PDA
View Full Version : 5.9L 12V Performance
Pages : 1 2 [3] 4 5 6 7 8 9
  1. need some info on getting my p pump benched
  2. CLUTCH???
  3. Drivability with 13mm
  4. Twin turbo size
  5. detroit e-locker, or arb?
  6. oring or fire ring
  7. Tranny problem...SUNCOAST STAGE V rebuild
  8. 12v fuel plate installed.!
  9. fuel pressure to lift pump???
  10. 24v head on a 12 v motor
  11. Pac Brake install
  12. Replacement dually fenders
  13. tv cable mod question
  14. LBDP injectors
  15. power gains from a benched pump?
  16. afc help
  17. great product
  18. Tranny
  19. Tranny still doesn't feel right.
  20. 1995 cummins electronics
  21. timeslip?
  22. Part numbers
  23. Power curious dyno day soon
  24. would it work a 12v?
  25. is this right
  26. cuts out after 3000RPMS???
  27. Turbo size
  28. 7.3 lift pump
  29. Power from stock turbo
  30. 1/4 time
  31. hx 35/40 hybrid questions
  32. high egts
  33. Fender stack..we aint talking amps here!
  34. Where to next?
  35. Calculating and tuning compound turbos...
  36. hx 55 turbo??
  37. hx35/40 work stock???
  38. 3rd gen II super phat shaft on my 12 valve?
  39. Ppe lift pump
  40. mighty diesel head bolt torque
  41. Boost Elbow Question
  42. boosted launches
  43. High EGT Low Power
  44. Fuel plate
  45. Ford front end manual hub conversion
  46. CAT Stack!
  47. Performance
  48. RPM Governor
  49. timing
  50. 2/3 shift
  51. what 7 holes to buy??
  52. cost of a rebuild
  53. 400-450 hp goal
  54. .093 stainless injection lines
  55. good turbo? will it work? ''not ebay''
  56. Which intake?
  57. gov springs?
  58. stacks
  59. 5x12 or 5x14 sdx injectors??
  60. 1998 12 valve
  61. injector size vs. boost?
  62. too hot
  63. meth injection help
  64. Pcm/ecu
  65. Fuel pressure
  66. Doggy after a super B
  67. truck wont start! help afc spring kit install
  68. Turbo A/R 1.51?
  69. Good fueling for twins
  70. Gauge Help
  71. 1996 DODGE RAM 3500 TURBO WASTEGATE
  72. which has more power
  73. 12v boost guage
  74. turbo time
  75. best place to get tow mirrors
  76. spool aid just for 03+ trucks?
  77. 5.9 second Gen 12 valve rebuild
  78. head stud?
  79. Partts list for fummins
  80. lets hear some ideas
  81. smokem special delivery valves
  82. transmission build problem. any help is welcome.
  83. intercooler leak
  84. steering problems after lift
  85. boost and fuel plate suggestions
  86. in need of a few opinions
  87. mbrp exhaust bolts
  88. tamper proof bolt
  89. Injector question/help
  90. how much power can a stock cummins make
  91. need a better trans
  92. hid headlight type??
  93. Intake manifold and grid heater delete?
  94. ISSPRO pyro
  95. overhaul questions and suggestions!
  96. hx40 spool
  97. Best diesel exhaust
  98. isspro dual pyrometer
  99. BHAF
  100. picking injectors 5x0.012s or 5x0.014s
  101. raptor 150 retrofit
  102. whats your HP?
  103. New toys
  104. Ground Wires
  105. Fuel plate bolts?
  106. Transmission rebuilt ARI seems good
  107. looking to to build a twin turbo setup
  108. 2nd gen cummins upgrades
  109. HP Calculator
  110. gauges
  111. Twins piping pictures
  112. guess my hp level
  113. turbo
  114. twin ram
  115. Airdog 12v
  116. turbo
  117. TC lock up switch?
  118. whos running a vgt??
  119. How to install governor springs
  120. opinions on SDX injectors
  121. do i need a new billet input?
