- brakes pull ??
- lift kit
- Rear main leakage
- ABS light, E brake light on.
- Problem while installing 366 spring
- 93 cummins swap in to a 93 1ton chevy
- How do i eliminate my my door buzzer?
- non lock torque converter
- 91 Non I/C dodge w250
- Banks Power Twin Ram. Worth the money?
- Different first gen injectors?
- Alternator problem!!!!!!
- bypass ecm to get a/c to work 92 w250
- Turbo hunt
- I need a radiator!!!
- Turbo Specs
- INJECTORS
- 91 dodge auto
- Socket size fer my Dana 70
- Thermostat not opening
- Unconfirmed - Stomp makes 700+ Hp at May Madness
- Dear Friends
- Changing a thermostat
- pump still leaking
- starter
- POD injectors
- Whacky Temp Gauge
- steering headache
- Sickly brakes
- Air intake
- decoding my vin #
- Starter Manufacturer
- Down pipe
- Timing bump
- Headgasket
- Low pressure hose on power steering pump
- Clutch
- got my phatshaft 62 in today
- Did the Kingpin Bushings Today
- Getrag overfill?
- drive pressure
- injectors
- Spare bits and pieces
- Fuel Pin Install HELP---DennyT Pin
- puting a cummings in a 1 ton gastruck
- Fuel pin
- can't get the alt to charge the batt any help
- HOW CAN I TEST MY FAN CLUTCH?
- Speedometer parts
- strang moaning sound
- Tack ?
- schwitzer turbo for sale..think it might fit?
- How to make more hp from setup?
- Guages
- best place to get shocks
- Dana 70? or Dana70-HD
- SDX injectors
- Injection pump performace, tranny?
- phat shaft 62 ordered!
- A/C clutch problems
- VE44 Pump Problems??
- TRUCK WONT START
- THANKS M&H
- shutter/jerky feeling when taking off
- 1st gen water meth inj???
- OD trans ???
- IN SERIOUS NEED OF A PUMP GEAR
- 1st gen turbo
- Fuel Pin Giveaway
- 05 wheels on a 1st gen
- 92 12v 5sp
- HELP truck ran fine last night now will not start
- 2nd gen injectors in 1st gen
- Two questions
- turbo
- Courtesy light door jamb switches
- Help anyone have pictures of how kickdown cable should connect
- Transmision Fluid
- what do you think about the spicer 70
- basic maitnance scedual
- 1st gen doesnt like water
- Cummins into 1983 Chevy 1ton Dually
- 12 VALVE WON'T START!! **PLEASE HELP!!!**
- Transmission Help
- AFTERMARKET FUEL PIN
- Violent Clicking Relay!
- Interior trim? Where to get it?
- Gasket Set
- WHO MAKES A GOOD STEERING BOX BRACE
- PLEASE HELP!!D350 WHEEL AND STUD QUESTION
- 89 Trans problems
- Just Found This
- 5.9 Bastard child HELP!
- did they make 4 door 1st gens
- Throttle Position Sensor
- 6.7 CTD Manifold on a 12V?
- The right radiator
- driving along and truck shuts down
- SDX injectors
- question for 1st genners about smoke screw
- Pics please
- i need parts
- Getrag
- Whats Wrong With My Boost
- 1990 W250 Cummins
- A/C pump question
- Horse power numbers don't foget the torqe
- '93 Automatic trans?
- New 1993 12 v single cab short bed dually need advice
- is this too hot?
- got more smoke
- Intake heater acting funny
- My 1st mod
- injector pump rebuilt
- what is the spec for normal idle RPM
- Truck Wont Charge
- Truck dies if i don't keep my foot on the go petal
- need quick advice on possible cummins trade
- ABS - BRAKE LIGHT
- What Would It Be Worth?
- Injector Pump Rebuild
- h1c vs h1e
- Smoke srew
- fuel filter (stock upgrade)
- VE PUMP LEAK
- cummins parts
- would like info on hx40 rebuild?
- 91 d350 2wd brake caliper... How much
- 1990 W250 Worth Buying?
- Fuel line question
- CRANK CASE VENT
- Heater problems
- PULLING THE TRANNY!
- Looking for parts
- Driveline issues.
- new fuel pin :)
- Does anyone else's getrag do this?
- coolant leak
- no intake heater and no speedo
- TO TURN OR NOT TO TURN. That is the question?
- I need a ball/bolt deal for my accelerator rod
- Need a part. No longer available
- Cylinder Head
- 93 remote trans cooler temp switch
- air bag hardware
- Bosch Ve pump numbers please?
- fender flares
- trans swap
- throttle position sensor
- Got my Custom "Tractor" (hood) Stack on :)
- wrapping my turbo, advantave or not?
- Which radiator???
- Is that the posi unit making that noise?
- patriot blue
- truck trim
- Washer fluid on the windshield
- pump recall
- Love the truck hate the charging system. Need some help!
- I'm new to this and need help. Lots of it.lol
- bumper
- Slave Cylinder Mount
- Lope?
- Another turbo question
- Injector pump tuning
- What kinda Turbo
- 307's and overdrive
- strange idle
- seats
- First gen. with a 5 speed
- Need an Extra Inch?
- stripe or no stripe
- I got Flat rear springs
- boiling point
- water in fuel
- My heats not hot.
- speedometer problems
- Weatherstriping
- 5th wheel wiring.
- Need name of a seal
- 91 Injector Pump leak
- Transfer case
- Heater/Window Power Wire at Ignition Switch gets HOT
- Cam bolt assembly
- Help No Speedometer or Overdrive
- How Cold IS To Cold?
- In need of a part!
- doese any one know whats wrong
- Guys Look In Here
- What Tranny is this???
- Converting auto from 4x4 to 2wd
- Wont shut off!!
- 92 cummins oil pressure problem
- 1990 cummins tach
- Power steering problem
- Only 2nd gear
- what should i look at when trying to buy a motor?
- shut off solenoid wiring
- How high is too high of EGTs
- Whats it worth
- Steering shaft parts needed
- truck will NOT stop letting water in
- Posi rear end
- whats next?
- factory rims
- Any advice on the KDP fix.
- average coolant temp
- Newest member of the family
- man with tired cummins seeks advice
- handle on factory lift pump
- Inlet Pipe
- Anyone have a part number for this?
- anyone know what this is?
- Rear Main Leaking?
- 3/4 ton front end alignment
- Valve Covers Cover Plate Question..?
- turbo wont spin ....
- Injector pump leak - specific question
- The dangers of buying used pumps
- will not start with ether please help
- 4x4 shift boot
- Odometer not working
- will not start with either please help
- smoke
- First Long run issues...:(
- 92 12v need valve adjustment specs.
- dumb pump question?
- intercooler repair
- Fuel pump Leak
- Timing
- Will this fit my ride.
- speedo not working correctly
- Oil Pressure drops when accelerating
- fuel screw cover?
- getrag top cover question
- speedometer doesnt read correctly ?
- tansmission
- mileage?
- fuel pump leaking
- HELP!
- Clocking the transfer case...?
- Tach Gauge
- wondering
- curious
- need injectors
- What to use?
- strange idle in the cold
- finally got my truck on the road today!
- Real motivational!
- custom interior
