- Fuel Plate
- School Me on Fuel Plates
- ATS 3 piece mainfold
- P7100 pump question
- not enough rpm's
- Drive pressure gauge
- tach?
- #11 fuel plate
- delivery valves
- gov kit & valvespring prob
- Anyone have a D-Tech Turbo?
- injectors
- dv desicions
- Detune?
- Springs and what not
- #6 plate
- gettin to the fuel plate
- Paranioa or not
- tst vs ebay
- Sticks? What Injectors do I have?
- ~*TRUCK SHOW*~
- Gov spring kit tips
- Timing for towing???
- ? Biggest Fuel Plate on a Automatic?
- DV'S
- Aftermarket Tachometer
- 400hp?
- anybody pulled with a ductal dual disc?
- AirDog Dodge FP-100-150 1994-1998 Install Manual Rev. 3-3-09
- P7100 1st gen
- DD install problems
- 12v build questions and advice
- de-bomb?
- to much blowby
- plate issues
- twin ram
- water methenal
- Going Half Fenders... No Bed!
- twins can it fit?
- oil bypass filter
- ICEBOX!!!
- Blowin Coal
- GS washer shim?
- blow off valve
- Fire ring/o-ring?
- newbie 100 vs. 0 plate cut
- cam question
- help turning the fuel up
- milling rocker stands for head studs?
- water /meth injection
- dual disc
- Gauge installing
- Delivery Valves
- Down pipe
- Pensacola injectors?
- water meth
- '03 Trac Bar Conversion/ DSS Project...
- timing 12v
- fuel pressure guage
- Home brewed twins
- best auto trans
- Turbos
- AM I TRYING TO GET INFO FROM THE WRONG SITE?
- Are ATS Turbos good?
- are they compatable?
- I need advice im losing sleep!
- anyone know turbos?
- bumpin fuel in my 98 12v ?s any help?
- 4k govener spring kit
- pulling timing cover what all should i do?
- what turbo sould i get?
- what hp you think im making?
- how to make power,,,cheap
- 13 second 1/4s ??
- Anatomy of Twins
- More rack travel
- AFC arm
- 4" exaust
- Ground my plate to a #100
- 370 marine nozzels
- twins
- Whats it like under your hood?
- Whats a good 3rd Gen TB Bushing???
- help asap please
- Governor Spring Kit Question
- Gutting AFC
- Boost Gauge wiring...
- Getting my 12 valve some more power
- 12valve Turbo Whistle 'r installed...
- afc kit
- ATS Aurora 2000 turbo
- Swapping Parts
- 3000 to 4000 gsk where to get the extra parts?
- #100
- black smoke!!!!!!!!!!!!!!
- Bomb order.
- Plate profiles....
- 4X4 problems.
- changing the plate or plate number from a #6
- High Idle
- delivery valves
- TST power kit has anyone tried
- Question about lope.
- Looking to buy injectors, but which one's?
- what injectors should i get?
- Propane ?'s
- Anyone go from a 3k to a 4k?
- Fuel Plate Grinding...
- Anyone replaced your ball joints?
- starwheel adjustment
- 1Hole... 2Springs... ???
- 3k GSK install
- Death Wobble baby steps...
- Injector flow
- Tuning the AFC?
- sigma p pumps
- Injectors
- 370s
- cummins fuel plate
- Lift + Tires
- cummins pyrometer
- which plate has most power??
- Bumping Timing up on a 1996 12v...
- Steering upgrade
- 12 volt block heater????
- 12 Valve on a budget
- Air vs Fuel
- Opinions On A Muffler
- Fuel Plates
- Fass/Airdog Questions
- BHAF
- Twins setup oil return question
- Monster Pump In A 12V
- Injector Questions Again
- Help Tuning A 12 Valve!!
- Which Trans To Pick...
- 12V Boost Gauge Install
- How Much HP Should This Make.....
- 97 Fuel Filter Relocate Kit ?
- Grid Heater Delete
- New Turbo...
- Lets Make Some Power....
- Unsyncronizing A NV4500
- Stocker Over HT3B
- Best Mileage And Perfomance Help
- Turning up a p7100 fuel pump
- Injectors???
- 12v FASS ?'s
- AFC Starwheel Spring Curves
- Banks Kits
- Upgrades
- P-7100 Tuning The Black Art...
- ATS Exhaust Manifold...!!!!!
- Phat Shaft VS High Tech
- I Can't Decide
- 12 Build
- 94cummins12v Custom Light Bar
- SUPER B SPECIAL
- Turbo Size?
- Rain Caps For 5 Inch Miter Cut Stacks
- Intake Horn
- Turbo
- Headlights
- How To Make SMOKE And Lots Of It!
- 370Hp Injector Install
- Really Quick Fuel Plate Lesson....
- Fuel Pressure Gauge Install Help
- DV's
- Prices For My Truck Stuff.
- Twin Turbo Sensor
- Silencer Ring
- Intake Horn
- What Next?
- Anyone Know Who Has Some Mods For A 12 Valve Cummins
- Convertor
- Trans Temp Gauge........
- Twins
- What?
- 181 DV's Worth It?
- Aftermarket Shops
- KDP Drill Jigg
- Trans Temp Gauge
- Adj Boost Elbow
- Cummins Factory Injectors
- Fuel Plate Or No Fuel Plate?
- New Valair 500hp Clutch Slipping
- Head Gasket Setups
- 3rd Gen Mirrors On A 97
- Exhaust
- KDP
- Isspro Guages
- Temp Difference
- AFC Housing Bolts
- Stage 2 Sticks
- Bad Day To Be A Cummins
- Phat Shaft Turbo's
- LCDVs VS. 191s
- Fuel
- Manual Shutoff
- Stacks
- New Clutch Time
- 4" Exhaust
- Good Place To Set Timing
- Considering New Exhaust
- LCDV's
- 12V & FASS
- Getting A New 12V - Need Help With Build Up
- Where Should I Set My Timing
- Silencer Ring MIA = Lower EGT's
- KDP killed
- banks high-ram
- best fuel plate for 3gsk???
- adjusting tst fuel plate
- visor w/cab lights
- banks brake
- gear vendors
- What do you think power will be. 97 12V
- Accident
- Turbo question
- plate and injector install
- High EGT's
- help? track bar conversion
- gauge pod
- Timbrens
- A/C Clutch
- brake controller
- I want the best fuel mileage
- adjusting stock fuel plate 12 valve
- Could Somebody Tell Me What This Is?
- Delivery Valves
- Moving Stock Plate Forward
- help! toruqe plate
- ford 7.8 turbo
- finally!
- How much boost?
- Longevity
- Homebuilt Preluber. Worth it?
- Truck not down, but....
- ICEBOX is in
- can you say FUEL!!!!!!!!!
- 5000 or 5500 rpm gsk
- Crazy transfer case ?
- Cummins w/an Allison
- best cheap 1st mods?
- torque plate
- pyrometer
- Cheap Mods On A Stock Truck Thread.
- 318 To 5.9 12 valve transplant