  122. turbo
  123. H1C/H1E over HT60 Twins setup... Advice.
  124. How-To: Fuel Plate Mods
  125. New injector tips/nozzles
  126. 4k's installed
  127. PROGRAMMER ?
  128. Improving exhaust brake stopping power...
  129. Need some knowledable guidance.
  130. Bad Converter or not
  131. What injectors will give me the most hp.
  132. want a better turbo
  133. low budget build
  134. Modifications?
  135. when to upgrade intercoolers?
  136. whats the best clutch
  137. Want power...
  138. most timing i can run on 370 somewhat safe
  139. How hard is a auto to manual swap and what is the avergage cost?
  140. Crazy idea...
  141. Lower EGT's with larger Turbo Housing?
  142. intermeadiate shaft?????
  143. fuelplate Mod
  144. 7.3 intercooler on a cummins??
  145. Timing failure
  146. P-Pumped 24v Advice
  147. need idea on mounting ladder bars
  148. diesel shops????
  149. Which Turbo woud you recommend?
  150. Suspension to Stiff! 96 Cummins
  151. unknown mods runs like junk!
  152. Who makes / sells the TPS replacement kits
  153. #0 vs Plate less DIFFERENCES???
  154. 12 v power
  155. Timing
  156. what brand clutch
  157. valet switch?
  158. building a tranny and looking for pointers
  159. 12v build info needed
  160. Dlord
  161. Exhaust question
  162. 4K GSK install now not running right
  163. airdog help
  164. 91 5 speed in a 95
  165. where to get parts
  166. 271 swap.
  167. tran plans?
  168. marine injectors?
  169. output shaft??????
  170. injecters
  171. new tranny?
  172. got 7-800 to spend on the truck....what to get??
  173. crossover steering done
  174. body lift for a cummins?
  175. Injection pump
  176. fuel economy/ tire size?
  177. Laser Cut DV help!
  178. help please ?s about hx55's
  179. 3-piece Manifold
  180. 12 Valve need advice and mod ideas!
  181. trany
  182. Trouble
  183. How to get decent hp/tq from 99 block
  184. hx-35 hybrid
  185. head bolts
  186. excited
  187. ideal problems
  188. put govener springs in now truck shuts off
  189. KDP
  190. 5k GSK
  191. dv's issues
  192. Nv 271 slip yoke part number?
  193. i need an idea on which fuel plate is best
  194. Just curious
  195. nv4500 rebuild cost?
  196. adding horsepower question
  197. best hauling set up
  198. Truely reliable 400hp towing
  199. Better buy
  200. Adjustable injection pump gear
  201. Port and polish?
  202. needed any 12v info u have
  203. dual valve cover breather
  204. ok, 12v questions
  205. turbo education
  206. New 1997 Cummins owner
  207. Fuel supply
  208. Rebuild question
  209. engine build. 12 v or 24v
  210. 600-650hp goal
  211. Nv 271 swap
  212. Torgue converter thoughts
  213. boost???
  214. Turbo info
  215. 6.7 turbo on a 94 12v
  216. TO4B59
  217. timing with 370's
  218. 60lb spring talk
  219. What do you think?
  220. Delivery Valves for 94 cummins
  221. 4k gsk breaking up
  222. Turning the barrels
  223. what would next step be??
  224. lift kits
  225. hx40 no boost high egts
  226. 95 injection pump
  227. Stacks?
  228. 12 valve build up Need input!
  229. fuel plates, boost & Transmission
  230. Question about water/meth system?
  231. Advice Needed
  232. BOMB
  233. 3rd gen tail lights on a 2nd gen
  234. MPG?
  235. hx40
  236. EGT probe-where do you guys
  237. 4 or 3k?????
  238. Transmisssion weak points
  239. Opinion on Valair Clutches......
  240. Turning the barrels
  241. Tranny
  242. engine rebuild
  243. 4gsk ?
  244. 1995 cummins questions on parts
  245. timing?
  246. shift kit an valve body
  247. Bigger injectors?
  248. glowshift guages???
  249. Fuel line question
  250. hx40 limits
