger floor board
  193. How often do you adjust your valves
  194. Valve Spring Retainers
  195. how much hp
  196. 96 tranny line upgrade ideas
  197. hx 35 turbo rebuild
  198. HX 50 EGTS
  199. white smoke under compression
  200. clutch
  201. starting issue
  202. exit off highway ramp lose RMP dies,wont start running again
  203. egts
  204. AFC Spring and Govenor Spring
  205. stock numbers
  206. replacing head light bulbs
  207. pump plug
  208. 4x4?
  209. NEW TO THE DIESEL GAME
  210. 47RE shift troubleshooting
  211. 95 auto trans
  212. turbo mapping
  213. death wobble
  214. damn pedals wont come out
  215. Rear dana need help
  216. makin my 12v lope
  217. valve springs
  218. Need some advice
  219. tq vs. hp
  220. more boost bc the star wheel?
  221. Lift kits???
  222. what convertor
  223. Confused :(
  224. oil in plug for 4k kit install
  225. tc lockup on a relay?
  226. new guy needs help
  227. wtf HELLLLLLP!!!
  228. fuel plate suggestion
  229. Oil pressure
  230. Idle RPM's
  231. valve spring install
  232. pre boost screw
  233. Exhaust Change
  234. Fuel Plate
  235. Stock tranny questions
  236. EXHAUST LEAK,gasket replacement?
  237. 95...easy hp + ?...
  238. 85 dodge prospector 1/2 ton 4bt swap
  239. Lift Pump
  240. wat to do
  241. hx35/40 urgent help!!
  242. hx35/40 waste gate
  243. Oil Drinking
  244. engine temp changes
  245. return line leak
  246. how to fix the cruise control? 1997 12v 5speed
  247. throttle sticking
  248. oiled filters
  249. turbo here advice!
  250. Exhaust
